沃赛特 https://passport2.21ic.com/?448798 [收藏] [复制] [RSS] 祝贺WORSAT成立!
日志
曾写的78E58的ISP程序PC部分
已有 1172 次阅读2006-6-25 16:22 |个人分类:原味...
使用BCB编写的很小的东东,用API访问串口,
直接运行界面如下不好看只要能用就行(我是实用主义者,同时对那些写了很小的程序就要用户安装、改注册表。。。的人表示鄙视:))。
//定义头文件中的主要内容
class TForm1 : public TForm
__published: // IDE-managed Components
        TButton *Button1;
        TButton *Button2;
        TButton *Button3;
        TOpenDialog *OpenDialog1;
        TProgressBar *ProgressBar1;
        TEdit *Edit1;
        TButton *Button4;
        TLabel *Label1;
        TRadioButton *RadioButton1;
        TRadioButton *RadioButton2;
        TButton *Button5;
        TEdit *Edit2;
        TMemo *Memo1;
        TButton *Button6;
        TEdit *Edit3;
        TLabel *Label2;
        TLabel *Label3;
        TTimer *Timer1;
        TMemo *Memo2;
        void __fastcall Button5Click(TObject *Sender);
        void __fastcall Button1Click(TObject *Sender);
        void __fastcall FormCreate(TObject *Sender);
        void __fastcall RadioButton1Click(TObject *Sender);
        void __fastcall RadioButton2Click(TObject *Sender);
        void __fastcall FormClose(TObject *Sender, TCloseAction &Action);
        void __fastcall Button2Click(TObject *Sender);
        void __fastcall Button3Click(TObject *Sender);
        void __fastcall Button4Click(TObject *Sender);
        void __fastcall Button6Click(TObject *Sender);
        void __fastcall Timer1Timer(TObject *Sender);
        void __fastcall Memo1DblClick(TObject *Sender);
private: // User declarations
public:  // User declarations
        unsigned char Buff[0x10000];    //文件内容缓冲区
        DCB ComDCB;
        HANDLE hComm;
        DWORD BytesSent;
        DWORD BytesRead;
        COMSTAT ComStat;
        DWORD dwBytesRead;
        DWORD dwErrorFlags;
        int BufLen;     // 有效长度
        unsigned char SendBytes[100];
        unsigned char ucRxBuff[100];
        unsigned char __fastcall ToHex(unsigned char dat);
        __fastcall TForm1(TComponent* Owner);
//代码文件中的主要内容
unsigned char _fastcall TForm1::ToHex(unsigned char dat)
{//很笨办法实现的char转HEX,但执行效率不一定低。有空再改
unsigned char i;
switch (dat)
        case '0':
                i = 0;
                break;
        case '1':
                i = 1;
                break;
        case '2':
                i = 2;
                break;
        case '3':
                i = 3;
                break;
        case '4':
                i = 4;
                break;
        case '5':
                i = 5;
                break;
        case '6':
                i = 6;
                break;
        case '7':
                i = 7;
                break;
        case '8':
                i = 8;
                break;
        case '9':
                i = 9;
                break;
        case 'a':
        case 'A':
                i = 0x0a;
                break;
        case 'b':
        case 'B':
                i = 0x0b;
                break;
        case 'c':
        case 'C':
                i = 0x0c;
                break;
        case 'd':
        case 'D':
                i = 0x0d;
                break;
        case 'e':
        case 'E':
                i = 0x0e;
                break;
        case 'f':
        case 'F':
                i = 0x0f;
                break;
        default:
                i = dat;
                break;
return i;
void __fastcall TForm1::Button5Click(TObject *Sender)
int addr,i,j;
BufLen = 0;
Form1->OpenDialog1->Execute();
for (i = 0;i<65536;i++) Buff = 0xff;
int iFileHandle = FileOpen(OpenDialog1->FileName, fmOpenRead);
Edit1->Text = OpenDialog1->FileName;
int iFileLength = FileSeek(iFileHandle,0,2);
FileSeek(iFileHandle,0,0);
unsigned char *pszBuffer = new unsigned char[iFileLength+1];
int iBytesRead = FileRead(iFileHandle, pszBuffer, iFileLength);
FileClose(iFileHandle);
int hexFileType = MessageBox(Form1->Handle,"INTEL HEX格式选择是(Y),BIN格式选择否(N)","是否HEX格式?",MB_YESNO);
if (IDNO == hexFileType)
        {//BIN
        if (iBytesRead>0x8000) iBytesRead = 0x8000;
        for (i=0;i<iBytesRead;i++) {Buff = pszBuffer;};
        BufLen = iBytesRead/32;
        BufLen *= 32;
        if (0 != (iBytesRead%32)) {BufLen += 32;};
else
        {//HEX
        i = 0;
        while(1)
         while ((':' != pszBuffer) && (i<iBytesRead)) {i++;};
         if (i>=iBytesRead)
                i = 0x8000;
                while(Buff == 0xff) i--;
                BufLen = i/32;
                BufLen *= 32;
                if (0 != (i%32)) {BufLen +=32;};
                delete [] pszBuffer;
                if ((0 != BufLen) && (hComm > 0))
                        Button2->Enabled = true;
                        Button3->Enabled = true;
                        Button4->Enabled = true;
                else
                        Button2->Enabled = false;
                        Button3->Enabled = false;
                        Button4->Enabled = false;
                return;
         i++;
         unsigned char cc = 16 * ToHex(pszBuffer[i++]);
         cc += ToHex(pszBuffer[i++]);
         addr = 16 * 16 * 16 * ToHex(pszBuffer[i++]);
         addr += 16 * 16 * ToHex(pszBuffer[i++]);
         addr += 16 * ToHex(pszBuffer[i++]);
         addr += ToHex(pszBuffer[i++]);
         j =  16 * ToHex(pszBuffer[i++]);
         j += ToHex(pszBuffer[i++]);
         if (0==j)
                for (j=0;j<cc;j++)
                        if (addr<0x8000)
                                Buff[addr] =  16 * ToHex(pszBuffer[i++]);
                                Buff[addr++] +=  ToHex(pszBuffer[i++]);
if (0 != BufLen)
else
void __fastcall TForm1::Button1Click(TObject *Sender)
Timer1->Enabled = false;
Label1->Caption = "正在擦除......";
Label1->Refresh();
SendBytes[0] = 'p';  //如MCU在32K模式则复位并进入4K BOOT
PurgeComm(hComm, PURGE_TXABORT| PURGE_RXABORT | PURGE_TXCLEAR| PURGE_RXCLEAR ) ; //清收发缓冲区
WriteFile(hComm,SendBytes,1,&BytesSent,NULL);
Sleep(500);
SendBytes[0] = 'E';
Form1->ProgressBar1->Position = 0;
Sleep(200);
ClearCommError(hComm,&dwErrorFlags,&ComStat);
if (ComStat.cbInQue > 1) ComStat.cbInQue = 1;
if (ReadFile(hComm,ucRxBuff,ComStat.cbInQue,&BytesRead,NULL) && (BytesRead >= 1))
        if (0x00 == ucRxBuff[0])
                Label1->Caption = "擦除后空白检查OK";
                ProgressBar1->Position = ProgressBar1->Max;
                return;
        if (0xff == ucRxBuff[0])
                {Label1->Caption = "擦除后空白检查不能通过!!!!!";return;};
        ProgressBar1->Position = ucRxBuff[0];
        while(1)
                                return;
                        Form1->ProgressBar1->Position = ucRxBuff[0];
                        Label1->Caption = "正在空白检查......";
                Sleep(1);
else
        Label1->Caption = "通信超时!检查连接!";
void __fastcall TForm1::FormCreate(TObject *Sender)
Application->ShowMainForm=false;
AnsiString cap=Application->Title;
Application->Title="temp";
if (FindWindow(NULL,cap.c_str()))
     {Application->Terminate();return;};
Application->Title=cap.c_str();   //检查如果已有本程序运行则返回
Application->ShowMainForm=true;
BufLen = 0;
CloseHandle(hComm);
hComm = CreateFile("COM1",GENERIC_READ|GENERIC_WRITE,0,NULL,OPEN_EXISTING,FILE_ATTRIBUTE_NORMAL,0);//|FILE_FLAG_OVERLAPPED,0);
if ((int)hComm < 0)
        hComm = CreateFile("COM2",GENERIC_READ|GENERIC_WRITE,0,NULL,OPEN_EXISTING,FILE_ATTRIBUTE_NORMAL,0);//|FILE_FLAG_OVERLAPPED,0);
        Form1->RadioButton1->Checked = false;
        Form1->RadioButton2->Checked = true;
if ((int)hComm < 0)
        MessageBox(Form1->Handle,"端口都不能被使用!","ERROR", MB_OK);
        Label1->Caption = "请检查通信端口是否被其它程序占用";
        Button1->Enabled = false;
        Button6->Enabled = false;
        return;
GetCommState(hComm,&ComDCB);
BuildCommDCB("57600,n,8,1",&ComDCB);
SetCommState(hComm,&ComDCB);
PurgeComm(hComm, PURGE_RXCLEAR|PURGE_TXCLEAR|PURGE_RXABORT|PURGE_TXABORT);
Label1->Caption = "等待命令...";
Button1->Enabled = true;
Button6->Enabled = true;
void __fastcall TForm1::RadioButton1Click(TObject *Sender)
CloseHandle(hComm);
if ((int)hComm < 0)
        MessageBox(Form1->Handle,"端口1不能被使用!","ERROR", MB_OK);
        Label1->Caption = "请重新选择通信端口";
        return;
if(0 != BufLen)
void __fastcall TForm1::RadioButton2Click(TObject *Sender)
CloseHandle(hComm);
if ((int)hComm < 0)
        MessageBox(Form1->Handle,"端口2不能被使用!","ERROR", MB_OK);
        RadioButton2->Checked = false;
        return;
if(0 != BufLen)
void __fastcall TForm1::FormClose(TObject *Sender, TCloseAction &Action)
if ((int)hComm <0) return;
CloseHandle(hComm);
void __fastcall TForm1::Button2Click(TObject *Sender)
unsigned short addr = 0;
int i;
Label1->Caption = "正在编程......";
Label1->Refresh();
while (addr < BufLen)
SendBytes[0] = 'P';
SendBytes[1]=addr/256;SendBytes[2]=addr;
if ((BufLen-addr)>=32)
        SendBytes[3]=32;
        for (i=4;i<36;i++)
                {SendBytes=Buff[addr++];};
        WriteFile(hComm,SendBytes,36,&BytesSent,NULL);
else    {
        SendBytes[3]=BufLen-addr;
        for (i=4;i<(4+BufLen-addr);i++)
        WriteFile(hComm,SendBytes,4+BufLen-addr,&BytesSent,NULL);
i =0;
do
        Sleep(1);
        i++;
        if (i>1000)
                Label1->Caption ="通信出错!!!!!";
                return;
        } while (ComStat.cbInQue<2);
ReadFile(hComm,ucRxBuff,ComStat.cbInQue,&BytesRead,NULL);
ProgressBar1->Position = 128 *addr / BufLen;
Label1->Caption = "编程完成,请进行校验";
void __fastcall TForm1::Button3Click(TObject *Sender)
int i;
Label1->Caption = "正在检查校验数据......";
Label1->Refresh();
SendBytes[0] = 'V';
SendBytes[3]=32;
WriteFile(hComm,SendBytes,4,&BytesSent,NULL);
i =0;
do
        Sleep(1);
        i++;
        if (i>1000)
                return;
        } while (ComStat.cbInQue < 33);
if ('V' != ucRxBuff[0])
        Label1->Caption ="接收出错!!!!!";
        return;
for (i=1;i<33;i++)
        if (Buff[addr++] != ucRxBuff)
                Label1->Caption = "校验检查到错误 0x"+IntToHex(addr-1,4);
                return;
Label1->Caption = "校验OK";
void __fastcall TForm1::Button4Click(TObject *Sender)
Button6->Refresh();
Form1->Button1Click(Form1);
Form1->Refresh();
if (Label1->Caption != "擦除后空白检查OK")
        return;
Form1->Button2Click(Form1);
Form1->Refresh();
if (Label1->Caption != "编程完成,请进行校验")
        return;
Form1->Button3Click(Form1);
Form1->Refresh();
if (Label1->Caption != "校验OK")
        return;
SendBytes[0] = 'F';
Sleep(10);
Label1->Caption = "完成编程,并使MCU复位";
Timer1->Enabled = true;
void __fastcall TForm1::Button6Click(TObject *Sender)
int i = 0;
AnsiString s;
if (Edit3->Text.Length() != 1) return;
SendBytes[i++] = Edit3->Text.c_str()[0];
int j = 0;
while (j < Edit2->Text.Length())
        s= "";
        while ((Edit2->Text.c_str()[j] != ',') && (j < Edit2->Text.Length()))
        s += Edit2->Text.c_str()[j++];
        j++;
        if (s.Length()==2) s = "0x"+s;
        SendBytes[i++] = StrToInt(s);
//PurgeComm(hComm, PURGE_TXABORT| PURGE_RXABORT | PURGE_TXCLEAR| PURGE_RXCLEAR ) ; //清收发缓冲区
WriteFile(hComm,SendBytes,i,&BytesSent,NULL);
void __fastcall TForm1::Timer1Timer(TObject *Sender)
AnsiString s="";
AnsiString ss="";
if (ComStat.cbInQue == 0)
        return;
for (unsigned int i=0;i<BytesRead;i++)
        s += IntToHex(ucRxBuff,2) + " ";
        ss += " ";
        ss += (char)ucRxBuff;
        ss += " ";
Memo1->Lines->Append(s);
Memo2->Lines->Append(ss);
void __fastcall TForm1::Memo1DblClick(TObject *Sender)
Memo1->Clear();
Memo2->Clear();
//Memo1->Lines->Append("接收到的数据:");
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
