gaoyang9992006 发表于 2024-11-14 22:02
CW32L010开发板尝鲜体验+驱动TFT屏幕ST7735S
第一句:认真看原理图
SPI的使用其实很简单,但是驱动SPI接口的TFT还需要几个IO配合,RST、CS、DC
根据原理图选择合适的引脚使用,至关重要
#define ST7735_RST_Pin       GPIO_PIN_5
#define ST7735_RST_GPIO_Port CW_GPIOB
#define ST7735_DC_Pin      GPIO_PIN_6
#define ST7735_DC_GPIO_PortCW_GPIOB
#define ST7735_CS_Pin      GPIO_PIN_2
#define ST7735_CS_GPIO_PortCW_GPIOA
#define ST7735_SCK_Pin         GPIO_PIN_5
#define ST7735_SCK_GPIO_Port   CW_GPIOA
#define ST7735_MOSI_Pin      GPIO_PIN_4
#define ST7735_MOSI_GPIO_PortCW_GPIOA
#define ST7735_SPICW_SPI然后就可以愉快的使用这些映射合适引脚的宏和外设了
                //推挽输出
        GPIO_InitStructure.Pins = ST7735_CS_Pin;
        GPIO_InitStructure.IT = GPIO_IT_NONE;
        GPIO_InitStructure.Mode = GPIO_MODE_OUTPUT_PP;
        GPIO_Init(ST7735_CS_GPIO_Port, &GPIO_InitStructure);
        GPIO_InitStructure.Pins = ST7735_DC_Pin;
        GPIO_Init(ST7735_DC_GPIO_Port, &GPIO_InitStructure);
        GPIO_InitStructure.Pins = ST7735_RST_Pin;
        GPIO_Init(ST7735_RST_GPIO_Port, &GPIO_InitStructure);
        GPIO_InitStructure.Pins = ST7735_SCK_Pin;
        GPIO_Init(ST7735_SCK_GPIO_Port, &GPIO_InitStructure);
        GPIO_InitStructure.Pins = ST7735_MOSI_Pin;
        GPIO_Init(ST7735_MOSI_GPIO_Port, &GPIO_InitStructure);
        PA05_AFx_SPI1SCK();
        PA04_AFx_SPI1MOSI();
        SYSCTRL_APBPeriphClk_Enable1(SYSCTRL_APB1_PERIPH_SPI, ENABLE);
        SPI_InitTypeDef SPI_InitStructure;
        SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_TxOnly;         //单工只发
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                         // 主机模式
        SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                     // 帧数据长度为8bit
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;                           // 时钟空闲电平为高
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;                        // 第2个边沿采样
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                           // 片选信号由SSI寄存器控制
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;    // 波特率为PCLK的4分频
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;                  // 最高有效位 MSB 收发在前
        SPI_InitStructure.SPI_Speed = SPI_Speed_Low;                        // 低速SPI
        SPI_Init(ST7735_SPI, &SPI_InitStructure);
        SPI_Cmd(ST7735_SPI, ENABLE);接下来就可以调用库函数执行相关的数据传输指令了void ST7735_delay(uint8_t i)
        delay1ms(i);
void ST7735_SPI_SendByte(uint8_t byte)
//        判断是否可以继续发送放在之后判断可以避免CS拉高后还没发送结束。可以确保每一次发送都是成功的。
        SPI_SendData(ST7735_SPI, byte);
        while(SPI_GetFlagStatus(ST7735_SPI, SPI_FLAG_TXE) == RESET);
void ST7735_SPI_RST_SetLow(void)
        GPIO_WritePin(ST7735_RST_GPIO_Port,ST7735_RST_Pin,GPIO_Pin_RESET);
void ST7735_SPI_RST_SetHigh(void)
        GPIO_WritePin(ST7735_RST_GPIO_Port,ST7735_RST_Pin,GPIO_Pin_SET);
void ST7735_SPI_CS_SetLow(void)
        GPIO_WritePin(ST7735_CS_GPIO_Port,ST7735_CS_Pin,GPIO_Pin_RESET);
void ST7735_SPI_CS_SetHigh(void)
        GPIO_WritePin(ST7735_CS_GPIO_Port,ST7735_CS_Pin,GPIO_Pin_SET);
void ST7735_SPI_DC_SetLow(void)
        GPIO_WritePin(ST7735_DC_GPIO_Port,ST7735_DC_Pin,GPIO_Pin_RESET);
void ST7735_SPI_DC_SetHigh(void)
        GPIO_WritePin(ST7735_DC_GPIO_Port,ST7735_DC_Pin,GPIO_Pin_SET);
以下函数不用修改,以下函数调用上面的几个基础函数完成ST7735接口的操作。
void ST7735_Reset(void)
        ST7735_SPI_RST_SetLow();
        ST7735_delay(100);
        ST7735_SPI_RST_SetHigh();
        ST7735_delay(100);
void ST7735_WriteCommand(uint8_t cmd)
        ST7735_SPI_CS_SetLow();
        ST7735_SPI_DC_SetLow();
        ST7735_SPI_SendByte(cmd);
        ST7735_SPI_CS_SetHigh();
void ST7735_WriteByte(uint8_t data)
        ST7735_SPI_DC_SetHigh();
        ST7735_SPI_SendByte(data);
void ST7735_WriteData(uint8_t *data, size_t data_size)
        for(int i=0;i<data_size;i++) ST7735_SPI_SendByte(*(data+i));
}在主函数完成代码
int32_t main(void)
    SYSCTRL_HSI_Enable(SYSCTRL_HSIOSC_DIV12);
    __SYSCTRL_GPIOA_CLK_ENABLE();
    __SYSCTRL_GPIOB_CLK_ENABLE();
                //推挽输出
        GPIO_InitStructure.Pins = GPIO_PIN_2;
        GPIO_Init(CW_GPIOB, &GPIO_InitStructure);
        SPI_Configuration();
        ST7735_Init();
        ST7735_FillScreen(ST7735_BLACK);
        ST7735_DrawRectangle(0,0,10,5,ST7735_YELLOW);
        ST7735_DrawRectangle(15,5,10,20,ST7735_BLUE);
        ST7735_DrawRectangle(30,25,10,10,ST7735_RED);
        ST7735_DrawString(0,35,"Hello",ST7735_GREEN,ST7735_BLACK,&Font_11x18);
        ST7735_DrawString(0,55,"Hello",ST7735_MAGENTA,ST7735_BLACK,&Font_7x10);
        while(1)
                GPIO_WritePin(CW_GPIOB,GPIO_PIN_2,GPIO_Pin_RESET);
                Delay(0xFFFF);
                GPIO_WritePin(CW_GPIOB,GPIO_PIN_2,GPIO_Pin_SET);
                Delay(0xFFFF);
}编译烧录,点亮屏幕
小小蚂蚁举千斤 发表于 2024-11-22 09:29
SPI驱动案例还是非常不错的
gaoyang9992006 发表于 2024-11-24 14:29
中国龙芯CDX 发表于 2024-11-24 19:26
SPI驱动还是非常有必要的
feifeiniao 发表于 2025-6-26 14:27
参考参考代码
页: [1]
查看完整版本: CW32L010开发板尝鲜体验+驱动TFT屏幕ST7735S
