我爱你的吻123的个人空间 https://passport2.21ic.com/?1046966 [收藏] [复制] [RSS]
日志
TSM320F2812 烧写到Flash中的configuration
已有 999 次阅读2015-10-31 11:24 |个人分类:DSP|系统分类:DSP| Flash
        首先从网上查阅的资料,都说比较困难。实着对我这样的业余2812人员一个大大的下马威啊。没有办法,饭只有一口一口的吃。摸索下来,发现也不是很困难的事情啊(也许在下是夜郎自大,没有遇到稀奇古怪的case)。
          place-lower device只是实现了很简单的功能,
           1,eCan, 采用了poll transmit AND interrupt receipt,
           2,SCI -b,同样采用轮训发送,中断的接收;
           3,ADC ,只采样了三路,做了很基本的Float到Hexadecimal 的转换
          ADC采样数据发送到eCan interface,pc端只有一个eCan <<==>>USB的adapter《==》virual COM。没有软件,没有开发库(由于我们前期只是把功能实现了),连用多少Baud,数据位,停止位是什么都不知道,费劲吧;在这上面,确实花费我不少的功夫,读出USB的original 数据啊,查找其rule(都是凑出来的),然后解码成原始发送的数据,丢到VC的GUI中显示波形。
        ok,言归正传,先修改cmd文件,我的cmd文件如下 MYF2812.cmd(CMD文件的格式,讲的地方很多,google一下吧)
MEMORY
PAGE 0:    /* Program Memory */
           /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE1 for data allocation */
   RAML0       : origin = 0x008000, length = 0x001000     /*L0 SRAM 4K */
   OTP         : origin = 0x3D7800, length = 0x000800     /* on-chip OTP */
   FLASHJ      : origin = 0x3D8000, length = 0x002000     /* on-chip FLASH */
   FLASHI      : origin = 0x3DA000, length = 0x002000     /* on-chip FLASH */
   FLASHH      : origin = 0x3DC000, length = 0x004000     /* on-chip FLASH */
   FLASHG      : origin = 0x3E0000, length = 0x004000     /* on-chip FLASH */
   FLASHF      : origin = 0x3E4000, length = 0x004000     /* on-chip FLASH */
   FLASHE      : origin = 0x3E8000, length = 0x004000     /* on-chip FLASH */
   FLASHD      : origin = 0x3EC000, length = 0x004000     /* on-chip FLASH */
   FLASHC      : origin = 0x3F0000, length = 0x004000     /* on-chip FLASH */
   FLASHA      : origin = 0x3F6000, length = 0x001F80     /* on-chip FLASH */
   CSM_RSVD    : origin = 0x3F7F80, length = 0x000076     /* Part of FLASHA.  Program with all 0x0000 when CSM is in use. */
   BEGIN       : origin = 0x3F7FF6, length = 0x000002     /* Part of FLASHA.  Used for "boot to Flash" bootloader mode. */
   ROM         : origin = 0x3FF000, length = 0x000FC0     /* 引导区的ROM available if MP/MCn=0 */
   RESET       : origin = 0x3FFFC0, length = 0x000002     /* 复位地址BROM矢量 ROM (MP/MCn=0) or XINTF zone 7 (MP/MCn=1) */
   VECTORS     : origin = 0x3FFFC2, length = 0x00003E     /*BROM矢量 ROM (MP/MCn=0) or XINTF zone 7 (MP/MCn=1) */
PAGE 1 :   /* Data Memory */
           /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE0 for program allocation */
           /* Registers remain on PAGE1                                                  */
   RAMM0       : origin = 0x000000, length = 0x000400     /* 低地址 数据空间 M0 SRAM */
   RAMM1       : origin = 0x000400, length = 0x000400     /* 低地址 数据空间 M1 SRAM */
   RAML1       : origin = 0x009000, length = 0x001000     /* 低地址 数据空间 L1 SRAM */
   FLASHB      : origin = 0x3F4000, length = 0x002000     /* on-chip FLASH */
   RAMH0       : origin = 0x3F8000, length = 0x002000     /* 高地址 H0 8K空间*/
  /* Peripheral Frame 0:   */
   DEV_EMU    : origin = 0x000880, length = 0x000180
   FLASH_REGS : origin = 0x000A80, length = 0x000060
   CSM        : origin = 0x000AE0, length = 0x000010
   XINTF      : origin = 0x000B20, length = 0x000020
   CPU_TIMER0 : origin = 0x000C00, length = 0x000008
   CPU_TIMER1 : origin = 0x000C08, length = 0x000008
   CPU_TIMER2 : origin = 0x000C10, length = 0x000008
   PIE_CTRL   : origin = 0x000CE0, length = 0x000020
   PIE_VECT   : origin = 0x000D00, length = 0x000100
   /* Peripheral Frame 1:   */
   ECANA       : origin = 0x006000, length = 0x000040     /* eCAN control and status registers */
   ECANA_LAM   : origin = 0x006040, length = 0x000040     /* eCAN local acceptance masks */
   ECANA_MOTS  : origin = 0x006080, length = 0x000040     /* eCAN message object time stamps */
   ECANA_MOTO  : origin = 0x0060C0, length = 0x000040     /* eCAN object time-out registers */
   ECANA_MBOX  : origin = 0x006100, length = 0x000100     /* eCAN mailboxes */
   /* Peripheral Frame 2:   */
   SYSTEM     : origin = 0x007010, length = 0x000020
   SPI_A      : origin = 0x007040, length = 0x000010
   SCI_A      : origin = 0x007050, length = 0x000010
   XINTRUPT   : origin = 0x007070, length = 0x000010
   GPIOMUX    : origin = 0x0070C0, length = 0x000020
   GPIODAT    : origin = 0x0070E0, length = 0x000020
   ADC        : origin = 0x007100, length = 0x000020
   EV_A       : origin = 0x007400, length = 0x000040
   EV_B       : origin = 0x007500, length = 0x000040
   SPI_B      : origin = 0x007740, length = 0x000010
   SCI_B      : origin = 0x007750, length = 0x000010
   MCBSP_A    : origin = 0x007800, length = 0x000040
   CSM_PWL     : origin = 0x3F7FF8, length = 0x000008     /* Part of FLASHA.  CSM password locations in FLASHA */
/* Allocate sections to memory blocks.
   Note:
         codestart user defined section in DSP28_CodeStartBranch.asm used to redirect code
                   execution when booting to flash
         ramfuncs  user defined section to store functions that will be copied from Flash into RAM
SECTIONS
   /* Allocate program areas: */
   .cinit              : > FLASHA      PAGE = 0
   .pinit              : > FLASHA      PAGE = 0
   .text               : > FLASHA      PAGE = 0
   codestart           : > BEGIN       PAGE = 0
      ramfuncs            : LOAD = FLASHD,
                         RUN = RAML0,
                         LOAD_START(_RamfuncsLoadStart),
                         LOAD_END(_RamfuncsLoadEnd),
                         RUN_START(_RamfuncsRunStart),
                         PAGE = 0
   /* Allocate uninitalized data sections: */
   .stack              : > RAMM0       PAGE = 1
   .ebss               : > RAML1       PAGE = 1
   .esysmem            : > RAMH0       PAGE = 1
   /* Initalized sections go in Flash */
   /* For SDFlash to program these, they must be allocated to page 0 */
   .econst             : > FLASHA      PAGE = 0
   .switch             : > FLASHA      PAGE = 0
   /* Allocate IQ math areas: */
   IQmath              : > FLASHC      PAGE = 0                  /* Math Code */
   IQmathTables        : > ROM         PAGE = 0, TYPE = NOLOAD   /* Math Tables In ROM */
   /* .reset is a standard section used by the compiler.  It contains the */
   /* the address of the start of _c_int00 for C Code.   /*
   /* When using the boot ROM this section and the CPU vector */
   /* table is not needed.  Thus the default type is set here to  */
   /* DSECT  */
   .reset              : > RESET,      PAGE = 0, TYPE = DSECT
   vectors             : > VECTORS     PAGE = 0, TYPE = DSECT
   PieVectTableFile : > PIE_VECT,   PAGE = 1
   /* Allocate Peripheral Frame 0 Register Structures:   */
   DevEmuRegsFile      : > DEV_EMU     PAGE = 1
   FlashRegsFile       : > FLASH_REGS  PAGE = 1
   CsmRegsFile         : > CSM         PAGE = 1
   XintfRegsFile       : > XINTF       PAGE = 1
   CpuTimer0RegsFile   : > CPU_TIMER0  PAGE = 1
   CpuTimer1RegsFile   : > CPU_TIMER1  PAGE = 1
   CpuTimer2RegsFile   : > CPU_TIMER2  PAGE = 1
   PieCtrlRegsFile     : > PIE_CTRL    PAGE = 1
   PieVectTable        : > PIE_VECT    PAGE = 1
  /*** Peripheral Frame 1 Register Structures ***/
   ECanaRegsFile     : > ECANA,       PAGE = 1
   ECanaLAMRegsFile  : > ECANA_LAM    PAGE = 1
   ECanaMboxesFile   : > ECANA_MBOX   PAGE = 1
   ECanaMOTSRegsFile : > ECANA_MOTS   PAGE = 1
   ECanaMOTORegsFile : > ECANA_MOTO   PAGE = 1
   /* Allocate Peripheral Frame 1 Register Structures:   */
   SysCtrlRegsFile     : > SYSTEM      PAGE = 1
   SpiaRegsFile        : > SPI_A       PAGE = 1
   SciaRegsFile        : > SCI_A       PAGE = 1
   XIntruptRegsFile    : > XINTRUPT    PAGE = 1
   GpioMuxRegsFile     : > GPIOMUX     PAGE = 1
   GpioDataRegsFile    : > GPIODAT     PAGE = 1
   AdcRegsFile         : > ADC         PAGE = 1
   EvaRegsFile         : > EV_A        PAGE = 1
   EvbRegsFile         : > EV_B        PAGE = 1
   ScibRegsFile        : > SCI_B       PAGE = 1
   McbspaRegsFile      : > MCBSP_A     PAGE = 1
    /* CSM Password Locations */
   CsmPwlFile          : > CSM_PWL     PAGE = 1
,需要注意的是,出现 warning: creating output section XXXXXXXXX without SECTIONS specification 的警告时,标示您的cmd文件中找不到xxxxxx指定的节,必须要加它。
千万不要忘记flash 的初始化,如果能顺利的进入startbranch.asm中的话,而在illegalISR中等待,则很可能是initflash函数没有执行,这个函数需要再SRAM中执行,所以要先把它move到RAM中,然后在run,如下
   MemCopy(&RamfuncsLoadStart, &RamfuncsLoadEnd, &RamfuncsRunStart);
// Call Flash Initialization to setup flash waitstates
// This function must reside in RAM
   InitFlash();
 在flash中运行的程序也是可以调试的,这时候的step into (F10),Step over(F11)已经基本不用了。而用assembly step-into 和assembly step-over来替代
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
