【灵动微电子MM32F0121测评】3.PWM呼吸灯
本帖最后由 阿源玩电子 于 2025-6-24 21:44 编辑PWM呼吸灯
[*]原理图部分
2.引脚复用,使用TIM1的1,2通道用于调光,PB14和PB15复用为AF7功能。
3.定时器配置频率计算:
[*]预分频值计算为(TIM_ClockFrequency / 1000000) - 1,使计数器时钟为1MHz
[*]设置ARR值为999(1000-1),得到精确的1kHz PWM频率
占空比范围:
[*]通过设置ARR=999,CCR值范围0-999对应0%-100%占空比
[*]使用TIM_SetCompare1(TIM1, value),TIM_SetCompare2(TIM1, value)设置占空比,value范围0-999
[*]pwm_dsp.c
#include "pwm_dsp.h"
void TIM1_PWM_Configure(void)
RCC_ClocksTypeDef RCC_Clocks;
GPIO_InitTypeDef GPIO_InitStruct;
TIM_OCInitTypeDef TIM_OCInitStruct;
TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStruct;
uint32_t TIM_ClockFrequency = 0;
uint32_t HPRE = 0, PPRE2 = 0;
// PWM参数配置
uint32_t PWM_Frequency = 1000; // 1kHz PWM频率
uint16_t PWM_Period = 1000; // 周期值(ARR),占空比范围0-1000
uint16_t PrescalerValue = 0; // 预分频值
// 1. 获取时钟频率
HPRE= READ_BIT(RCC->CFGR, RCC_CFGR_HPRE)>> RCC_CFGR_HPRE_Pos;
PPRE2 = READ_BIT(RCC->CFGR, RCC_CFGR_PPRE2) >> RCC_CFGR_PPRE2_Pos;
RCC_GetClocksFreq(&RCC_Clocks);
// 计算TIM1时钟频率
if (HPRE < 8) {
TIM_ClockFrequency = (PPRE2 < 4) ? RCC_Clocks.PCLK2_Frequency : RCC_Clocks.PCLK2_Frequency * 2;
} else {
TIM_ClockFrequency = (PPRE2 < 4) ? RCC_Clocks.PCLK2_Frequency * 2 : RCC_Clocks.PCLK2_Frequency * 4;
// 2. 计算预分频值 (目标计数器时钟 = 1MHz)
PrescalerValue = (uint16_t)(TIM_ClockFrequency / 1000000) - 1;
// 3. 初始化TIM1定时器
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
TIM_TimeBaseStructInit(&TIM_TimeBaseInitStruct);
TIM_TimeBaseInitStruct.TIM_Prescaler = PrescalerValue;// 设置预分频
TIM_TimeBaseInitStruct.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInitStruct.TIM_Period = PWM_Period - 1; // ARR值 (1000-1)
TIM_TimeBaseInitStruct.TIM_ClockDivision = TIM_CKD_Div1;
TIM_TimeBaseInitStruct.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseInitStruct);
// 4. 配置PWM模式 (初始占空比0%)
TIM_OCStructInit(&TIM_OCInitStruct);
TIM_OCInitStruct.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStruct.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStruct.TIM_Pulse = 0; // 初始CCR值(占空比)
TIM_OCInitStruct.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OCInitStruct.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OC1Init(TIM1, &TIM_OCInitStruct);// 配置通道1
TIM_OC2Init(TIM1, &TIM_OCInitStruct);// 配置通道2
// 启用预装载寄存器
TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM1, ENABLE);
// 5. 配置GPIO为PWM输出
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource14, GPIO_AF_7);// TIM1_CH1
GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_7);// TIM1_CH2
GPIO_StructInit(&GPIO_InitStruct);
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_14 | GPIO_Pin_15;
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStruct.GPIO_Speed = GPIO_Speed_High;
GPIO_Init(GPIOB, &GPIO_InitStruct);
// 6. 使能TIM1和PWM输出
TIM_Cmd(TIM1, ENABLE);
TIM_CtrlPWMOutputs(TIM1, ENABLE);
[*]pwm_dsp.h#include "hal_conf.h"
void TIM1_PWM_Configure(void);
4.试验现象PB14(TIM1_CH1) 和 PB15(TIM1_CH2)将输出1kHz 的 PWM 信号,并可动态调整占空比(0%~100%),将占空比由0变化到1000,再由1000变换到0,由此作为呼吸效果
从硬件配置到软件编程,每个步骤都有详细的说明,这对于初学者来说非常有帮助。 可以学习如何配置MCU的定时器和GPIO 灵动微电子MM32F0121是一款基于ARM Cortex-M0内核的32位微控制器(MCU),具有高集成度和便捷开发体验的特点。 PWM呼吸灯实验是一个实用的项目 频率和占空比的调节方法。 深入浅出地解释了PWM的工作原理以及如何通过调整占空比来实现亮度变化。 定时器的初始化、GPIO的配置、PWM输出的设置 一篇非常有价值的测评文章,适合对灵动微电子MM32F0121微控制器和PWM技术 动态占空比调整的代码片段直接可行,降低了学习门槛。 对PWM原理、定时器工作模式等理论部分描述较少,可能对完全零基础的读者不够友好 步骤描述是否详尽,对于初学者来说是否足够友好。 除了呼吸灯外是否还能启发其他创意项目
页:
[1]
