laojun001 发表于 2025-2-26 10:42
test09_v.py
from math import log
from scipy.constants import Boltzmann, physical_constants
T = 300# TEMPERATURE (unit = K)
def builtin_voltage(
    donor_conc: float,# donor concentration
    acceptor_conc: float,# acceptor concentration
    intrinsic_conc: float,# intrinsic concentration
) -> float:
    This function can calculate the Builtin Voltage of a pn junction diode.
    This is calculated from the given three values.
    Examples -
    >>> builtin_voltage(donor_conc=1e17, acceptor_conc=1e17, intrinsic_conc=1e10)
    0.833370010652644
    >>> builtin_voltage(donor_conc=0, acceptor_conc=1600, intrinsic_conc=200)
    Traceback (most recent call last):
    ValueError: Donor concentration should be positive
    >>> builtin_voltage(donor_conc=1000, acceptor_conc=0, intrinsic_conc=1200)
    ValueError: Acceptor concentration should be positive
    >>> builtin_voltage(donor_conc=1000, acceptor_conc=1000, intrinsic_conc=0)
    ValueError: Intrinsic concentration should be positive
    >>> builtin_voltage(donor_conc=1000, acceptor_conc=3000, intrinsic_conc=2000)
    ValueError: Donor concentration should be greater than intrinsic concentration
    >>> builtin_voltage(donor_conc=3000, acceptor_conc=1000, intrinsic_conc=2000)
    ValueError: Acceptor concentration should be greater than intrinsic concentration
    if donor_conc <= 0:
      raise ValueError("Donor concentration should be positive")
    elif acceptor_conc <= 0:
      raise ValueError("Acceptor concentration should be positive")
    elif intrinsic_conc <= 0:
      raise ValueError("Intrinsic concentration should be positive")
    elif donor_conc <= intrinsic_conc:
      raise ValueError(
            "Donor concentration should be greater than intrinsic concentration"
    elif acceptor_conc <= intrinsic_conc:
      raise ValueError(
            "Acceptor concentration should be greater than intrinsic concentration"
    else:
      return (
            Boltzmann
            * T
            * log((donor_conc * acceptor_conc) / intrinsic_conc**2)
            / physical_constants["electron volt"]
if __name__ == "__main__":
    import doctest
    doctest.testmod()
魔法森林精灵 发表于 2025-4-3 17:11
不知道这个公式是从哪里来的,有没有相关的物理背景知识可以参考
页: [1]
查看完整版本: test09_v.py
