求ESP32通过mqtt和android进行图片传输代码
求ESP32通过mqtt和android进行图片传输代码提供apk的编译文件。代码运行成功截图。提供运行机制说明,自己修改的说明。
本帖最后由 3472076282 于 2024-11-26 09:42 编辑ESP32 端代码首先,确保你已经安装了所需的库,例如 PubSubClient 和 WiFi。#include <WiFi.h>#include <PubSubClient.h> // WiFi credentialsconst char* ssid = "your_SSID";const char* password = "your_PASSWORD"; // MQTT Brokerconst char* mqtt_server = "broker.hivemq.com"; WiFiClient espClient;PubSubClient client(espClient); void setup() {Serial.begin(115200);setup_wifi();client.setServer(mqtt_server, 1883);} void setup_wifi() {delay(10);Serial.println();Serial.print("Connecting to ");Serial.println(ssid); WiFi.begin(ssid, password); while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print(".");} Serial.println("");Serial.println("WiFi connected");Serial.println("IP address: ");Serial.println(WiFi.localIP());} void reconnect() {while (!client.connected()) { Serial.print("Attempting MQTT connection..."); if (client.connect("ESP32Client")) { Serial.println("connected"); } else { Serial.print("failed, rc="); Serial.print(client.state()); Serial.println(" try again in 5 seconds"); delay(5000); }}} void loop() {if (!client.connected()) { reconnect();}client.loop();} Android 端代码在Android端,你可以使用Paho MQTT库来连接到MQTT Broker并发送/接收消息。以下是一个基本的示例:1. 添加依赖项到你的 build.gradle 文件: dependencies { implementation 'org.eclipse.paho:org.eclipse.paho.client.mqttv3:1.2.5' implementation 'org.eclipse.paho:org.eclipse.paho.android.service:1.1.1'} 2. 创建一个服务来处理MQTT连接: import android.app.Service;import android.content.Intent;import android.os.IBinder;import org.eclipse.paho.android.service.MqttAndroidClient;import org.eclipse.paho.client.mqttv3.IMqttActionListener;import org.eclipse.paho.client.mqttv3.IMqttToken;import org.eclipse.paho.client.mqttv3.MqttCallback;import org.eclipse.paho.client.mqttv3.MqttMessage; public class MqttService extends Service { private static final String MQTT_BROKER_URL = "tcp://broker.hivemq.com:1883"; private static final String CLIENT_ID = "AndroidClient"; private MqttAndroidClient mqttAndroidClient; @Override public void onCreate() { super.onCreate(); mqttAndroidClient = new MqttAndroidClient(this, MQTT_BROKER_URL, CLIENT_ID); mqttAndroidClient.setCallback(new MqttCallback() { @Override public void connectionLost(Throwable cause) { // handle connection loss } @Override public void messageArrived(String topic, MqttMessage message) throws Exception { // handle incoming message } @Override public void deliveryComplete(IMqttDeliveryToken token) { // handle message delivery complete } }); } @Override public int onStartCommand(Intent intent, int flags, int startId) { connectToMqttBroker(); return START_STICKY; } private void connectToMqttBroker() { try { mqttAndroidClient.connect(null, new IMqttActionListener() { @Override public void onSuccess(IMqttToken asyncActionToken) { // subscribe to a topic or publish a message } @Override public void onFailure(IMqttToken asyncActionToken, Throwable exception) { // handle failure to connect } }); } catch (Exception e) { e.printStackTrace(); } } @Override public IBinder onBind(Intent intent) { return null; }} 3. 启动服务: Intent serviceIntent = new Intent(this, MqttService.class);startService(serviceIntent); 4. 发布或订阅消息: // To publish a messageString topic = "test/topic";String message = "Hello from Android";try { mqttAndroidClient.publish(topic, message.getBytes(), 0, false);} catch (Exception e) { e.printStackTrace();} // To subscribe to a topicString topic = "test/topic";try { mqttAndroidClient.subscribe(topic, 0);} catch (Exception e) { e.printStackTrace();} 图片传输示例假设你要传输一张图片,可以将图片转换为字节数组并通过MQTT发送。以下是一个简单的例子:ESP32 端接收图片数据:void callback(char* topic, byte* payload, unsigned int length) {// Assuming the payload is the image data in bytesfor (int i = 0; i < length; i++) { Serial.print((char)payload);}Serial.println();} Android 端发送图片数据:Bitmap bitmap = ... // your bitmap imageByteArrayOutputStream baos = new ByteArrayOutputStream();bitmap.compress(Bitmap.CompressFormat.JPEG, 100, baos); // bmp is your Bitmap instancebyte[] bytes = baos.toByteArray();String base64Image = Base64.encodeToString(bytes, Base64.DEFAULT);try { mqttAndroidClient.publish("image/topic", base64Image.getBytes(), 0, false);} catch (Exception e) { e.printStackTrace();} 以上代码展示了如何在ESP32和Android之间通过MQTT进行图片传输的基本方法。根据你的具体需求,你可能需要进一步优化和调整代码。
// send_img_aliyun.ino#include <WiFi.h>
#include <Wire.h>
#include <ArduinoJson.h>
// #include "aliyun_mqtt.h"
#include "aliyunmqtt.h"
#include "esp_camera.h"
#include <SPIFFS.h>
#include "FS.h" // SD Card ESP32
#include "SD_MMC.h" // SD Card ESP32
#include "soc/soc.h" // Disable brownour problems
#include "soc/rtc_cntl_reg.h"// Disable brownour problems
#include "driver/rtc_io.h"
#include <EEPROM.h>
// 内存存储相关配置
#define EEPROM_SIZE 1
int pictureNumber = 0;
String msg;
int buttonState = 0;
int btnHold = 0;
// #define SENSOR_PIN 10
//以下信息需要自己修改
#define WIFI_SSID "TP-LINK_1760"//替换自己的WIFI
#define WIFI_PASSWD "987654321" //替换自己的WIFI密码
// 阿里云物联网 三元组
#define PRODUCT_KEY "k0xxxxxIM" //替换自己的PRODUCT_KEY
#define DEVICE_NAME "esp001_001" //替换自己的DEVICE_NAME
#define DEVICE_SECRET "589xxxxxxxxxxxxxxxxxxxe0f"//替换自己的DEVICE_SECRET \
//以下不需修改
#define ALINK_BODY_FORMAT "{\"id\":\"123\",\"version\":\"1.0\",\"method\":\"%s\",\"params\":%s}"
#define ALINK_TOPIC_PROP_POST "/sys/" PRODUCT_KEY "/" DEVICE_NAME "/thing/event/property/post"
#define ALINK_TOPIC_PROP_POSTRSP "/sys/" PRODUCT_KEY "/" DEVICE_NAME "/thing/event/property/post_reply"
#define ALINK_TOPIC_PROP_SET "/sys/" PRODUCT_KEY "/" DEVICE_NAME "/thing/service/property/set"
#define ALINK_METHOD_PROP_POST "thing.event.property.post"
#define ALINK_TOPIC_DEV_INFO "/ota/device/inform/" PRODUCT_KEY "/" DEVICE_NAME ""
#define ALINK_VERSION_FROMA "{\"id\": 123,\"params\": {\"version\": \"%s\"}}"
unsigned long lastMs = 0;
// 测试 初始温度
int i = 15;
PubSubClient mqttClient(espClient);
//CAMERA_MODEL_AI_THINKER类型摄像头的引脚定义
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
static camera_config_t camera_config = {
.pin_pwdn = PWDN_GPIO_NUM,
.pin_reset = RESET_GPIO_NUM,
.pin_xclk = XCLK_GPIO_NUM,
.pin_sscb_sda = SIOD_GPIO_NUM,
.pin_sscb_scl = SIOC_GPIO_NUM,
.pin_d7 = Y9_GPIO_NUM,
.pin_d6 = Y8_GPIO_NUM,
.pin_d5 = Y7_GPIO_NUM,
.pin_d4 = Y6_GPIO_NUM,
.pin_d3 = Y5_GPIO_NUM,
.pin_d2 = Y4_GPIO_NUM,
.pin_d1 = Y3_GPIO_NUM,
.pin_d0 = Y2_GPIO_NUM,
.pin_vsync = VSYNC_GPIO_NUM,
.pin_href = HREF_GPIO_NUM,
.pin_pclk = PCLK_GPIO_NUM,
.xclk_freq_hz = 20000000,
.ledc_timer = LEDC_TIMER_0,
.ledc_channel = LEDC_CHANNEL_0,
.pixel_format = PIXFORMAT_JPEG,
// .frame_size = FRAMESIZE_VGA,
// FRAMESIZE_UXGA (1600 x 1200)
// FRAMESIZE_QVGA (320 x 240)
// FRAMESIZE_CIF (352 x 288)
// FRAMESIZE_VGA (640 x 480)
// FRAMESIZE_SVGA (800 x 600)
// FRAMESIZE_XGA (1024 x 768)
// FRAMESIZE_SXGA (1280 x 1024)
.frame_size = FRAMESIZE_QVGA,
.jpeg_quality = 10,
// 图像质量(jpeg_quality) 可以是 0 到 63 之间的数字。数字越小意味着质量越高
.fb_count = 1,
void init_wifi(const char *ssid, const char *password) {
WiFi.mode(WIFI_STA);
Serial.println("WiFi does not connect, try again ...");
delay(500);
Serial.println("Wifi is connected.");
void mqtt_callback(char *topic, byte *payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
payload = '\0';
Serial.println((char *)payload);
if (strstr(topic, ALINK_TOPIC_PROP_SET)) {
StaticJsonBuffer<100> jsonBuffer;
JsonObject &root = jsonBuffer.parseObject(payload);
if (!root.success()) {
Serial.println("parseObject() failed");
return;
void mqtt_check_connect() {
while (!mqttClient.connected())//
while (connect_aliyun_mqtt(mqttClient, PRODUCT_KEY, DEVICE_NAME, DEVICE_SECRET)) {
Serial.println("MQTT connect succeed!");
//client.subscribe(ALINK_TOPIC_PROP_POSTRSP);
mqttClient.subscribe(ALINK_TOPIC_PROP_SET);
Serial.println("subscribe done");
void mqtt_interval_post() {
//static int i=0;
char param;
char jsonBuf;
sprintf(jsonBuf, "{\"id\":\"1189401707\",\"version\":\"1.0.0\",\"method\":\"%s\",\"params\":{\"img\":\"END\"}}");
Serial.println(jsonBuf);
mqttClient.publish(ALINK_TOPIC_PROP_POST, jsonBuf);
Serial.println("发送结束符");
delay(1000);
// 摄像头、SD卡与 SPIFFS 初始化
esp_err_t camera_init() {
//initialize the camera
esp_err_t err = esp_camera_init(&camera_config);
if (err != ESP_OK) {
Serial.println("Camera Init Failed");
return err;
sensor_t *s = esp_camera_sensor_get();
//initial sensors are flipped vertically and colors are a bit saturated
if (s->id.PID == OV2640_PID) {
// s->set_vflip(s, 1);//flip it back
// s->set_brightness(s, 1);//up the blightness just a bit
// s->set_contrast(s, 1);
Serial.println("Camera Init OK!");
return ESP_OK;
void sd_init(void) {
//SD card init
if (!SD_MMC.begin()) {
Serial.println("Card Mount Failed");
return;
uint8_t cardType = SD_MMC.cardType();
if (cardType == CARD_NONE) {
Serial.println("No SD_MMC card attached");
return;
void SPIFFS_init() {
//初始化SPIFFS
if (!SPIFFS.begin(true)) {
Serial.println("An Error has occurred while mounting SPIFFS");
} else {
delay(500);
Serial.println("SPIFFS mounted successfully");
//Turn-off the 'brownout detector'
WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
// 摄像头、SD卡与 SPIFFS 初始化 end
void setup() {
Serial.println("程序 Start");
init_wifi(WIFI_SSID, WIFI_PASSWD);
camera_init();
sd_init();
SPIFFS_init();
mqttClient.setCallback(mqtt_callback);
// the loop function runs over and over again forever
void loop() {
// 程序开始拍照并保存
Serial.print("进行拍照\n");
camera_fb_t *fb = esp_camera_fb_get();
if (!fb) {
Serial.print("Camera capture failed");
return;
} else {
EEPROM.begin(EEPROM_SIZE);
pictureNumber = EEPROM.read(0) + 1;
// Path where new picture will be saved in SD Card
String path = "/picture" + String(pictureNumber) + ".jpg";
fs::FS &fs = SD_MMC;
Serial.printf("文件名字: %s\n", path.c_str());
File file = fs.open(path.c_str(), FILE_WRITE);
if (!file) {
Serial.println("Failed to open file in writing mode");
} else {
file.write(fb->buf, fb->len);// payload (image), payload length
Serial.println(fb->len);
Serial.print("抓拍成功并保存\n");
Serial.printf("保存路径: %s\n\n", path.c_str());
EEPROM.write(0, pictureNumber);
EEPROM.commit();
String a1 = "{\"id\":\"1189401707\",\"version\":\"1.0.0\",\"method\":\"123\",\"params\":{\"img\":\"";
String a2;
String a3 = "\"}}";
char data;
// 将图片分为不超过 800 通过 MQTT 发送出去
for (int i = 0; i < fb->len; i++) {
sprintf(data, "%02X", *(fb->buf + i));
a2 += data;
if (a2.length() == 800) {
String a4 = a1 + a2;
String a = a4 + a3;
char jsonBuf;
for (int i = 0; i < a.length(); i++)
jsonBuf = a;
jsonBuf = '\0';
a2 = "", a = "", a4 = "";
// ms
delay(200);
if (a2.length() > 0) {
String a = a4 + a3;
char jsonBuf;
jsonBuf = a;
jsonBuf = '\0';
// 将图片分为不超过 800 通过 MQTT 发送出去end
char endBuf;
sprintf(endBuf, "{\"id\":\"1189401707\",\"version\":\"1.0.0\",\"method\":\"123\",\"params\":{\"img\":\"END\"}}");
Serial.println(endBuf);
mqttClient.publish(ALINK_TOPIC_PROP_POST, endBuf);
Serial.println("图片发送完成了......");
delay(1000);
// 图片发送结束后发送 END
if (millis() - lastMs >= 10000) {
lastMs = millis();
mqtt_check_connect();
// Postinterval 间隔
// mqtt_interval_post();
mqttClient.loop();
unsigned int WAIT_MS = 2000;
delay(WAIT_MS);// ms
Serial.println(millis() / WAIT_MS);
const container = require('rhea');const crypto = require('crypto');
const fs = require("fs");
// 请根据实际情况修改下面的参数
// host,在物联网平台首页,查看开发配置中查看
var YourHost="iot-06z00xxxxt6xc.amqp.iothub.aliyuncs.com"
// 客户端ID,可自定义,长度不可超过64个字符
var YourClientId="esp32_001"
// 账号的 AccessKey。将鼠标移至账号头像上,然后单击AccessKey管理,获取AccessKey ID和AccessKey Secret。
var YourAccessKeyId="LTAI5tXXXXXXXXXXxLEMGYL2"
var YourAccessKeySecret="6vi2Txxxw9xxxrwig"
// 在对应实例的消息转发 > 服务端订阅 > 消费组列表查看您的消费组ID。
var YourConsumerGroupId="DEFAULT_GROUP"
// 物联网平台首页实例 ID
var YourIotInstanceId="iot-0600uxtxxsx"
// 存放完整的图片字符串
var imgStr = ""
// 16进制图片转base64
function to_base64(str) {
var digits = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/";
var base64_rep = "";
var cnt = 0;
var bit_arr = 0;
var bit_num = 0;
for (var n = 0; n < str.length; ++n) {
if (str >= 'A' && str <= 'Z') {
ascv = str.charCodeAt(n) - 55;
else if (str >= 'a' && str <= 'z') {
ascv = str.charCodeAt(n) - 87;
else {
ascv = str.charCodeAt(n) - 48;
bit_arr = (bit_arr << 4) | ascv;
bit_num += 4;
if (bit_num >= 6) {
bit_num -= 6;
base64_rep += digits;
bit_arr &= ~(-1 << bit_num);
if (bit_num > 0) {
bit_arr <<= 6 - bit_num;
var padding = base64_rep.length % 4;
if (padding > 0) {
for (var n = 0; n < 4 - padding; ++n) {
base64_rep += "=";
return base64_rep;
//创建Connection。
var connection = container.connect({
//接入域名,请参见AMQP客户端接入说明文档。
'host': YourHost,
'port': 5671,
'transport':'tls',
'reconnect':true,
'idle_time_out':60000,
//userName组装方法,请参见AMQP客户端接入说明文档。
'username':YourClientId+'|authMode=aksign,signMethod=hmacsha1,timestamp=1573489088171,authId='+YourAccessKeyId+',iotInstanceId='+YourIotInstanceId+',consumerGroupId='+YourConsumerGroupId+'|',
//计算签名,password组装方法,请参见AMQP客户端接入说明文档。
'password': hmacSha1(YourAccessKeySecret, 'authId='+YourAccessKeyId+'×tamp=1573489088171'),
//创建Receiver Link
var receiver = connection.open_receiver();
//接收云端推送消息的回调函数。
container.on('message', function (context) {
var msg = context.message;
var messageId = msg.message_id;
var topic = msg.application_properties.topic;
var content = Buffer.from(msg.body.content).toString();
// 输出内容。
console.log(content);
// 将接收到的mqtt消息中内容转为json
var imgBody = JSON.parse(content).items.img.value
console.log('-------')
// 如果图片没有传输完毕,则拼接图片
if (imgBody != 'END') {
imgStr += imgBody
} else {
// 如果图片传输完毕,则将图片转为base64
console.log('imgStr:')
console.log(to_base64(imgStr))
// 配置图片保存路径
var path = './img/' + new Date().getTime() + '.jpg';
var dataBuffer = new Buffer(to_base64(imgStr), 'base64'); //把base64码转成buffer对象,
//用fs将图片写入本地文件
fs.writeFile(path, dataBuffer, function (err) {
if (err) {
console.log(err);
} else {
console.log('写入成功!');
// 图片转换完毕后,清空imgStr,准备接受下一张图片
imgStr = ""
//发送ACK,注意不要在回调函数有耗时逻辑。
context.delivery.accept();
//计算password签名。
function hmacSha1(key, context) {
return Buffer.from(crypto.createHmac('sha1', key).update(context).digest())
.toString('base64');
https://github.com/xianjimli/esp32cam_mqtt_aliyun_iot.git ESP32和海思芯片比起来,哪个性能或者功能更全面?哪个成本低?
页:
[1]
