关于GD32F303定时器Timer8输出PWM问题
我想使用PE5输出PWM,复用Timer8 ch0,根据例程修改定时器后,一直无法输出,代码如下,请大神指导!!!//PE5复用Timer8 ch0
timer_oc_parameter_struct timer_ocintpara;
timer_parameter_struct timer_initpara;
rcu_periph_clock_enable(RCU_AF);
rcu_periph_clock_enable(RCU_GPIOE);
gpio_pin_remap_config(GPIO_TIMER8_REMAP,ENABLE);
/*Configure PE5(TIMER8_CH0) as alternate function*/
gpio_init(GPIOE, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_5);
rcu_periph_clock_enable(RCU_TIMER8);
timer_deinit(TIMER8);
/* TIMER8 configuration */
timer_initpara.prescaler = 108;
timer_initpara.alignedmode = TIMER_COUNTER_EDGE;
timer_initpara.counterdirection= TIMER_COUNTER_UP;
timer_initpara.period = 500;
timer_initpara.clockdivision = TIMER_CKDIV_DIV1;
timer_initpara.repetitioncounter = 0;
timer_init(TIMER8,&timer_initpara);
/* CH0 configuration in PWM mode */
timer_ocintpara.outputstate= TIMER_CCX_ENABLE;
timer_ocintpara.outputnstate = TIMER_CCXN_DISABLE;
timer_ocintpara.ocpolarity = TIMER_OC_POLARITY_HIGH;
timer_ocintpara.ocnpolarity= TIMER_OCN_POLARITY_HIGH;
timer_ocintpara.ocidlestate= TIMER_OC_IDLE_STATE_LOW;
timer_ocintpara.ocnidlestate = TIMER_OCN_IDLE_STATE_LOW;
timer_channel_output_config(TIMER8,TIMER_CH_0,&timer_ocintpara);
timer_channel_output_pulse_value_config(TIMER8,TIMER_CH_0,250);
timer_channel_output_mode_config(TIMER8,TIMER_CH_0,TIMER_OC_MODE_PWM0);
timer_channel_output_shadow_config(TIMER8,TIMER_CH_0,TIMER_OC_SHADOW_DISABLE);
timer_primary_output_config(TIMER8,ENABLE);
/* auto-reload preload enable */
timer_auto_reload_shadow_enable(TIMER8);
timer_enable(TIMER8); 楼主解决了么,最近我也遇到这个问题 我是GD原厂代理有需要和有需要可以交流合作13242085214研发遇到任何问题我们提供技术帮助 不会是没有TIMER8的303吧? 我也发现类似问题,查到库函数timer_init 就没有对timer8进行处理, 见:
void timer_init(uint32_t timer_periph, timer_parameter_struct* initpara)
/* configure the counter prescaler value */
TIMER_PSC(timer_periph) = (uint16_t)initpara->prescaler;
/* configure the counter direction and aligned mode */
if((TIMER0 == timer_periph) || (TIMER1 == timer_periph) || (TIMER2 == timer_periph)
|| (TIMER3 == timer_periph) || (TIMER4 == timer_periph) || (TIMER7 == timer_periph)){
TIMER_CTL0(timer_periph) &= ~(uint32_t)(TIMER_CTL0_DIR|TIMER_CTL0_CAM);
TIMER_CTL0(timer_periph) |= (uint32_t)initpara->alignedmode;
TIMER_CTL0(timer_periph) |= (uint32_t)initpara->counterdirection;
/* configure the autoreload value */
TIMER_CAR(timer_periph) = (uint32_t)initpara->period;
if((TIMER5 != timer_periph) && (TIMER6 != timer_periph)){
/* reset the CKDIV bit */
TIMER_CTL0(timer_periph) &= ~(uint32_t)TIMER_CTL0_CKDIV;
TIMER_CTL0(timer_periph) |= (uint32_t)initpara->clockdivision;
if((TIMER0 == timer_periph) || (TIMER7 == timer_periph)){
/* configure the repetition counter value */
TIMER_CREP(timer_periph) = (uint32_t)initpara->repetitioncounter;
/* generate an update event */
TIMER_SWEVG(timer_periph) |= (uint32_t)TIMER_SWEVG_UPG;
} 重映射配置是否正确?PIO_TIMER8_REMAP可能未正确启用。 gpio_pin_remap_config(GPIO_TIMER8_REMAP, ENABLE)可能未生效。 timer_init()函数可能未完全配置TIMER8。 TIMER_OC_MODE_PWM0模式需配合极性和预装载。 重映射冲突或者时钟未启用。 经各位大佬提醒, 确实是Timer8_CH1@PE6重定位忘了写了, 加上后, timer8初始化正常!看来不是库函数timer_init()的问题。现在的问题是timer11_CH0(@PB15)也使用了类似的设置, 无重定位要求, 但还无法使用, 检查中。
页:
[1]
