18078550376 发表于 2025-3-24 18:11
HC32F460的内部高速时钟问题
使用内部高速时钟HRC作为PPL时钟然后倍频再分频至200MHZ作为系统时钟,在使用定时器验证时一直对不上,使用外部晶振配置又是正常的。都是基于例程在测试而且Debug查看SystemCoreClock以及相关寄存器的配置也没发现哪里有问题Z:\Share\HC1
18078550376 发表于 2025-3-24 18:12
void CLK_Init(void)
    stc_clk_sysclk_cfg_t    stcSysClkCfg;
    stc_clk_xtal_cfg_t      stcXtalCfg;
    stc_clk_mpll_cfg_t      stcMpllCfg;
    stc_sram_config_t       stcSramConfig;
    MEM_ZERO_STRUCT(stcSysClkCfg);
    MEM_ZERO_STRUCT(stcXtalCfg);
    MEM_ZERO_STRUCT(stcMpllCfg);
    MEM_ZERO_STRUCT(stcSramConfig);
    /* Set bus clk div. */
    stcSysClkCfg.enHclkDiv= ClkSysclkDiv1;
    stcSysClkCfg.enExclkDiv = ClkSysclkDiv2;
    stcSysClkCfg.enPclk0Div = ClkSysclkDiv1;
    stcSysClkCfg.enPclk1Div = ClkSysclkDiv2;
    stcSysClkCfg.enPclk2Div = ClkSysclkDiv4;
    stcSysClkCfg.enPclk3Div = ClkSysclkDiv4;
    stcSysClkCfg.enPclk4Div = ClkSysclkDiv2;
    CLK_SysClkConfig(&stcSysClkCfg);
                CLK_HrcCmd(Enable);
//    while(Set != CLK_GetFlagStatus(ClkFlagHRCRdy))
    /* sram init include read/write wait cycle setting */
    stcSramConfig.u8SramIdx = Sram12Idx | Sram3Idx | SramHsIdx | SramRetIdx;
    stcSramConfig.enSramRC = SramCycle2;
    stcSramConfig.enSramWC = SramCycle2;
    SRAM_Init(&stcSramConfig);
    /* flash read wait cycle setting */
    EFM_Unlock();
    EFM_SetLatency(EFM_LATENCY_5);
    EFM_Lock();
    /* MPLL config (XTAL / pllmDiv * plln / PllpDiv = 200M). */
    stcMpllCfg.pllmDiv = 2ul;
    stcMpllCfg.plln    = 40ul;
    stcMpllCfg.PllpDiv = 2ul;
    stcMpllCfg.PllqDiv = 2ul;
    stcMpllCfg.PllrDiv = 2ul;
    CLK_SetPllSource(ClkPllSrcHRC);
    CLK_MpllConfig(&stcMpllCfg);
    /* Enable MPLL. */
    CLK_MpllCmd(Enable);
    /* Wait MPLL ready. */
    while(Set != CLK_GetFlagStatus(ClkFlagMPLLRdy))
    /* Switch driver ability */
    PWC_HS2HP();
    /* Switch system clock source to MPLL. */
    CLK_SetSysClkSource(CLKSysSrcMPLL);
18078550376 发表于 2025-3-26 13:53
问题解决了,淘宝上买的最小系统配的芯片可能是假的;另外买了芯片换上去就好了
wang6623 发表于 2025-3-31 13:42
如果你要倍频到200MHz,需要合理配置PLL倍频器。
Amazingxixixi 发表于 2025-4-24 15:50
学习一下啊!感觉有点知识慌了
页: [1]
查看完整版本: HC32F460的内部高速时钟问题
