请教下HC32F460读SHT30,实在是搞不定了。
HC32F460模拟I2C 读SHT30,实在是搞不定了。那位大佬做过类似的,可以参考下吗?建议你先用Arduino搞通,然后对比时序信号。主要侧重于脉冲周期、ACK/NACK上。 你先试一下你的模拟IIC信号是否对?基本就是时序周期等一类的问题 要不我给你个SHT30的驱动 下边是I2C.c
#include "I2C.h"
#define Delay_Time 2
void I2C_delay_nus(uint16_t time)
uint8_t i=0;
while(time--)
i=1;
while(i--) ;
static void Set_I2C1_SCL(uint8_t a)
if(a!=0)
PHout(5)=1;
else
PHout(5)=0;
static void Set_I2C1_SDA(uint8_t a)
if(a!=0)
PAout(4)=1;
else
PAout(4)=0;
static uint8_t Get_I2C1_SDA(void)
return PAin(4);
static void Set_I2C2_SCL(uint8_t a)
if(a!=0)
PBout(7)=1;
else
PBout(7)=0;
static void Set_I2C2_SDA(uint8_t a)
if(a!=0)
PBout(8)=1;
else
PBout(8)=0;
static uint8_t Get_I2C2_SDA(void)
return PBin(8);
static void Set_I2C3_SCL(uint8_t a)
if(a!=0)
PEout(2)=1;
else
PEout(2)=0;
static void Set_I2C3_SDA(uint8_t a)
if(a!=0)
PEout(3)=1;
else
PEout(3)=0;
static uint8_t Get_I2C3_SDA(void)
return PEin(3);
struct I2C_Device I2C_1=
.Set_SDA = Set_I2C1_SDA,
.Set_SCL = Set_I2C1_SCL,
.Get_SDA = Get_I2C1_SDA,
.delayus = I2C_delay_nus
struct I2C_Device I2C_2=
.Set_SDA = Set_I2C2_SDA,
.Set_SCL = Set_I2C2_SCL,
.Get_SDA = Get_I2C2_SDA,
struct I2C_Device I2C_3=
.Set_SDA = Set_I2C3_SDA,
.Set_SCL = Set_I2C3_SCL,
.Get_SDA = Get_I2C3_SDA,
IIC Driver
void I2C_Start(struct I2C_Device *IIcBus)
IIcBus->Set_SDA(1);
IIcBus->delayus(Delay_Time);
IIcBus->Set_SCL(1);
IIcBus->Set_SDA(0);
IIcBus->Set_SCL(0);
void I2C_Stop(struct I2C_Device *IIcBus)
IIcBus->Set_SDA(0);
IIcBus->Set_SCL(1);
IIcBus->Set_SDA(1);
uint8_t Receive_ACK(struct I2C_Device *IIcBus)
uint32_t i;
IIcBus->Set_SCL(0);//一定把时钟设为低电平再释放总线等待ACK
IIcBus->Set_SDA(1);//释放总线
while(IIcBus->Get_SDA()!=0)
i++;
if(i>10)
return 0;
IIcBus->Set_SCL(1);
IIcBus->Set_SCL(0);
return 1;
void I2C_WriteOneByte(struct I2C_Device *IIcBus,uint8_t Write_Data)
uint8_t i;
uint8_t Data=0;
Data=Write_Data;
for(i=0;i<8;i++)
IIcBus->Set_SDA(Data & 0x80);
IIcBus->Set_SCL(1);
IIcBus->Set_SCL(0);
Data <<= 1;
/**************Send ACK**************/
void I2C_SendACK(struct I2C_Device *IIcBus)
IIcBus->Set_SCL(0);
IIcBus->Set_SDA(0);//发送ACK
IIcBus->Set_SCL(1);//拉高时钟线再拉低时钟线完成一个读周期
IIcBus->Set_SCL(0);//空闲时保证时钟线为低
IIcBus->Set_SDA(1);//发送完ACK后释放总线
void I2C_SendNACK(struct I2C_Device *IIcBus)
IIcBus->Set_SCL(0);
IIcBus->Set_SCL(1);
IIcBus->Set_SCL(0);
uint8_t I2C_ReadOneByte(struct I2C_Device *IIcBus,uint8_t Ack)
uint8_t i;
uint8_t Data=0;
for(i=0;i<8;i++)
Data <<= 1;
IIcBus->Set_SCL(0);
IIcBus->Set_SCL(1);
if(IIcBus->Get_SDA())
Data++;
IIcBus->Set_SCL(0);
if(Ack)
I2C_SendACK(IIcBus);
else
I2C_SendNACK(IIcBus);
return Data;
下边是I2C.h
#ifndef __IIC_H
#define __IIC_H
#include "Header.h"
struct I2C_Device
void (*Set_SDA)(uint8_t a);
void (*Set_SCL)(uint8_t a);
uint8_t (*Get_SDA)(void);
void (*delayus)(uint16_t us);
extern struct I2C_Device I2C_1,I2C_2,I2C_3;
void I2C_delay_nus(uint16_t time);
void I2C_Start(struct I2C_Device *IIcBus);
void I2C_Stop(struct I2C_Device *IIcBus);
uint8_t Receive_ACK(struct I2C_Device *IIcBus);
void I2C_WriteOneByte(struct I2C_Device *IIcBus,uint8_t Write_Data);
void I2C_SendACK(struct I2C_Device *IIcBus);
void I2C_SendNACK(struct I2C_Device *IIcBus);
uint8_t I2C_ReadOneByte(struct I2C_Device *IIcBus,uint8_t Ack);
#endif
下边是SHT3x.c
#include "Sht3x.h"
struct sht3xObj sht31_1 =
.HardWare = &I2C_1
struct sht3xObj sht31_2 =
.HardWare = &I2C_2
static uint8_t sht31_mode_set(struct sht3xObj *PARA, uint8_t mode_h,uint8_t mode_l)
I2C_Start(PARA->HardWare);
I2C_WriteOneByte(PARA->HardWare,SHT31_RHT_W);
if(Receive_ACK(PARA->HardWare)!=1)
return 0;
I2C_WriteOneByte(PARA->HardWare,Mode_Set_H);
return 0;
I2C_WriteOneByte(PARA->HardWare,Mode_Set_L);
return 0;
I2C_Stop(PARA->HardWare);
return 1;
uint8_t soft_reset_sensor(struct sht3xObj *PARA)
return 0;
I2C_WriteOneByte(PARA->HardWare,RESET_SET_H);
return 0;
I2C_WriteOneByte(PARA->HardWare,RESET_SET_L);
return 0;
return 1;
uint8_t StartReadRHTemperature(struct sht3xObj *PARA)
return 0;
I2C_WriteOneByte(PARA->HardWare,0xE0);
return 0;
I2C_WriteOneByte(PARA->HardWare,0x00);
return 0;
return 1;
uint8_t sht31ReadRHTemperature(struct sht3xObj *PARA)
uint8_t T_Data_MSB, T_Data_LSB, RH_Data_MSB, RH_Data_LSB;
uint8_t CRC8_1, CRC8_2;
uint16_tdata_t, data_rh;
I2C_WriteOneByte(PARA->HardWare,SHT31_RHT_R);
return 0;
T_Data_MSB = I2C_ReadOneByte(PARA->HardWare,ACK);
T_Data_LSB = I2C_ReadOneByte(PARA->HardWare,ACK);
CRC8_1 = I2C_ReadOneByte(PARA->HardWare,ACK);
RH_Data_MSB = I2C_ReadOneByte(PARA->HardWare,ACK);
RH_Data_LSB = I2C_ReadOneByte(PARA->HardWare,ACK);
CRC8_2 = I2C_ReadOneByte(PARA->HardWare,NACK);
data_rh = (RH_Data_MSB<<8)|(RH_Data_LSB);
PARA->Humidty = 100*((float)data_rh/65535);
data_t = (T_Data_MSB<<8)|(T_Data_LSB);
PARA->Temperture = -45 + 175*((float)data_t/65535);
return 1;
void sht31_thread(struct sht3xObj *PARA)
switch(PARA->RH_Status)
case 0:
if(CheckDelay(&PARA->Delay_Time)==0)
if(sht31_mode_set(PARA,Mode_Set_H,Mode_Set_L) != 0)
PARA->RH_Status++;
else
Set_Delay_Time(1500,&PARA->Delay_Time);
}break;
case 1://启动温湿度检测
if(StartReadRHTemperature(PARA)!=0)
Set_Delay_Time(1000,&PARA->Delay_Time);
PARA->RH_Read_Time = 0;
PARA->RH_Status++;
else
PARA->RH_Read_Time++;
Set_Delay_Time(100,&PARA->Delay_Time);
if(PARA->RH_Read_Time > 5)
PARA->RH_Status = 0;
}break;
case 2:
if(sht31ReadRHTemperature(PARA) != 0)
PARA->RH_Status = 1;
else
}break;
default:
}break;
下边是sht3x.h
#ifndef __SHT3X__H__
#define __SHT3X__H__
#include "I2C.h"
#include "Header.h"
#include "Delay.h"
#define ACK 1
#define NACK 0
#define SHT31_RHT_W 0X88
#define SHT31_RHT_R 0X89
//#define SHT31_RHT_W 0X8C
//#define SHT31_RHT_R 0X8D
//MODE COMMAND
#define Mode_Set_H 0x21
#define Mode_Set_L 0x2D
//SOFTRESET COMMAND
#define RESET_SET_H 0x30
#define RESET_SET_L 0xA2
struct sht3xObj
uint16_t Delay_Time;//别忘了需要被DelayTimeCount_ms
struct I2C_Device *HardWare;
uint16_t adc_t;
uint16_t adc_rh;
float Temperture;
float Humidty;
uint8_t Status;
uint8_t RH_Status;
uint8_t RH_Read_Time;
extern struct sht3xObj sht31_1,sht31_2;
void sht31_thread(struct sht3xObj *PARA);
#endif
下边是用到的延时函数
void DelayTimeCount_ms(uint16_t *DelayTime_Count)
if(*DelayTime_Count==0)
*DelayTime_Count=0;
else
*DelayTime_Count-=1;
void Set_Delay_Time(uint16_t Time,uint16_t *DelayTime_Count)
*DelayTime_Count=Time;
uint8_t CheckDelay(uint16_t *DelayTime_Count)
return 0;
else
return 1;
下边是函数调用
#include "TaskMgr.h"
uint8_t Sys_Status=0;
uint16_t Item_OverTime_Count=0;
uint16_t TimeTick_Count=0;
uint8_t Task_1ms_EN=0,Task_2ms_EN=0,Task_5ms_EN=0,Task_10ms_EN=0,Task_20ms_EN=0,Task_50ms_EN=0,Task_100ms_EN=0,Task_500ms_EN=0,Task_1000ms_EN=0,Task_5000ms_EN=0;
uint8_t TCL=0;
static void SysTimeTikeCounting(void)
TCL = 1;
if(TimeTick_Count>60000)
TimeTick_Count=1;
else
TimeTick_Count++;
static void Task_1ms(void)
TimeCountReceive(&U_D_Uart1);
DelayTimeCount_ms(&MS8607_Para_1.PT_Thread_Time);
DelayTimeCount_ms(&MS8607_Para_2.PT_Thread_Time);
DelayTimeCount_ms(&RS485BusSilentTime1);
DelayTimeCount_ms(&MMDPort1.DelayTime);
DelayTimeCount_ms(&PTQ3040.DelayTime);
DelayTimeCount_ms(&sht31_1.Delay_Time);
DelayTimeCount_ms(&sht31_2.Delay_Time);
SmiTimeCount();
static void Task_2ms(void)
static void Task_5ms(void)
static void Task_10ms(void)
static void Task_20ms(void)
static void Task_50ms(void)
ReadEleSensorInformationWhenBooting();
static void Task_100ms(void)
static void Task_500ms(void)
static void Task_1000ms(void)
GetDS18B20Data(&DS18B20_1);
//GetDS18B20Data(&DS18B20_2);
//GetDS18B20Data(&DS18B20_3);
//GetDS18B20Data(&DS18B20_4);
ReadEleSensorValueEnable();
ReadLSPMValueEnable();
ReadWSEnable();
ReadWDEnable();
PTQModeSetEnable();
PTQReadEnable();
static void Task_5000ms(void)
static void TaskPolls(void)
if(TCL)
TCL = 0;
if((TimeTick_Count%1)==0)
Task_1ms_EN=1;
if((TimeTick_Count%2)==0)
Task_2ms_EN=1;
if((TimeTick_Count%5)==0)
Task_5ms_EN=1;
if((TimeTick_Count%10)==0)
Task_10ms_EN=1;
if((TimeTick_Count%20)==0)
Task_20ms_EN=1;
if((TimeTick_Count%50)==0)
Task_50ms_EN=1;
if((TimeTick_Count%100)==0)
Task_100ms_EN=1;
if((TimeTick_Count%500)==0)
Task_500ms_EN=1;
if((TimeTick_Count%1000)==0)
Task_1000ms_EN=1;
if((TimeTick_Count%5000)==0)
Task_5000ms_EN=1;
if(Task_1ms_EN)
Task_1ms_EN=0;
Task_1ms();
if(Task_2ms_EN)
Task_2ms_EN=0;
Task_2ms();
if(Task_5ms_EN)
Task_5ms_EN=0;
Task_5ms();
if(Task_10ms_EN)
Task_10ms_EN=0;
Task_10ms();
if(Task_20ms_EN)
Task_20ms_EN=0;
Task_20ms();
if(Task_50ms_EN)
Task_50ms_EN=0;
Task_50ms();
if(Task_100ms_EN)
Task_100ms_EN=0;
Task_100ms();
if(Task_500ms_EN)
Task_500ms_EN=0;
Task_500ms();
if(Task_1000ms_EN)
Task_1000ms_EN=0;
Task_1000ms();
if(Task_5000ms_EN)
Task_5000ms_EN=0;
Task_5000ms();
void Sys_INIT(void)
//MX_GPIO_Init();
//MX_TIM1_Init();
//MX_TIM2_Init();
//MX_TIM3_Init();
//MX_USART1_UART_Init();
UartDebugInit();
HAL_TIM_PWM_Start(&htim2,TIM_CHANNEL_1);
PTQModeSetEnable();
void SYSTICK_Callback(void)
SysTimeTikeCounting();
void SystemRun(void)
TaskPolls();
//FlowControl(&FlowDust);
MS8607_PT_Thread(&MS8607_Para_1);
sht31_thread(&sht31_1);
MS8607_PT_Thread(&MS8607_Para_2);
sht31_thread(&sht31_2);
//SmiRuning(&SM9541_1);
RS485Device1Handle();
qinlu123 发表于 2024-11-19 16:01
下边是I2C.c
#include "I2C.h"
感谢,今天排查后解决了。确实是时序还有SDA转换成输入时的问题。 模拟IIC的SDA做输入输出切换时,在有些芯片里会产生问题,要注意切换时的逻辑顺序。用示波器会看到切换时的一个高电平跳变。所以把IO先置0再切换就好了。 可以直接用 rtt,这样就不用自己写驱动了 将SHT30传感器通过适当的接口(如I2C或SPI)连接到HC32F460的相应引脚。确保连接正确无误,包括电源、地线、时钟线(SCL或SDA)和数据线(SDA或SCL)。
配置微控制器,根据HC32F460的数据手册配置相应的硬件接口模块(如I2C或SPI模块),以正确与传感器通信。这可能包括设置时钟频率、从地址、波特率等参数。
通过相应的通信协议向SHT30发送初始化命令,使其准备好接收指令并发送数据。这通常涉及设置传感器的测量模式(如连续模式或单次测量模式)、输出数据速率等。
使用HC32F460的通信接口发送读取命令到SHT30传感器,以获取温度和湿度数据。具体的读取命令和格式取决于传感器的数据手册。通常,你需要按照传感器的指令集发送特定的命令序列,然后接收传感器返回的数据。
从传感器接收到的数据可能是原始的,需要进行适当的转换和处理才能得到实际的温度和湿度值。根据SHT30的数据手册,你可能需要解析返回的数据格式,并进行必要的计算以得到最终的温湿度值。
具体的实现细节取决于你的硬件连接、微控制器的配置以及传感器的数据手册。
建议详细阅读HC32F460和SHT30的数据手册,并根据其中的指导进行开发。
网上有很多关于模拟I2C控制SHT30的例子的,你调整一下时序也就是delay应该就可以了
确实你说的IO配置成输入这个问题,之前我还遇到过IO需要先打开复用时钟的
其实一般来说模拟I2C不如硬件I2C来的快而且硬件I2C还比较好调试
页:
[1]
