mao13226675618 发表于 2021-8-20 22:31
hc32m120-timer4输出2路4通道互补死区可调pwm-例程
hc32m120-timer4输出2路4通道带死区可调互补pwm。/*******************************************************************************
* Include files
#include "hc32_ddl.h"
* @addtogroup HC32M120_DDL_Examples
* @addtogroup TIMER4_PWM_Dead_Timer_Filter_Mode
* Local type definitions ('typedef')
* Local pre-processor symbols/macros ('#define')
/* TIM4 PWM Port/Pin definition */
#define TIM4_1_OXH_PORT               (GPIO_PORT_6)
#define TIM4_1_OXH_PIN                  (GPIO_PIN_1)
#define TIM4_1_OXH_GPIO_FUNC            (GPIO_FUNC_4_TIM4)
#define TIM4_1_OXL_PORT               (GPIO_PORT_6)
#define TIM4_1_OXL_PIN                  (GPIO_PIN_0)
#define TIM4_1_OXL_GPIO_FUNC            (GPIO_FUNC_2_TIM4)
#define TIM4_1_OVH_PORT               (GPIO_PORT_3)
#define TIM4_1_OVH_PIN                  (GPIO_PIN_1)
#define TIM4_1_OVH_GPIO_FUNC            (GPIO_FUNC_2_TIM4)
#define TIM4_1_OVL_PORT               (GPIO_PORT_6)
#define TIM4_1_OVL_PIN                  (GPIO_PIN_2)
#define TIM4_1_OVL_GPIO_FUNC            (GPIO_FUNC_4_TIM4)
/* Function clock gate definition */
#define FUNCTION_CLK_GATE               (CLK_FCG_TIM4)
/* Timer4 Counter period value && interrupt number definition */
#define TIMER4_CNT_CYCLE_VAL            ((uint16_t)(400))    /* 500 ms */
/* Timer4 OCO Channel definition */
//#define TIMER4_OCO_LOW_CH               (TIMER4_OCO_UL)    /* only TIMER4_OCO_ULTIMER4_OCO_VLTIMER4_OCO_WL */
//#define TIMER4_OCO_LOW_CH               (TIMER4_OCO_VL)
#define TIMER4_OCO_OCCR_BUF_SIZE      (4u)
/* Timer4 OCO get interrupt source number definition */
#define TIMER4_OCO_INT_SRC(x)         ((en_int_src_t)((uint32_t)INT_TMR4_GCMUH + ((uint32_t)((x) - TIMER4_OCO_UH))))
/* Timer4 PWM get channel by OCO low channel */
#define TIMER4_PWM_CH(x)                (((x) == TIMER4_OCO_UL) ? TIMER4_PWM_U : \
                                       (((x) == TIMER4_OCO_VL) ? TIMER4_PWM_V : TIMER4_PWM_W))
* Global variable definitions (declared in header file with 'extern')
* Local function prototypes ('static')
static void SystemClockConfig(void);
static void Timer4OcoMatchIrqCb(void);
* Local variable definitions ('static')
static uint16_t m_au16OccrVal;
* Function implementation - global ('extern') and local ('static')
* @briefConfigure system clock.
* @paramNone
* @retval None
    /* Configure the system clock to HRC8MHz. */
    CLK_HRCInit(CLK_HRC_ON, CLK_HRCFREQ_48);
* @briefTIMER4 OCO match interrupt handler callback.
* @paramNone
* @retval None
    static uint8_t u8CntOcoMatchIrq = 0u;
    if (++u8CntOcoMatchIrq >= TIMER4_OCO_OCCR_BUF_SIZE)
    TIMER4_OCO_ClearFlag(TIMER4_OCO_UL);
    TIMER4_OCO_SetOccrVal(TIMER4_OCO_UL, m_au16OccrVal);
                TIMER4_OCO_ClearFlag(TIMER4_OCO_VL);
    TIMER4_OCO_SetOccrVal(TIMER4_OCO_VL, m_au16OccrVal);
* @briefMain function of TIMER4 PWM dead timer filter mode
* @paramNone
* @retval int32_t return value, if needed
int32_t main(void)
    uint32_t u32PwmChU;
          uint32_t u32PwmChV;
    stc_irq_regi_config_t stcIrqRegiConf;
    stc_timer4_cnt_init_t stcTimer4CntInit;
    stc_timer4_oco_init_t stcTimer4OcoInit;
    stc_timer4_pwm_init_t stcTimer4PwmInit;
    stc_oco_low_ch_compare_mode_t stcLowChCmpMode;
    /* Configure system clock. */
    SystemClockConfig();
    /* Enable peripheral clock */
    CLK_FcgPeriphClockCmd(FUNCTION_CLK_GATE, Enable);
    /* Initialize TIMER4 Counter */
    TIMER4_CNT_StructInit(&stcTimer4CntInit);
    stcTimer4CntInit.u16ClkDiv = TIMER4_CNT_CLK_DIV1;
    /* Period_Value(500ms) = SystemClock(SystemCoreClock) / TIMER4_CNT_Clock_Division(128) / Frequency(2) */
    stcTimer4CntInit.u16CycleVal = TIMER4_CNT_CYCLE_VAL;
    TIMER4_CNT_Init(&stcTimer4CntInit);
    /* Initialize TIMER4 OCO high&&low channel */
    m_au16OccrVal = (TIMER4_CNT_CYCLE_VAL / 2u);
    TIMER4_OCO_StructInit(&stcTimer4OcoInit);
    stcTimer4OcoInit.enOcoCmd = Enable;
    stcTimer4OcoInit.enOcoIntCmd = Enable;
    stcTimer4OcoInit.u16OccrVal = m_au16OccrVal;
    TIMER4_OCO_Init(TIMER4_OCO_UL, &stcTimer4OcoInit);
    TIMER4_OCO_Init(TIMER4_OCO_VL, &stcTimer4OcoInit);
   // if (TIMER4_OCO_LOW_CH % 2ul)
      /* OCMR 0x0FF0 0FFF = b 0000 1111 1111 0000   0000 1111 1111 1111 */
      stcLowChCmpMode.OCMRx_f.OCFDCL = TIMER4_OCO_OCF_SET;    /* bit 1 */
      stcLowChCmpMode.OCMRx_f.OCFPKL = TIMER4_OCO_OCF_SET;    /* bit 1 */
      stcLowChCmpMode.OCMRx_f.OCFUCL = TIMER4_OCO_OCF_SET;    /* bit 1 */
      stcLowChCmpMode.OCMRx_f.OCFZRL = TIMER4_OCO_OCF_SET;    /* bit 1 */
      stcLowChCmpMode.OCMRx_f.OPDCL = TIMER4_OCO_OP_INVERT;   /* bit    11 */
      stcLowChCmpMode.OCMRx_f.OPPKL = TIMER4_OCO_OP_INVERT;   /* bit    11 */
      stcLowChCmpMode.OCMRx_f.OPUCL = TIMER4_OCO_OP_INVERT;   /* bit    11 */
      stcLowChCmpMode.OCMRx_f.OPZRL = TIMER4_OCO_OP_INVERT;   /* bit11 */
      stcLowChCmpMode.OCMRx_f.OPNPKL = TIMER4_OCO_OP_HOLD;    /* bit00 */
      stcLowChCmpMode.OCMRx_f.OPNZRL = TIMER4_OCO_OP_HOLD;    /* bit00 */
      stcLowChCmpMode.OCMRx_f.EOPNDCL = TIMER4_OCO_OP_HOLD;   /* bit00 */
      stcLowChCmpMode.OCMRx_f.EOPNUCL = TIMER4_OCO_OP_HOLD;   /* bit00 */
      stcLowChCmpMode.OCMRx_f.EOPDCL = TIMER4_OCO_OP_INVERT;/* bit11 */
      stcLowChCmpMode.OCMRx_f.EOPPKL = TIMER4_OCO_OP_INVERT;/* bit11 */
      stcLowChCmpMode.OCMRx_f.EOPUCL = TIMER4_OCO_OP_INVERT;/* bit11 */
      stcLowChCmpMode.OCMRx_f.EOPZRL = TIMER4_OCO_OP_INVERT;/* bit11 */
      stcLowChCmpMode.OCMRx_f.EOPNPKL = TIMER4_OCO_OP_HOLD;   /* bit00 */
      stcLowChCmpMode.OCMRx_f.EOPNZRL = TIMER4_OCO_OP_HOLD;   /* bit00 */
      stcLowChCmpMode.enExtendMatchCondCmd =Enable; //Disable;//Enable;
      TIMER4_OCO_SetLowChCompareMode(TIMER4_OCO_UL, &stcLowChCmpMode);/* Set OCO low channel compare mode */
                              TIMER4_OCO_SetLowChCompareMode(TIMER4_OCO_VL, &stcLowChCmpMode);
    /* Register IRQ handler && configure NVIC. */
    stcIrqRegiConf.enIRQn = Int013_IRQn;
    stcIrqRegiConf.enIntSrc =TIMER4_OCO_INT_SRC(TIMER4_OCO_UL);
                stcIrqRegiConf.enIntSrc =TIMER4_OCO_INT_SRC(TIMER4_OCO_VL);
    stcIrqRegiConf.pfnCallback = &Timer4OcoMatchIrqCb;
    INTC_IrqRegistration(&stcIrqRegiConf);
    NVIC_ClearPendingIRQ(stcIrqRegiConf.enIRQn);
    NVIC_SetPriority(stcIrqRegiConf.enIRQn, DDL_IRQ_PRIORITY_03);
    NVIC_EnableIRQ(stcIrqRegiConf.enIRQn);
    /* Initialize PWM I/O */
    GPIO_SetFunc(TIM4_1_OXH_PORT, TIM4_1_OXH_PIN, TIM4_1_OXH_GPIO_FUNC);
    GPIO_SetFunc(TIM4_1_OXL_PORT, TIM4_1_OXL_PIN, TIM4_1_OXL_GPIO_FUNC);
    GPIO_SetFunc(TIM4_1_OVH_PORT, TIM4_1_OVH_PIN, TIM4_1_OVH_GPIO_FUNC);
    GPIO_SetFunc(TIM4_1_OVL_PORT, TIM4_1_OVL_PIN, TIM4_1_OVL_GPIO_FUNC);
    /* Timer4 PWM: Get pwm couple channel */
    u32PwmChU = TIMER4_PWM_CH(TIMER4_OCO_UL);
    u32PwmChV = TIMER4_PWM_CH(TIMER4_OCO_VL);
    /* Initialize Timer4 PWM */
    TIMER4_PWM_StructInit(&stcTimer4PwmInit);
    stcTimer4PwmInit.enRtIntMaskCmd = Enable;
    stcTimer4PwmInit.u16ClkDiv = TIMER4_PWM_CLK_DIV1;
    stcTimer4PwmInit.u16Mode = TIMER4_PWM_DEAD_TIMER_FILTER_MODE;
    TIMER4_PWM_Init(u32PwmChU, &stcTimer4PwmInit);
    TIMER4_PWM_SetDeadRegionValue(u32PwmChU, 10u, 10u);
    TIMER4_PWM_SetFilterCountValue(u32PwmChU, (200u));
    TIMER4_PWM_Init(u32PwmChV, &stcTimer4PwmInit);
    TIMER4_PWM_SetDeadRegionValue(u32PwmChV, 10u, 10u);
    TIMER4_PWM_SetFilterCountValue(u32PwmChV, (200u));
    /* Start TIMER4 counter. */
    TIMER4_CNT_Start();
    while (1)
9.90
请在此处填写付费后可见内容
mao13226675618 发表于 2021-8-20 22:38
波形运行稳定,开始信赖华大了,支撑国产技术发展壮大!
mao13226675618 发表于 2021-8-21 08:12
感觉比st更方便了,哈哈哈
mao13226675618 发表于 2021-8-23 06:57
支持华大做强做大
tpgf 发表于 2021-9-10 17:57
死区的范围是多少啊
martinhu 发表于 2021-9-14 13:59
这里的输出比较匹配电平逻辑设定,用翻转虽然也能出想要的波形,
但是在有些情况下可能会出错。
最好使用输出高或者输出低电平的设定。不过逻辑得重新整理。
洪泽湖湖主 发表于 2024-11-14 14:02
6666
suncat0504 发表于 2024-11-19 10:30
多支持国产,发展才会越来越好。
地瓜patch 发表于 2025-1-21 22:02
波形真不错
申小林一号 发表于 2025-1-22 08:48
感谢啊
页: [1]
查看完整版本: hc32m120-timer4输出2路4通道互补死区可调pwm-例程
