[应用方案]
矩阵键盘代码
92|0
chenci2013|  楼主 | 2024-11-22 22:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#define uchar unsigned char
#define uint unsigned int
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={ 0x3f,0x06,0x5b,0x4f,
                     0x66,0x6d,0x7d,0x07,
                0x7f,0x6f,0x77,0x7c,
                0x39,0x5e,0x79,0x71};
void delayms(uint xms)
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
void display(uchar num)
  P0=table[num];
dula=1;
//P0=table[num];
dula=0;
//delayms(500);
void matrixkeyscan()
uchar temp,key;
P3=0xfe;
temp=P3;
temp=temp&0xf0;
if(temp != 0xf0)
  delayms(10);
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
   temp=P3;
   switch(temp)
    case 0xee: key=0;
               break;
    case 0xde: key=1;
               break;
    case 0xbe: key=2;
               break;
    case 0x7e: key=3;
               break;
   while(temp!=0xf0)
    temp=P3;
    temp=temp&0xf0;
   display(key);
P3=0xfd;
temp=P3;
temp=temp&0xf0;
if(temp != 0xf0)
  delayms(10);
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
   temp=P3;
   switch(temp)
    case 0xed: key=4;
               break;
    case 0xdd: key=5;
               break;
    case 0xbd: key=6;
               break;
    case 0x7d: key=7;
               break;
   while(temp!=0xf0)
    temp=P3;
    temp=temp&0xf0;
   display(key);
P3=0xfb;
temp=P3;
temp=temp&0xf0;
if(temp != 0xf0)
  delayms(10);
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
   temp=P3;
   switch(temp)
    case 0xeb: key=8;
               break;
    case 0xdb: key=9;
               break;
    case 0xbb: key=10;
               break;
    case 0x7b: key=11;
               break;
   while(temp!=0xf0)
    temp=P3;
    temp=temp&0xf0;
   display(key);
P3=0xf7;
temp=P3;
temp=temp&0xf0;
if(temp != 0xf0)
  delayms(10);
  temp=P3;
  temp=temp&0xf0;
  if(temp!=0xf0)
   temp=P3;
   switch(temp)
    case 0xe7: key=12;
               break;
    case 0xd7: key=13;
               break;
    case 0xb7: key=14;
               break;
    case 0x77: key=15;
               break;
   while(temp!=0xf0)
    temp=P3;
    temp=temp&0xf0;
   display(key);
void main()
P0=0;
dula=1;
dula=0;
P0=0xc0;
wela=1;
//P0=0xc0;
wela=0;
while(1)
  matrixkeyscan();
