改进后,节点和代码框架。
基于修正后的架构,我们需要实现以下ROS 2节点及其代码框架:### 节点规划及代码框架
#### 1. **视觉处理节点 (vision\_processor\_node)**
**python**
#!/usr/bin/env python3
import rclpy
from rclpy.node import Node
from sensor_msgs.msg import Image
from vision_msgs.msg import Detection2DArray
from cv_bridge import CvBridge
import cv2
class VisionProcessor(Node):
def __init__(self):
super().__init__('vision_processor')
# ROS 2接口
self.image_sub = self.create_subscription(
Image, '/camera/image', self.image_callback, 10)
self.detection_pub = self.create_publisher(
Detection2DArray, '/object/detections', 10)
# OpenCV工具
self.bridge = CvBridge()
self.detector = self.init_detector()# 初始化OpenCV检测器
def init_detector(self):
"""初始化视觉检测模型"""
# 实际实现使用OpenCV DNN或自定义模型
return None
def image_callback(self, msg):
"""处理图像并发布检测结果"""
try:
cv_image = self.bridge.imgmsg_to_cv2(msg, 'bgr8')
detections = self.process_image(cv_image)
# 转换为ROS消息
detection_msg = self.create_detection_msg(detections)
self.detection_pub.publish(detection_msg)
except Exception as e:
self.get_logger().error(f'Image processing error: {str(e)}')
def process_image(self, cv_image):
"""使用OpenCV处理图像并返回检测结果"""
# 实际实现包含目标检测算法
return []
def create_detection_msg(self, detections):
"""将检测结果转换为ROS消息"""
# 实际实现填充Detection2DArray
return Detection2DArray()
if __name__ == '__main__':
rclpy.init()
node = VisionProcessor()
rclpy.spin(node)
rclpy.shutdown()
#### 2. **任务规划节点 (task\_planner\_node)**
**python**
import rclpy
from task_msgs.msg import TaskSequence
from control_msgs.msg import SystemStatus
from std_msgs.msg import String
class TaskPlanner(Node):
def __init__(self):
super().__init__('task_planner')
# ROS 2接口
self.detection_sub = self.create_subscription(
Detection2DArray, '/object/detections', self.detection_callback, 10)
self.status_sub = self.create_subscription(
SystemStatus, '/system/status', self.status_callback, 10)
self.task_pub = self.create_publisher(
TaskSequence, '/task/sequence', 10)
self.ui_sub = self.create_subscription(
String, '/ui/params', self.ui_callback, 10)
# 任务状态机
self.current_task = None
self.task_queue = []
def detection_callback(self, msg):
"""根据视觉检测结果生成任务"""
if not self.task_queue:
self.generate_tasks(msg)
def generate_tasks(self, detections):
"""基于检测结果生成任务序列"""
# 实际实现包含任务规划算法
task_sequence = TaskSequence()
# ... 填充任务序列
self.task_pub.publish(task_sequence)
def status_callback(self, msg):
"""监控系统状态并调整任务"""
if msg.error_flag:
self.handle_error(msg)
def ui_callback(self, msg):
"""处理UI配置更新"""
# 解析UI参数并更新任务配置
self.get_logger().info(f'UI config updated: {msg.data}')
rclpy.init()
node = TaskPlanner()
rclpy.spin(node)
rclpy.shutdown()
#### 3. **路径规划节点 (path\_planner\_node)**
**python**
import rclpy
from nav_msgs.msg import OccupancyGrid, Path
from visualization_msgs.msg import MarkerArray
from std_msgs.msg import Bool
import numpy as np
class PathPlanner(Node):
def __init__(self):
super().__init__('path_planner')
# ROS 2接口
self.task_sub = self.create_subscription(
TaskSequence, '/task/sequence', self.task_callback, 10)
self.map_sub = self.create_subscription(
OccupancyGrid, '/obstacle/map', self.map_callback, 10)
self.collision_sub = self.create_subscription(
Bool, '/collision/alerts', self.collision_callback, 10)
self.path_pub = self.create_publisher(
Path, '/path/planned', 10)
self.visualization_pub = self.create_publisher(
MarkerArray, '/path/visualization', 10)
# 路径规划状态
self.current_map = None
self.timer = self.create_timer(0.1, self.planning_loop)# 10Hz
def task_callback(self, msg):
"""存储当前任务序列"""
self.current_task = msg
def map_callback(self, msg):
"""更新障碍物地图"""
self.current_map = msg
def collision_callback(self, msg):
"""处理碰撞警报触发重规划"""
if msg.data and self.current_task:
self.get_logger().warn('Collision detected! Replanning...')
self.generate_path(self.current_task, self.current_map)
def planning_loop(self):
"""主规划循环"""
if self.current_task and self.current_map:
def generate_path(self, task, map):
"""生成优化路径 (A*/RRT*)"""
# 实际实现包含路径规划算法
path = Path()
# ... 填充路径
# 发布路径
self.path_pub.publish(path)
# 生成可视化标记
markers = self.create_visualization(path)
self.visualization_pub.publish(markers)
rclpy.init()
node = PathPlanner()
rclpy.spin(node)
rclpy.shutdown()
#### 4. **导航避障节点 (navigation\_obstacle\_node)**
**python**
import rclpy
from sensor_msgs.msg import PointCloud2
from geometry_msgs.msg import PoseStamped
import numpy as np
class NavigationObstacle(Node):
def __init__(self):
super().__init__('navigation_obstacle')
# ROS 2接口
self.pose_sub = self.create_subscription(
PoseStamped, '/sensor/pose', self.pose_callback, 10)
self.pointcloud_sub = self.create_subscription(
PointCloud2, '/sensor/pointcloud', self.pointcloud_callback, 10)
self.map_pub = self.create_publisher(
OccupancyGrid, '/obstacle/map', 10)
self.collision_pub = self.create_publisher(
Bool, '/collision/alerts', 10)
# 避障参数
self.safety_distance = 0.5# 安全距离(m)
self.map_resolution = 0.05# 地图分辨率(m/cell)
def pose_callback(self, msg):
"""更新当前位姿"""
self.current_pose = msg
def pointcloud_callback(self, msg):
"""处理点云数据生成障碍地图"""
if hasattr(self, 'current_pose'):
obstacle_map = self.generate_occupancy_grid(msg)
self.map_pub.publish(obstacle_map)
# 检查碰撞风险
collision_risk = self.check_collision(obstacle_map)
alert = Bool(data=collision_risk)
self.collision_pub.publish(alert)
def generate_occupancy_grid(self, pointcloud):
"""从点云生成占据栅格地图"""
# 实际实现包含点云处理算法
return OccupancyGrid()
def check_collision(self, map):
"""检查碰撞风险"""
# 实际实现包含安全距离检查
return False
rclpy.init()
node = NavigationObstacle()
rclpy.spin(node)
rclpy.shutdown()
#### 5. **运动控制节点 (motion\_controller\_node)**
**python**
import rclpy
from nav_msgs.msg import Path
from geometry_msgs.msg import Twist
from sensor_msgs.msg import JointState
class MotionController(Node):
def __init__(self):
super().__init__('motion_controller')
# ROS 2接口
self.path_sub = self.create_subscription(
Path, '/path/planned', self.path_callback, 10)
self.cmd_pub = self.create_publisher(
Twist, '/cmd_vel', 10)
self.joint_pub = self.create_publisher(
JointState, '/joint_states', 10)
self.status_pub = self.create_publisher(
SystemStatus, '/system/status', 10)
# 控制参数
self.control_rate = 100# Hz
self.timer = self.create_timer(1/self.control_rate, self.control_loop)
self.current_path = None
def path_callback(self, msg):
"""存储当前路径"""
self.current_path = msg
def control_loop(self):
"""主控制循环"""
if self.current_path:
# 生成控制指令
cmd_vel = self.generate_control_command()
self.cmd_pub.publish(cmd_vel)
# 发布关节状态
joint_state = self.get_joint_states()
self.joint_pub.publish(joint_state)
# 发布系统状态
status = SystemStatus()
# ... 填充状态信息
self.status_pub.publish(status)
def generate_control_command(self):
"""根据路径生成控制指令"""
# 实际实现包含轨迹跟踪算法
return Twist()
def get_joint_states(self):
"""获取当前关节状态"""
# 实际实现从硬件读取
return JointState()
rclpy.init()
node = MotionController()
rclpy.spin(node)
rclpy.shutdown()
#### 6. **Qt UI节点 (qt\_ui\_node)**
**python**
import rclpy
from PyQt6.QtWidgets import QApplication, QMainWindow
import sys
class QtUINode(Node):
def __init__(self):
super().__init__('qt_ui_node')
# ROS 2接口
self.ui_pub = self.create_publisher(
String, '/ui/params', 10)
self.marker_sub = self.create_subscription(
MarkerArray, '/path/visualization', self.marker_callback, 10)
# Qt UI
self.app = QApplication(sys.argv)
self.window = MainWindow(self)
self.window.show()
"""更新UI中的图像显示"""
self.window.update_image(msg)
def marker_callback(self, msg):
"""更新UI中的路径可视化"""
self.window.update_path_visualization(msg)
def run(self):
"""启动Qt应用"""
sys.exit(self.app.exec())
class MainWindow(QMainWindow):
def __init__(self, ros_node):
super().__init__()
self.ros_node = ros_node
# 初始化UI组件
self.init_ui()
def init_ui(self):
"""初始化用户界面"""
# 实际实现包含Qt UI布局
self.setWindowTitle("ROS 2 Visual Control System")
self.setGeometry(100, 100, 1200, 800)
def update_image(self, image_msg):
"""更新图像显示"""
# 实际实现将ROS图像转换为Qt图像
def update_path_visualization(self, markers):
"""更新路径可视化"""
# 实际实现处理可视化标记
def on_config_changed(self):
"""处理UI配置变更"""
config = String(data="current config")
self.ros_node.ui_pub.publish(config)
rclpy.init()
node = QtUINode()
# 在独立线程中运行ROS
from threading import Thread
spin_thread = Thread(target=rclpy.spin, args=(node,))
spin_thread.start()
# 运行Qt主循环
node.run()
rclpy.shutdown()
### 自定义消息类型
需要在 `task_msgs`包中定义自定义消息:
**`TaskSequence.msg`**
Header header
TaskGoal[] goals
**`TaskGoal.msg`**
string goal_id
geometry_msgs/Pose target_pose
string action_type# e.g., "PICK", "PLACE", "MOVE"
### 系统部署说明
1. **依赖安装**:
sudo apt install ros-jazzy-vision-msgs ros-jazzy-nav-msgs
2. **构建和运行**:
colcon build --packages-select vision_processor task_planner path_planner navigation_obstacle motion_controller qt_ui
source install/setup.bash
ros2 launch visual_control_system system.launch.py
3. **性能优化**:
* 路径规划节点使用C++实现以提高实时性
* 关键控制回路使用实时Linux内核
* 视觉处理使用GPU加速
### 系统架构图更新
!(data/attachment/forum/202506/18/125043wsp1fgvvsusvhgrg.png "deepseek_mermaid_20250618_40f937.png")
该实现方案提供了完整的视觉-运动控制系统,满足实时控制要求(运动控制100Hz,路径规划10Hz,任务规划1-5Hz),并通过Qt UI实现人机交互。
页:
[1]
