btiger2000的笔记 https://passport2.21ic.com/?37044 [收藏] [复制] [RSS] 嵌入式软硬件开发工程师的一些心得,一些体会,一些经验,一些教训
日志
转 mdk下查找hard fault位置的方法
已有 2367 次阅读2012-10-26 09:53 |个人分类:STM32|系统分类:ARM| hard, fault
keil中先将fault中断函数的内容改为:
HardFault_Handler\
                PROC
                ;EXPORT  HardFault_Handler         [WEAK]
                ;B                  .
                                IMPORT hard_fault_handler_c
                                TST LR, #4
                                ITE EQ
                                MRSEQ R0, MSP
                                MRSNE R0, PSP
                                B hard_fault_handler_c
                ENDP
然后在源程序里添加下面的函数代码:
// hard fault handler in C,
// with stack  location as input parameter
void hard_fault_handler_c(unsigned int * hardfault_args)
unsigned int stacked_r0;
unsigned int stacked_r1;
unsigned int stacked_r2;
unsigned int stacked_r3;
unsigned int stacked_r12;
unsigned int stacked_lr;
unsigned int stacked_pc;
unsigned int stacked_psr;
stacked_r0 = ((unsigned long) hardfault_args[0]);
stacked_r1 = ((unsigned long) hardfault_args[1]);
stacked_r2 = ((unsigned long) hardfault_args[2]);
stacked_r3 = ((unsigned long) hardfault_args[3]);
stacked_r12 = ((unsigned long) hardfault_args[4]);
stacked_lr = ((unsigned long) hardfault_args[5]);
stacked_pc = ((unsigned long) hardfault_args[6]);
stacked_psr = ((unsigned long) hardfault_args[7]);
printf ("[Hard fault handler]\n");
printf ("R0 = %x\n", stacked_r0);
printf ("R1 = %x\n", stacked_r1);
printf ("R2 = %x\n", stacked_r2);
printf ("R3 = %x\n", stacked_r3);
printf ("R12 = %x\n", stacked_r12);
printf ("LR = %x\n", stacked_lr);
printf ("PC = %x\n", stacked_pc);
printf ("PSR = %x\n", stacked_psr);
printf ("BFAR = %x\n", (*((volatile unsigned long *)(0xE000ED38))));
printf ("CFSR = %x\n", (*((volatile unsigned long *)(0xE000ED28))));
printf ("HFSR = %x\n", (*((volatile unsigned long *)(0xE000ED2C))));
printf ("DFSR = %x\n", (*((volatile unsigned long *)(0xE000ED30))));
printf ("AFSR = %x\n", (*((volatile unsigned long *)(0xE000ED3C))));
while(1)
如果使用调试器,则可以在第一个printf处设置断点.没有的话看串口打印结果
通过查看stacked_lr的内容可以知道程序运行到哪个位置出现fault
然后查看编译后汇编代码,可以知道源程序是哪个函数哪一步出现问题,
配合其它寄存器的内容来分析找出原因
路过
鸡蛋
鲜花
握手
雷人
发表评论 评论 (1 个评论)
回复 btiger2000 2012-12-3 07:13
MRSEQ R0, MSP
                                MRSNE R0, PSP
这两条指令mdk不认
