Nuvoton NSP2.0 高品质语音提示方案
NSP2.0系列芯片是性价比极高的产品, 产品规格齐全,工规的品质,极简的外围器件和简易的上位机工具,可以极大的缩短开发时间和减小开发成本。NSP2.0是一个内嵌Flash之万能语音合成播放芯片, 具有高音质NSP算法。NSP2.0提供硬件的I2C、UART和固件单线、双线接口与主机MCU通信,并支持在线升级(ISP)功能,以高数据传输率来更新语音内容。还具备有一组高分辨率的PWM语音输出可以直推0.5W喇叭,适合应用于各种语音提示应用。此外,NSP2xxxA01G 系列支持高达1.0 瓦(@5.5V)放大器直接驱动扬声器,适用于所有语音辅助应用。一、型号规格https://edit.wpgdadawant.com/uploads/news_file/program/2024/38231/tinymce/1.jpg
二、内核架构
https://edit.wpgdadawant.com/uploads/news_file/program/2024/38231/tinymce/3.jpg
三、设计原理图
I2C Interface
https://edit.wpgdadawant.com/uploads/news_file/program/2024/38231/tinymce/4.jpgUART Interface
https://edit.wpgdadawant.com/uploads/news_file/program/2024/38231/tinymce/5.jpg
Two-Wire Interface
https://edit.wpgdadawant.com/uploads/news_file/program/2024/38231/tinymce/6.jpg
One-Wire Interface
https://edit.wpgdadawant.com/uploads/news_file/program/2024/38231/tinymce/7.jpg
如音量不够,可以外接功放,无需低通滤波电路
https://edit.wpgdadawant.com/uploads/news_file/program/2024/38231/tinymce/7-1.jpg
https://edit.wpgdadawant.com/uploads/news_file/program/2024/38231/tinymce/7-2.jpg
四、上位机PlayList Tool操作说明
1、打开PlayList Tool,新建工程并设定参数
https://edit.wpgdadawant.com/uploads/news_file/program/2024/38231/tinymce/8-0.jpg2、导入音频文件,并新增播放索引
https://edit.wpgdadawant.com/uploads/news_file/program/2024/38231/tinymce/9.jpg3、编译和烧录
https://edit.wpgdadawant.com/uploads/news_file/program/2024/38231/tinymce/10-0.jpg4、打开此路径下的驱动包
https://edit.wpgdadawant.com/uploads/news_file/program/2024/38231/tinymce/11.jpg
5、移植到工程上,并执行播放指令https://edit.wpgdadawant.com/uploads/news_file/program/2024/38231/tinymce/12.jpg
确实是的,Nuvoton NSP2.0 是内嵌 Flash 的语音合成播放芯片,有高音质算法,支持多种接口,可直推喇叭,能在线升级 NSP2.0系列是一款集成了 Flash 存储器的高性能语音合成播放芯片,专为嵌入式语音应用设计,具有高性价比、高品质和易开发等优点。
页:
[1]
