刘玉宏原创仓库 https://passport2.21ic.com/?46121 [收藏] [复制] [RSS]
日志
rs232引脚定义,存此,方便查阅
已有 763 次阅读2012-10-30 13:54 |个人分类:其它|系统分类:接口电路| RS232
Signals
The following table lists commonly used RS-232 signals and pin assignments.[8] See serial port (pinouts)for non-standard variations including the popular DE-9connector.
Signal
Origin
DB-25pin
Name
Typical purpose
Abbreviation
DTE
DCE
Data Terminal Ready
Indicates presence of DTE to DCE.
DTR
20
Data Carrier Detect
DCE is connected to the telephone line.
DCD
Data Set Ready
DCE is ready to receive commands or data.
DSR
Ring Indicator
DCE has detected an incoming ring signal on the telephone line.
RI
22
Request To Send
DTE requests the DCE prepare to receive data.
RTS
Clear To Send
Indicates DCE is ready to accept data.
CTS
Transmitted Data
Carries data from DTE to DCE.
TxD
Received Data
Carries data from DCE to DTE.
RxD
Common Ground
GND
common
Protective Ground
PG
common
The signals are named from the standpoint of the DTE. The ground signal is a common returnfor the other connections. The DB-25 connector includes a second "protective ground" on pin 1.
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
