地瓜patch 发表于 2025-5-15 22:15
调用了两个同名文件,出现错误了
LOAD ERROR: WindowsPath('G:/STCL562F429N6570/STM32N6570DK/stm32ai-modelzoo-services-main/object_detection/src/experiments_outputs/2025_05_15_22_09_56/network.h') and WindowsPath('G:/STCL562F429N6570/STM32N6570DK/stm32ai-modelzoo-services-main/object_detection/src/experiments_outputs/2025_05_15_22_09_56/network.h') are the same file
Error executing job with overrides: []
Traceback (most recent call last):
File "C:\Users\Administrator\AppData\Local\Programs\Python\Python38\lib\site-packages\clearml\binding\hydra_bind.py", line 230, in _patched_task_function
    return task_function(a_config, *a_args, **a_kwargs)
File "stm32ai_main.py", line 228, in main
    process_mode(cfg)
File "stm32ai_main.py", line 102, in process_mode
    deploy(cfg)
File "../deployment\deploy.py", line 111, in deploy
    stm32ai_deploy_stm32n6(target=board, stlink_serial_number=stlink_serial_number, stm32ai_version=stm32ai_version, c_project_path=c_project_path,
File "../../common/deployment\common_deploy.py", line 469, in stm32ai_deploy_stm32n6
    stmaic_local_call(session)
File "../../common/deployment\common_deploy.py", line 443, in stmaic_local_call
    stmaic.compile(session=session, options=opt, target=session._board_config)
File "../../common\stm32ai_local\compile.py", line 208, in cmd_compile
    raise Exception('Error during compilation')
Exception: Error during compilation
Set the environment variable HYDRA_FULL_ERROR=1 for a complete stack trace.
调用了两个同名文件。文件路径重复加载,尝试两次加载同一个 network.h 文件,错误发生在 stm32ai_deploy_stm32n6 部署阶段。Exception: Error during compilation
页: [1]
查看完整版本: 调用了两个同名文件,出现错误了
