软件crc32 和硬件crc 大家一般用哪个?
软件crc32static const uint32_t crc32_table[] = {
0x00000000, 0x77073096, 0xEE0E612C, 0x990951BA, 0x076DC419, 0x706AF48F, 0xE963A535, 0x9E6495A3,
0x0EDB8832, 0x79DCB8A4, 0xE0D5E91E, 0x97D2D988, 0x09B64C2B, 0x7EB17CBD, 0xE7B82D07, 0x90BF1D91,
0x1DB71064, 0x6AB020F2, 0xF3B97148, 0x84BE41DE, 0x1ADAD47D, 0x6DDDE4EB, 0xF4D4B551, 0x83D385C7,
0x136C9856, 0x646BA8C0, 0xFD62F97A, 0x8A65C9EC, 0x14015C4F, 0x63066CD9, 0xFA0F3D63, 0x8D080DF5,
0x3B6E20C8, 0x4C69105E, 0xD56041E4, 0xA2677172, 0x3C03E4D1, 0x4B04D447, 0xD20D85FD, 0xA50AB56B,
0x35B5A8FA, 0x42B2986C, 0xDBBBC9D6, 0xACBCF940, 0x32D86CE3, 0x45DF5C75, 0xDCD60DCF, 0xABD13D59,
0x26D930AC, 0x51DE003A, 0xC8D75180, 0xBFD06116, 0x21B4F4B5, 0x56B3C423, 0xCFBA9599, 0xB8BDA50F,
0x2802B89E, 0x5F058808, 0xC60CD9B2, 0xB10BE924, 0x2F6F7C87, 0x58684C11, 0xC1611DAB, 0xB6662D3D,
0x76DC4190, 0x01DB7106, 0x98D220BC, 0xEFD5102A, 0x71B18589, 0x06B6B51F, 0x9FBFE4A5, 0xE8B8D433,
0x7807C9A2, 0x0F00F934, 0x9609A88E, 0xE10E9818, 0x7F6A0DBB, 0x086D3D2D, 0x91646C97, 0xE6635C01,
0x6B6B51F4, 0x1C6C6162, 0x856530D8, 0xF262004E, 0x6C0695ED, 0x1B01A57B, 0x8208F4C1, 0xF50FC457,
0x65B0D9C6, 0x12B7E950, 0x8BBEB8EA, 0xFCB9887C, 0x62DD1DDF, 0x15DA2D49, 0x8CD37CF3, 0xFBD44C65,
0x4DB26158, 0x3AB551CE, 0xA3BC0074, 0xD4BB30E2, 0x4ADFA541, 0x3DD895D7, 0xA4D1C46D, 0xD3D6F4FB,
0x4369E96A, 0x346ED9FC, 0xAD678846, 0xDA60B8D0, 0x44042D73, 0x33031DE5, 0xAA0A4C5F, 0xDD0D7CC9,
0x5005713C, 0x270241AA, 0xBE0B1010, 0xC90C2086, 0x5768B525, 0x206F85B3, 0xB966D409, 0xCE61E49F,
0x5EDEF90E, 0x29D9C998, 0xB0D09822, 0xC7D7A8B4, 0x59B33D17, 0x2EB40D81, 0xB7BD5C3B, 0xC0BA6CAD,
0xEDB88320, 0x9ABFB3B6, 0x03B6E20C, 0x74B1D29A, 0xEAD54739, 0x9DD277AF, 0x04DB2615, 0x73DC1683,
0xE3630B12, 0x94643B84, 0x0D6D6A3E, 0x7A6A5AA8, 0xE40ECF0B, 0x9309FF9D, 0x0A00AE27, 0x7D079EB1,
0xF00F9344, 0x8708A3D2, 0x1E01F268, 0x6906C2FE, 0xF762575D, 0x806567CB, 0x196C3671, 0x6E6B06E7,
0xFED41B76, 0x89D32BE0, 0x10DA7A5A, 0x67DD4ACC, 0xF9B9DF6F, 0x8EBEEFF9, 0x17B7BE43, 0x60B08ED5,
0xD6D6A3E8, 0xA1D1937E, 0x38D8C2C4, 0x4FDFF252, 0xD1BB67F1, 0xA6BC5767, 0x3FB506DD, 0x48B2364B,
0xD80D2BDA, 0xAF0A1B4C, 0x36034AF6, 0x41047A60, 0xDF60EFC3, 0xA867DF55, 0x316E8EEF, 0x4669BE79,
0xCB61B38C, 0xBC66831A, 0x256FD2A0, 0x5268E236, 0xCC0C7795, 0xBB0B4703, 0x220216B9, 0x5505262F,
0xC5BA3BBE, 0xB2BD0B28, 0x2BB45A92, 0x5CB36A04, 0xC2D7FFA7, 0xB5D0CF31, 0x2CD99E8B, 0x5BDEAE1D,
0x9B64C2B0, 0xEC63F226, 0x756AA39C, 0x026D930A, 0x9C0906A9, 0xEB0E363F, 0x72076785, 0x05005713,
0x95BF4A82, 0xE2B87A14, 0x7BB12BAE, 0x0CB61B38, 0x92D28E9B, 0xE5D5BE0D, 0x7CDCEFB7, 0x0BDBDF21,
0x86D3D2D4, 0xF1D4E242, 0x68DDB3F8, 0x1FDA836E, 0x81BE16CD, 0xF6B9265B, 0x6FB077E1, 0x18B74777,
0x88085AE6, 0xFF0F6A70, 0x66063BCA, 0x11010B5C, 0x8F659EFF, 0xF862AE69, 0x616BFFD3, 0x166CCF45,
0xA00AE278, 0xD70DD2EE, 0x4E048354, 0x3903B3C2, 0xA7672661, 0xD06016F7, 0x4969474D, 0x3E6E77DB,
0xAED16A4A, 0xD9D65ADC, 0x40DF0B66, 0x37D83BF0, 0xA9BCAE53, 0xDEBB9EC5, 0x47B2CF7F, 0x30B5FFE9,
0xBDBDF21C, 0xCABAC28A, 0x53B39330, 0x24B4A3A6, 0xBAD03605, 0xCDD70693, 0x54DE5729, 0x23D967BF,
0xB3667A2E, 0xC4614AB8, 0x5D681B02, 0x2A6F2B94, 0xB40BBE37, 0xC30C8EA1, 0x5A05DF1B, 0x2D02EF8D
uint32_t crc32_cyc_cal(uint32_t init_val, uint8_t *pdata, uint32_t len)
register uint32_t i;
register uint32_t crc32;
register uint8_t idx;
crc32 = init_val;
for(i=0; i<len; i++)
idx = ((uint8_t)crc32) ^ (*pdata++);
crc32 = (crc32>>8) ^ crc32_table;
return(crc32);
uint32_t crc32_cal(uint8_t *pdata, uint32_t len)
return(crc32_cyc_cal(CRC32_INIT_VAL, pdata, len) ^ CRC32_INIT_VAL);
硬件crc,一般使用芯片内部的
软件CRC计算量较大,如果对执行时间没有要求的话可以用软件CRC,硬件CRC执行时间快,一般会使用硬件CRC 个人观点:软件CRC计算较慢,硬件CRC计算效率快,由于硬件CRC算法单一以及对芯片的依赖程度,因此大部分还是选择软件CRC 是的,硬件计算较快,代码工程我一般也是选择软件,更多的时候用来兼容协议,移植通用性较强 软件CRC32和硬件CRC各有优缺点,选择哪种方式取决于具体的应用场景和需求。 在性能要求较高的场景中,硬件CRC可能更具优势;而在灵活性要求较高的场景中,软件CRC32可能更为合适。 通过软件算法在CPU上执行CRC计算。 硬件CRC电路通常是针对特定的CRC标准设计的,灵活性较差,但稳定性更高 如果硬件资源有限,或者硬件CRC不可用,则选择软件CRC。 软件CRC32的实现相对简单,开发者可以使用现成的库函数或自行实现算法。
硬件CRC的开发需要硬件设计知识,开发难度相对较大。 如果硬件支持,通常优先选择硬件CRC32,因为它能提供更高的性能和更低的功耗。但是,软件CRC32由于其灵活性和普适性,也是非常重要的一个选项。 硬件实现的CRC不需要CPU参与,可以减轻CPU的负担,提高系统性能。 相比软件实现,硬件CRC通常能以更低的功耗完成任务。 如果硬件不支持CRC或需要额外的硬件成本来实现CRC功能,软件CRC可能是一个更经济的选择。 软件实现的CRC32和硬件实现的CRC各有优缺点,选择哪个取决于具体的应用场景和需求。 需要权衡硬件成本和软件开发的成本。 在嵌入式系统中,如果数据量大且需要实时校验,通常优先选择硬件CRC。 软件CRC32通常用于对数据传输或存储过程中的完整性进行校验,广泛应用于文件传输、网络通信、嵌入式系统等领域。
硬件CRC则更多地应用于需要高速数据处理和实时性要求较高的场景,如高速网络设备、存储控制器等。 软件CRC32算法更加灵活,可以方便地更换CRC多项式,或者修改算法以适应不同的校验需求。 软件CRC32可以在任何支持所需编程语言的平台上实现,不受硬件限制。
