比神乐 发表于 2025-7-21 18:33
飞思卡尔单片机驱动HT1621
代码:
#include <hidef.h>      /* common defines and macros */
#include "derivative.h"      /* derivative-specific definitions */
#define LED PORTB
#define LED_dir DDRB
#define uchar unsigned char
#define uint unsigned int
#define DA_1PORTB |= 0X10//RS置1
#define DA_0PORTB &= 0XEF//RS置0
#define WR_1PORTB |= 0X04//RS置1
#define WR_0PORTB &= 0XFB//RS置0
#define CS_1PORTB |= 0X01//RS置1
#define CS_0PORTB &= 0XFE//RS置0
unsigned char data=0x01;
#define Smg_a 0x80
#define Smg_b 0x40
#define Smg_c 0x20
#define Smg_d 0x01
#define Smg_e 0x02
#define Smg_f 0x08
#define Smg_g 0x04
#define Smg_dp 0x10
#define Bmp0Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
#define Bmp1Map Smg_b | Smg_c
#define Bmp2Map Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
#define Bmp3Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
#define Bmp4Map Smg_b | Smg_c | Smg_f | Smg_g
#define Bmp5Map Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp6Map Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp8Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp9Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp7Map Smg_a | Smg_b | Smg_c
#define BmpAMap Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
#define BmpBMap Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpCMap Smg_a | Smg_d | Smg_e | Smg_f
#define BmpDMap Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
#define BmpEMap Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpFMap Smg_a | Smg_e | Smg_f | Smg_g
const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
unsigned char DpyNum = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //?????
unsigned int i;
void COMMAND_HT1621(unsigned char comm)
//unsigned char i;
CS_0;
WR_0;
for(i=0;i<3;i++)//???
if((0x04<<i)&0x04)
                                                   DA_1; //100
else
                                    DA_0;
WR_0;
WR_1;
for(i=0;i<9;i++)//?????
    if((comm<<i)&0x80) DA_1; //100
    else DA_0;
    WR_0;
    WR_1;
CS_1;
void HT1621_Display(void)
//unsigned char i;
CS_0;//??CS
WR_0;
for(i=0;i<3;i++) //???
    if((0x05<<i)&0x04) DA_1;
    else DA_0;
    WR_0;
    WR_1;
for(i=0;i<6;i++) //???
    if((20<<i)&0x20) DA_1;//20?? SEG??
    else DA_0;
    WR_0;
    WR_1;
for(i=0;i<8;i++) //???
    if((DpyNum<<i)&0x80)
                                                   DA_1;
    else DA_0;
    WR_0;
    WR_1;
if((DpyNum<<i)&0x80)DA_1;
else DA_0;
WR_0;
WR_1;
if((DpyNum<<i)&0x80) DA_1;
else DA_0;
WR_0;
WR_1;
else DA_0;
WR_0;
WR_1;
else DA_0;
WR_0;
WR_1;
else DA_0;
WR_0;
WR_1;
CS_1;
void LCD_Init(void)
COMMAND_HT1621(0x01);//SYS EN
COMMAND_HT1621(0x03);//LCD ON
COMMAND_HT1621(0x29);//4 COM牋1/3 BIAS
HT1621_Display(); //clear screen
/*                        延时函数                           */
void delay(void)
unsigned int i,j;
for(j=0;j<2;j++)
for(i=0;i<60000;i++)
/*                        主函数                           */
void main(void) {
        //DisableInterrupts;
// LED_dir=0xff;       //设置为输出
// LED=~data;          //点亮LED1
//        EnableInterrupts;
    DDRB=0XFF;
    delay();
   LCD_Init();
DpyNum = Smg_a|Smg_d|Smg_g;//"?"
DpyNum = SegCode;
DpyNum = SegCode;
DpyNum = SegCode;
DpyNum = SegCode;
DpyNum = SegCode;
HT1621_Display();
for(;;)
效果图:
附件喘不上来
页: [1]
查看完整版本: 飞思卡尔单片机驱动HT1621
