cashrwood 发表于 2025-3-22 14:57
环形缓存区ring_buffer
#include <stdlib.h>
#include <string.h>
#include "ring_buffer.h"
* Private types/enumerations/variables
#define RB_INDH(rb)                ((rb)->head & ((rb)->count - 1))
#define RB_INDT(rb)                ((rb)->tail & ((rb)->count - 1))
#if !defined(MAX)
#define MAX(a, b) (((a) > (b)) ? (a) : (b))
#endif
#if !defined(MIN)
#define MIN(a, b) (((a) < (b)) ? (a) : (b))
#endif
* Public types/enumerations/variables
* Private functions
* Public functions
* @brief      Resets the ring buffer to empty
* @param      RingBuff      : Pointer to ring buffer
* @return      Nothing
void RingBuffer_Flush(RINGBUFF_T *RingBuff)
    RingBuff->head = RingBuff->tail = 0;
* @brief      Return size the ring buffer
* @return      Size of the ring buffer in bytes
int RingBuffer_GetSize(RINGBUFF_T *RingBuff)
    return RingBuff->count;
* @brief      Return number of items in the ring buffer
* @return      Number of items in the ring buffer
static int RingBuffer_GetCount(RINGBUFF_T *RingBuff)
    return RB_VHEAD(RingBuff) - RB_VTAIL(RingBuff);
* @brief      Return number of free items in the ring buffer
* @return      Number of free items in the ring buffer
static int RingBuffer_GetFree(RINGBUFF_T *RingBuff)
    return RingBuff->count - RingBuffer_GetCount(RingBuff);
* @return      1 if the ring buffer is full, otherwise 0
int RingBuffer_IsFull(RINGBUFF_T *RingBuff)
    return (RingBuffer_GetCount(RingBuff) >= RingBuff->count);
* @brief      Return empty status of ring buffer
* @return      1 if the ring buffer is empty, otherwise 0
int RingBuffer_IsEmpty(RINGBUFF_T *RingBuff)
    return RB_VHEAD(RingBuff) == RB_VTAIL(RingBuff);
/* Initialize ring buffer */
int RingBuffer_Init(RINGBUFF_T *RingBuff, void *buffer, int itemSize, int count)
    RingBuff->data = buffer;
    RingBuff->count = count;
    RingBuff->itemSz = itemSize;
    return 1;
/* Insert a single item into Ring Buffer */
int RingBuffer_Insert(RINGBUFF_T *RingBuff, const void *data)
    u8 *ptr = RingBuff->data;
    /* We cannot insert when queue is full */
    if (RingBuffer_IsFull(RingBuff))
      return 0;
    ptr += RB_INDH(RingBuff) * RingBuff->itemSz;
    memcpy(ptr, data, RingBuff->itemSz);
    RingBuff->head++;
    return 1;
/* Insert multiple items into Ring Buffer */
int RingBuffer_InsertMult(RINGBUFF_T *RingBuff, const void *data, int num)
    int cnt1, cnt2;
      return 0;
    /* Calculate the segment lengths */
    cnt1 = cnt2 = RingBuffer_GetFree(RingBuff);
    if (RB_INDH(RingBuff) + cnt1 >= RingBuff->count)
      cnt1 = RingBuff->count - RB_INDH(RingBuff);
    cnt2 -= cnt1;
    cnt1 = MIN(cnt1, num);
    num -= cnt1;
    cnt2 = MIN(cnt2, num);
    num -= cnt2;
    /* Write segment 1 */
    memcpy(ptr, data, cnt1 * RingBuff->itemSz);
    RingBuff->head += cnt1;
    /* Write segment 2 */
    ptr = (u8 *) RingBuff->data + RB_INDH(RingBuff) * RingBuff->itemSz;
    data = (const u8 *) data + cnt1 * RingBuff->itemSz;
    memcpy(ptr, data, cnt2 * RingBuff->itemSz);
    RingBuff->head += cnt2;
    return cnt1 + cnt2;
/* Pop single item from Ring Buffer */
int RingBuffer_Pop(RINGBUFF_T *RingBuff, void *data)
    /* We cannot pop when queue is empty */
    if (RingBuffer_IsEmpty(RingBuff))
      return 0;
    ptr += RB_INDT(RingBuff) * RingBuff->itemSz;
    memcpy(data, ptr, RingBuff->itemSz);
    RingBuff->tail++;
    return 1;
/* Pop multiple items from Ring buffer */
int RingBuffer_PopMult(RINGBUFF_T *RingBuff, void *data, int num)
    int cnt1, cnt2;
    /* We cannot insert when queue is empty */
      return 0;
    cnt1 = cnt2 = RingBuffer_GetCount(RingBuff);
    if (RB_INDT(RingBuff) + cnt1 >= RingBuff->count)
      cnt1 = RingBuff->count - RB_INDT(RingBuff);
    cnt2 -= cnt1;
    num -= cnt1;
    num -= cnt2;
    memcpy(data, ptr, cnt1 * RingBuff->itemSz);
    RingBuff->tail += cnt1;
    ptr = (u8 *) RingBuff->data + RB_INDT(RingBuff) * RingBuff->itemSz;
    data = (u8 *) data + cnt1 * RingBuff->itemSz;
    memcpy(data, ptr, cnt2 * RingBuff->itemSz);
    RingBuff->tail += cnt2;
    return cnt1 + cnt2;
lidi911 发表于 2025-3-23 19:41
和FIFO buffer相比有什么区别。
lxs0026 发表于 2025-3-31 12:41
它的首尾相连,当缓冲区满时,新数据会覆盖旧数据。
Amazingxixixi 发表于 2025-4-24 15:52
学习一下啊!感觉有点知识慌了
页: [1]
查看完整版本: 环形缓存区ring_buffer
