狂奔的蜗牛JJ 发表于 2025-5-4 16:08
GD32F527 ADC DMA双缓冲存储
我进行adc电压电流采样,想用双缓冲进行配置,目前adc_buffer0 里面数据实时更新,但是进不去中断,把初始化的DMA_INT_FLAG_FTF改成DMA_INT_FLAG_HTF 又可以进入中断了。这是为什么?
#define BUFFER_SIZE   512
#define ADC_CHANNEL_CNT 3
#define DMA_BUFFER_SIZE   (ADC_CHANNEL_CNT * BUFFER_SIZE)
void User_ADC_Init(void)
    /* ADC mode config */
    adc_sync_mode_config(ADC_SYNC_MODE_INDEPENDENT);
    /* ADC contineous function disable */
    adc_special_function_config(ADC0, ADC_CONTINUOUS_MODE, ENABLE);
    /* ADC scan mode disable */
    adc_special_function_config(ADC0, ADC_SCAN_MODE, ENABLE);
    /* ADC data alignment config */
    adc_data_alignment_config(ADC0, ADC_DATAALIGN_RIGHT);
    /* ADC channel length config */
    adc_channel_length_config(ADC0, ADC_ROUTINE_CHANNEL, 3);
    /* ADC regular channel config */
    adc_routine_channel_config(ADC0, 0, ADC_CHANNEL_13, ADC_SAMPLETIME_15);/* 电流采样 */
    adc_routine_channel_config(ADC0, 1, ADC_CHANNEL_11, ADC_SAMPLETIME_15);/* 电压采样 */
    adc_routine_channel_config(ADC0, 2, ADC_CHANNEL_12, ADC_SAMPLETIME_15);/* 参考电压1.65V采样 */
    /* ADC trigger config */
    adc_external_trigger_source_config(ADC0, ADC_ROUTINE_CHANNEL, ADC_EXTTRIG_ROUTINE_T0_CH0); ////////ADC_EXTTRIG_ROUTINE_T0_CH0
    adc_external_trigger_config(ADC0, ADC_ROUTINE_CHANNEL, EXTERNAL_TRIGGER_DISABLE);///////
    /* ADC DMA function enable */
    adc_dma_request_after_last_enable(ADC0);
    adc_dma_mode_enable(ADC0);
    /* enable ADC interface */
    adc_enable(ADC0);
    /* wait for ADC stability */
    delay1ms(2);
    /* ADC calibration and reset calibration */
    adc_calibration_enable(ADC0);
    /* enable ADC software trigger */
    adc_software_trigger_enable(ADC0, ADC_ROUTINE_CHANNEL);
uint16_t adc_buffer0;
uint16_t adc_buffer1;
void User_DMA_Init(void)
    dma_single_data_parameter_struct dma_init_struct;
        dma_deinit(DMA1, DMA_CH0);
    dma_init_struct.periph_addr= (uint32_t)&ADC_RDATA(ADC0);
    dma_init_struct.periph_inc   = DMA_PERIPH_INCREASE_DISABLE;
    dma_init_struct.memory0_addr = (uint32_t)&adc_buffer0;
    dma_init_struct.memory_inc   = DMA_MEMORY_INCREASE_ENABLE;
    dma_init_struct.periph_memory_width = DMA_PERIPH_WIDTH_16BIT;
    dma_init_struct.direction = DMA_PERIPH_TO_MEMORY;
    dma_init_struct.number = ADC_CHANNEL_CNT * BUFFER_SIZE;
    dma_init_struct.priority = DMA_PRIORITY_ULTRA_HIGH;
    dma_single_data_mode_init(DMA1, DMA_CH0, &dma_init_struct);
    dma_channel_subperipheral_select(DMA1, DMA_CH0, DMA_SUBPERI0);
    /* 启用双缓冲 */
        dma_memory_address_config(DMA1, DMA_CH0, (uint32_t)&adc_buffer1, DMA_MEMORY_1);
        dma_switch_buffer_mode_enable(DMA1, DMA_CH0, ENABLE);
    dma_circulation_disable(DMA1, DMA_CH0);
    dma_channel_enable(DMA1, DMA_CH0);
    /* 开启DMA传输完成中断 */
    dma_interrupt_enable(DMA1, DMA_CH0, DMA_INT_FLAG_FTF);
    nvic_irq_enable(DMA1_Channel0_IRQn, 1, 0);
void DMA1_Channel0_IRQHandler(void)
    if (dma_interrupt_flag_get(DMA1, DMA_CH0, DMA_INT_FLAG_FTF)==SET) {
      dma_interrupt_flag_clear(DMA1, DMA_CH0, DMA_INT_FLAG_FTF);
      dma_current_buffer = (dma_current_buffer == 0) ? 1 : 0;
      buffer_ready_flag = 1;
classroom 发表于 2025-5-9 12:54
DMA传输配置问题或者是中断处理逻辑问题
flycamelaaa 发表于 2025-5-9 18:00
选择正确的中断标志。
kepe 发表于 2025-5-31 01:52
你调用了 dma_circulation_disable(DMA1, DMA_CH0); 禁用了循环模式,导致DMA只传输一次,且双缓冲工作方式不正常,可能也影响中断触发。
页: [1]
查看完整版本: GD32F527 ADC DMA双缓冲存储
