vivilyly 发表于 2024-11-30 21:49
AD8032的滤波算法
AD8032的滤波算法并提供软件截图
gaochy1126 发表于 2024-11-30 21:51
AD8032的滤波算法
/data/attachment/album/202411/30/215112k7unofj7wfu9sfsj.jpeg
#include "FIRfilterPtByPt.h"
* \brief   Function used for initialization FIR filter structure used for filtering
* \param   signalBufferLength    Length of cyclic buffer storing signal
* \param   signalCyclicBuffer[]   Cyclic buffer storing signal
* \param   coeffLength            Number of filter coefficients
* \param   coefficients[]            Filter coefficients
* \return      FIRfilterObject          FIR filter structure
FIRfilterObject CreateFIRfilterObject(uint16_t signalBufferLength, float signalCyclicBuffer[], uint16_t coeffLength, float coefficients[])
                FIRfilterObject _FIRfilterObject;
                _FIRfilterObject.coefficients = &coefficients;
                _FIRfilterObject.coefficientsLength = coeffLength;
                _FIRfilterObject.signalBuffer = &signalCyclicBuffer;
                _FIRfilterObject.signalBufferHead = 0;
                _FIRfilterObject.signalBufferLength = signalBufferLength;
                _FIRfilterObject.signalBufferMask = signalBufferLength - 1;
        //======= Zero out signalBuffer values=======//
                uint16_t i;
                uint16_t counterBy8 = _FIRfilterObject.signalBufferLength >> 3;//Division by 8
                uint16_t remainder = _FIRfilterObject.signalBufferLength - ((_FIRfilterObject.signalBufferLength >> 3) << 3);// % 8
                float* signalBufferPtr = &_FIRfilterObject.signalBuffer;
                for(i=0; i<counterBy8; i++)
                                *signalBufferPtr++ = 0.0f;
                for(i=0; i<remainder; i++)
                return _FIRfilterObject;
* \brief   Function filtering input signal point-by-point
* \param   filterObject    Pointer to FIR filter structure
* \param   signal         One sample of input signal
* \param   result            Result of filtering
void FIRfilterPtByPt(FIRfilterObject* filterObject, float signal, float* result)
    *result = 0;
    filterObject->signalBuffer = signal;
    float* coefficientsPtr;
    coefficientsPtr        = &filterObject->coefficients;
    float* signalPtr;
    signalPtr        = &filterObject->signalBuffer;
    int16_t i;
    int16_t counterBy8;
    int16_t remainder;
                if( filterObject->signalBufferHead >=filterObject->coefficientsLength)
      counterBy8 = filterObject->coefficientsLength >> 3;   //filterObject->coefficientsLength / 8
      remainder = filterObject->coefficientsLength - ((filterObject->coefficientsLength >> 3) << 3);// filterObject->coefficientsLength % 8
                                                *result += *signalPtr-- * *coefficientsPtr++;
                else
      counterBy8 = filterObject->signalBufferHead >> 3;//filterObject->signalBufferHead / 8
      remainder = filterObject->signalBufferHead - ((filterObject->signalBufferHead >> 3) << 3);// filterObject->signalBufferHead % 8
      *result += filterObject->signalBuffer * *coefficientsPtr++;
      counterBy8 = filterObject->coefficientsLength - filterObject->signalBufferHead - 1;
      remainder = counterBy8 - ((counterBy8 >> 3) << 3);// counterBy8 % 8
      counterBy8 = counterBy8 >> 3;//counterBy8 / 8
    filterObject->signalBufferHead = (filterObject->signalBufferHead + 1) & filterObject->signalBufferMask;
#include "IIRfilterPtByPt.h"
* \brief   Function used for initialization IIR 2nd order filter structure used for filtering
* \param   forwardCoeff            Filter forward coefficients
* \param   reverseCoeff            Filter reverse coefficients
* \return      IIR2ndOrderFilterObj    IIR 2nd order filter structure
IIR2ndOrderFilterObj IIR_2ndOrderSignalFilteringPtByPtInitialize(float forwardCoeff, float reverseCoeff)
    IIR2ndOrderFilterObjIIR2ndOrderFilterObj_;
    IIR2ndOrderFilterObj_.forwardCoeff = forwardCoeff;
    IIR2ndOrderFilterObj_.reverseCoeff = reverseCoeff;
    return IIR2ndOrderFilterObj_;
* \brief   Function used for initialization IIR 3rd order filter structure used for filtering
* \return      IIR3rdOrderFilterObj   IIR 3rd order filter structure
IIR3rdOrderFilterObj IIR_3rdOrderSignalFilteringPtByPtInitialize(float forwardCoeff, float reverseCoeff)
    IIR3rdOrderFilterObjIIR3rdOrderFilterObj_;
    IIR3rdOrderFilterObj_.forwardCoeff = forwardCoeff;
    IIR3rdOrderFilterObj_.reverseCoeff = reverseCoeff;
    return IIR3rdOrderFilterObj_;
* \brief   Function used for initialization IIR 4th order filter structure used for filtering
* \return      IIR4thOrderFilterObj   IIR 4th order filter structure
IIR4thOrderFilterObj IIR_4thOrderSignalFilteringPtByPtInitialize(float forwardCoeff, float reverseCoeff)
    IIR4thOrderFilterObjIIR4thOrderFilterObj_;
    IIR4thOrderFilterObj_.forwardCoeff = forwardCoeff;
    IIR4thOrderFilterObj_.reverseCoeff = reverseCoeff;
    return IIR4thOrderFilterObj_;
* \brief   Function for recursive Infinite Impulse Response 2nd order filtering of input signal point-by-point
* \warning This IIR filter implemantation can be used only when first reverse coefficient value == 1
* \paramfilterObject       Pointer to structure of 2nd order IIR filter
* \paramsignal               Input signal last sample
* \param result            Output filtered signal sample
void IIR_2ndOrderSignalFilteringPtByPt(IIR2ndOrderFilterObj* filterObject, float signal, float* result)
                static float as;
                filterObject->stateBuffer += signal * filterObject->forwardCoeff;
                as = -filterObject->stateBuffer;
                filterObject->stateBuffer += as * filterObject->reverseCoeff;
                *result = filterObject->stateBuffer;
                filterObject->stateBuffer = filterObject->stateBuffer;
    filterObject->stateBuffer = 0;
* \brief   Function for recursive Infinite Impulse Response 3rd order filtering of input signal point-by-point
* \paramfilterObject       Pointer to structure of 3rd order IIR filter
void IIR_3rdOrderSignalFilteringPtByPt(IIR3rdOrderFilterObj* filterObject, float signal, float* result)
                static float as;
* \brief   Function for recursive Infinite Impulse Response 4th order filtering of input signal point-by-point
* \paramfilterObject       Pointer to structure of 4th order IIR filter
void IIR_4thOrderSignalFilteringPtByPt(IIR4thOrderFilterObj* filterObject, float signal, float* result)
                static float as;
页: [1]
查看完整版本: AD8032的滤波算法
