MG32F02A/U 64/128 NCO(数字控制振荡器)
数字控制振荡器(Numerically Controlled Oscillator)什麼是数字控制振荡器?
NCO是一个非常好用的功能,可藉由程控产生任意频率的方波, 且不会造成主频变动.
数字控制振荡器的好處
1.产生最快24Mhz的频率组合2.可输出给外部使用3.可当成M0的追频函数
NCO溢出频率
(NCO输出频率需 < NCO输入频率/2 且 < APB频率/4)
代码简介#include "MG32x02z_APB_DRV.h"
//*** <<< Use Configuration Wizard in Context Menu >>> ***
//<o0> NCO input clock source select.
// <0=> CK_IHRCO
// <1=> CL_PLL
// <2=> CK_APB
// <3=> CK_LS
// <4=> TM00_TRGO
// <5=> NCO_CK0 (input pin)
#define NCOClock 0
选择NCO的时钟来源
//<o0> NCO output mode <0=>FDC mode <1=>PFM mode
#define NCOOutputMode 0
选择NCO的输出模式
FDC模式是固定占空比模式
PFM模式是脉冲频率模式
//<o0> Inverse NCO output <1=>ENABLE <0=>DISABLE
#define InverseNCO 0
设置NCO的输出反相
//<o0> input range from 0 to 1048575 (2^20 - 1)
#define NCOINCVal 1000
NC0的输入范围,根据前面公式设置该值,获得想要的频率
//<o0> APB NCO PFM width select (only support PFM mode)
// <0=> 1 CK_NCOn clock period
// <1=> 2 CK_NCOn clock period
// <2=> 4 CK_NCOn clock period
// <3=> 8 CK_NCOn clock period
// <4=> 16 CK_NCOn clock period
// <5=> 32 CK_NCOn clock period
// <6=> 64 CK_NCOn clock period
// <7=> 128 CK_NCOn clock period
#define NCO_PFMWidth 7
设置NCO PFM输出模式下的脉冲宽度
//*** <<< end of configuration section >>> ***
* @brief Initial NCO peripheral.
* @Details Initial NCO with start it.
* @return None
void Sample_APB_NCO(void)
// make sure :
//===Set CSC init====
//MG32x02z_CSC_Init.h(Configuration Wizard)
//Select CK_HS source = CK_IHRCO
//Select IHRCO = 12M
//Select CK_MAIN Source = CK_HS
//Configure PLL->Select APB Prescaler = CK_MAIN/1
//Configure Peripheral On Mode Clock->APB = Enable
在初始化之前确保设置好了想要的时钟
//==Set GPIO init
//NCO_P0 pin config:
//MG32x02z_GPIO_Init.h(Configuration Wizard)->Use GPIOB->PB3
//GPIO port initial is 0xFFFF
//PB3 mode is PPO
//PB3 function NCO_P0
确保相应的IO口设置到了相应的模式和功能复用。
// initial NCO
APB_NCOClockSource_Select((APB_NCOInputClockSrcDef) NCOClock);
APB_NCOOutputMode_Select((APB_NCOOutputMode) NCOOutputMode);
APB_NCOInverseOutput_Cmd((FunctionalState) InverseNCO);
APB_NCOPFMWidth_Select((APB_NCOPFMWidtrhSelDef) NCO_PFMWidth);
APB_NCOSetINC(NCOINCVal);
APB_NCOSetACC(999);
APB_NCO_Cmd(ENABLE);
初始化NCO的步骤:
1.选择输入时钟
2.选择输出模式
3.选择是否进行反相
4.设置PFM宽度(若使用PFM模式)
5.设置好输入比较值和计数值
6.使能输出。
return;
其它地方叫MCO 看看研究一下 数字控制振荡器简称NCO 笙泉的MCU感觉用的人很少啊,资源好找吗?
页:
[1]
