laojun001 发表于 2025-2-27 21:06
test_lib.s
* (C) Copyright 2005
* Wolfgang Denk, DENX Software Engineering, wd@denx.de.
* SPDX-License-Identifier:      GPL-2.0+
#include <config.h>
#include <ppc_asm.tmpl>
#include <ppc_defs.h>
#include <asm/cache.h>
#include <asm/mmu.h>
#include "test_burst.h"
      .text
*      void mmu_init(void);
*      This function turns the MMU on
*      Three 8 MByte regions are mapped 1:1, uncached
*      - SDRAM lower 8 MByte
*      - SDRAM higher 8 MByte
*      - IMMR
      .global mmu_init
mmu_init:
      tlbia                        /* Invalidate all TLB entries */
      li      r8, 0
      mtspr      MI_CTR, r8      /* Set instruction control to zero */
      lis      r8, MD_RESETVAL@h
      mtspr      MD_CTR, r8      /* Set data TLB control */
      /* Now map the lower 8 Meg into the TLBs.For this quick hack,
         * we can load the instruction and data TLB registers with the
         * same values.
      li      r8, MI_EVALID                /* Create EPN for address 0 */
      mtspr      MI_EPN, r8
      mtspr      MD_EPN, r8
      li      r8, MI_PS8MEG                /* Set 8M byte page */
      ori      r8, r8, MI_SVALID      /* Make it valid */
      mtspr      MI_TWC, r8
      mtspr      MD_TWC, r8
      li      r8, MI_BOOTINIT|0x2      /* Create RPN for address 0 */
      mtspr      MI_RPN, r8                /* Store TLB entry */
      mtspr      MD_RPN, r8
      lis      r8, MI_Kp@h                /* Set the protection mode */
      mtspr      MI_AP, r8
      mtspr      MD_AP, r8
      /* Now map the higher 8 Meg into the TLBs.For this quick hack,
         * same values.
      lwz      r9,20(r2)                /* gd->ram_size */
      addis      r9,r9,-0x80
      mr      r8, r9                        /* Higher 8 Meg in SDRAM */
      ori      r8, r8, MI_EVALID      /* Mark page valid */
      mtspr      MI_EPN, r8
      mtspr      MD_EPN, r8
      mtspr      MI_TWC, r8
      mtspr      MD_TWC, r8
      mr      r8, r9
      ori      r8, r8, MI_BOOTINIT|0x2
      mtspr      MD_RPN, r8
      mtspr      MI_AP, r8
      mtspr      MD_AP, r8
      /* Map another 8 MByte at the IMMR to get the processor
         * internal registers (among other things).
      mfspr      r9, 638                        /* Get current IMMR */
      andis.      r9, r9, 0xff80                /* Get 8Mbyte boundary */
      mr      r8, r9                        /* Create vaddr for TLB */
      ori      r8, r8, MD_EVALID      /* Mark it valid */
      mtspr      MD_EPN, r8
      li      r8, MD_PS8MEG                /* Set 8M byte page */
      ori      r8, r8, MD_SVALID      /* Make it valid */
      mtspr      MD_TWC, r8
      mr      r8, r9                        /* Create paddr for TLB */
      ori      r8, r8, MI_BOOTINIT|0x2 /* Inhibit cache -- Cort */
      mtspr      MD_RPN, r8
      /* We now have the lower and higher 8 Meg mapped into TLB entries,
         * and the caches ready to work.
      mfmsr      r0
      ori      r0,r0,MSR_DR|MSR_IR
      mtspr      SRR1,r0
      mflr      r0
      mtspr      SRR0,r0
      SYNC
      rfi      /* enables MMU */
*      void caches_init(void);
      .globl      caches_init
caches_init:
      sync
      mfspr      r3, IC_CST                /* Clear error bits */
      mfspr      r3, DC_CST
      lis      r3, IDC_UNALL@h                /* Unlock all */
      mtspr      IC_CST, r3
      mtspr      DC_CST, r3
      lis      r3, IDC_INVALL@h      /* Invalidate all */
      mtspr      IC_CST, r3
      mtspr      DC_CST, r3
      lis      r3, IDC_ENABLE@h      /* Enable all */
      mtspr      IC_CST, r3
      mtspr      DC_CST, r3
      blr
*      void flush_dcache_range(unsigned long start, unsigned long stop);
      .global flush_dcache_range
flush_dcache_range:
      li      r5,CACHE_LINE_SIZE-1
      andc      r3,r3,r5
      subf      r4,r3,r4
      add      r4,r4,r5
      srwi.      r4,r4,LG_CACHE_LINE_SIZE
      beqlr
      mtctr      r4
1:      dcbf      0,r3
      addi      r3,r3,CACHE_LINE_SIZE
      bdnz      1b
      sync                              /* wait for dcbf's to get to ram */
      blr
*      void disable_interrupts(void);
      .global disable_interrupts
disable_interrupts:
      mfmsr      r0
      rlwinm      r0,r0,0,17,15
      mtmsr      r0
      blr
页: [1]
查看完整版本: test_lib.s
