遥寄山川 发表于 2024-8-23 09:59
迅为iTOP-STM32MP157开发板Linux稳定开发学习
迅为ITOP-STM32MP157是基于ST的STM32MP157芯片开发的一款开发平台。
在STM32MP157开发平台上,我们也做了比较多的创新,其中重要的一点就是,iTOP-STM32MP157核心板电源管理采用ST全新配套研制的PMIC电源管理芯片STPMU1A。为整个系统的稳定运行提供了更可靠的保证。
核心板通过了电磁兼容,电磁辐射,安规检测、高低温环境测验,采用邮票孔的连接方式,连接方式更加稳定和可靠。
底板板载4G接口(选配)、千兆以太网、WIFI蓝牙模块、HDMI、CAN、RS485、LVDS接口、温湿度传感器(选配)光环境传感器、六轴传感器、2路USB OTG、3路串口、CAMERA接口、ADC电位器、SPDIF、 SDIO接口等。
在迅为iTOP-STM32MP157开发板上,系统支持Buildroot、QT5.12.10、ubuntu_base_20.04、Debian、yocto、最小Linux系统。 系统驱动源码全开源,提供开发使用手册并长期稳定更新,资料不断升级。
适用于智能充电桩、物联网、工业控制、医疗、智能交通等,可用于任何通用工业和物联网应用。
https://www.eechina.com/data/attachment/forum/202202/21/102815r5xyvm0qzjny07b7.jpg
https://www.eechina.com/data/attachment/forum/202202/21/102815p448s1m9jzzuiu1x.jpg
https://www.eechina.com/data/attachment/forum/202202/21/102815nne711momeom0rot.jpg
https://www.eechina.com/data/attachment/forum/202202/21/102815loclbw1iiasioszp.jpg
https://www.eechina.com/data/attachment/forum/202202/21/102815tmcxcmtgz4mxmc1p.jpg
https://www.eechina.com/data/attachment/forum/202202/21/102815t02cd6ee3pl37072.jpg
https://www.eechina.com/data/attachment/forum/202202/21/102816j3iujnrmz8jrinie.jpg
https://www.eechina.com/data/attachment/forum/202202/21/102816y8r5fp85ib3445c5.jpg
https://www.eechina.com/data/attachment/forum/202202/21/102816l2tep2qe63oft86y.jpg
https://www.eechina.com/data/attachment/forum/202202/21/102816nf3oifnbdqb1n3nb.jpg
https://www.eechina.com/data/attachment/forum/202202/21/102816ekdkszs7sk7ejf6m.jpg
https://www.eechina.com/data/attachment/forum/202202/21/102816cicqcos7nsy46w4l.jpg
https://www.eechina.com/data/attachment/forum/202202/21/102816h0aeemiemzeazm5i.jpg
https://www.eechina.com/data/attachment/forum/202202/21/102817l3sd3d3cv7pdqaaj.jpg
https://www.eechina.com/data/attachment/forum/202202/21/102817yj9v9fktfh9xt2vk.jpg
https://www.eechina.com/data/attachment/forum/202202/21/102817d3d3l2y32192qfrz.jpg
https://www.eechina.com/data/attachment/forum/202202/21/102817hlczkr2xpphkwtpx.jpg
核心板参数列表
CPU: STM32MP157A
架构: 双核 cortex-A7、单核 cortex-M4
主频: 650M
内存: 1G
存储: 8GB
工作电压: 直流 5V 供电
系统支持: 最小 Linux 系统、Buildroot、QT5.12.10、ubuntu_base_20.04、yocto 系统、Debian 系统
底板参数列表
尺寸 底板:190mm * 125mm
POWER: 电直流电源输入接口,12V/3A+电源输入
SWITCH: 电源开关
DIP SWITCH: 4 位拨码开关
ADC 电位器: 1 路
SDIO 接口: 1 个
JTAG 接口: 1 个
CAMERA 接口: 1 个
CAN 接口: 1 路 CAN
User Key: 5 个功能按键北京迅为电子有限公司 iTOP-STM32MP157 开发板使用手册
MIC: 支持 MIC 输入
PHONE: 支持耳机输出
串口: 3 路
USB Host: 2 路 USB Host,支持 USB2.0 协议
TF Card: 1 个标准 TF 卡接口
网口: 1 路千兆以太网接口
LED: 3 个(1 个电源指示灯,2 个可控 LED)
HDMI 接口: 1 路
LCD 接口: 1 路 LVDS(HDMI 口输出 lvds 信号), 1 路 RGB
USB OTG: 2 路 USB OTG 2.0
RTC 座: 1 个
RS485 接口: 1 路 RS485
WIFI/蓝牙芯片: 1 路
4G 模组(选配): 1 个
六轴传感器: 1 个
蜂鸣器: 1 个
红外传感器: 1 个
光环境传感器: 1 个
温湿度传感器: 1 个
页: [1]
查看完整版本: 迅为iTOP-STM32MP157开发板Linux稳定开发学习
