siuhiong的笔记 https://passport2.21ic.com/?646451 [收藏] [复制] [RSS]
日志
STM8读写24C02程序(I2C接口)
已有 2209 次阅读2012-12-12 00:27 |系统分类:单片机| STM8, 24c02, i2c接口
        1、程序功能:STM8单片机自带有I2C接口,可直接用于驱动AT24CXX系列存储芯片。本例程为STM8S1054S读写AT24CXX的驱动程序。
        2、电路连接:STM8单片机的PE1(SCL)、PE2(SDA)分别与AT24CXX的SCL、SDA相连,采用外部晶振16M,IAR FOR STM8开发环境。
        3、程序代码如下:
#include   <iostm8s105s4.h>
#define uchar                        unsigned char
#define uint                            unsigned int
#define WD_DADR                  0xa0
#define RD_DADR                   0xa1
#define I2C_busy()                 while((I2C_SR3&0x02)==1);
#define I2C_start()                 I2C_CR2|=0x01;
#define I2C_stop()                 I2C_CR2|=0x02;
#define I2C_Ack()                  I2C_CR2|=0x04;
#define I2C_NAck()                I2C_CR2&=(~0x04);
#define I2C_addrask              (I2C_SR1&0x02)
#define I2C_SBask                 (I2C_SR1&0x01)
#define I2C_TxEask                (I2C_SR1&0x80)
#define I2C_RxNeask              (I2C_SR1&0x40)
#define I2C_BTF                     (I2C_SR1&0x04)
#define I2C_writebyte(x)         I2C_DR=x;
uchar tmp;
/*--------I2C初始化-----------*/
void I2C_Init(void)
  I2C_FREQR=0x0f;      //设置频率寄存器
  I2C_CCRH=0x00;       //设置时钟寄存器高位
  I2C_CCRL=0x50;       //设置时钟寄存器低位
  I2C_TRISER=0x11;    //设置最大SCL上升时间
  I2C_CR1|=0x01;        //使能I2C模块
  I2C_Ack();                //设置匹配应答
  I2C_CR2|=0x08;       //设置接收应答
void I2C_Start(void)
  I2C_busy();
  I2C_start();
  while(I2C_SBask==0);
/*-------------传送地址---------------*/
void I2C_SendDAdr(uchar Add)
  I2C_writebyte(Add);
  while(I2C_addrask==0);
  I2C_busy();
/*----------------发送数据------------------*/
void I2C_SendDat(uchar data)
  I2C_writebyte(data);
  I2C_busy();
  while(I2C_TxEask==0);
/*---------------接收数据-------------------*/
uchar I2C_RcvDat(void)
  uchar i;
  while(I2C_RxNeask==0);
abc:
  if(I2C_BTF==0x04)
  {i=I2C_DR;}
  else goto abc;
  if(I2C_BTF==0){}
  else goto abc;
  return i;
/*--------------AT24CXX初始化------------*/
void AT24CXX_Init(void)
  I2C_Init();
/*--------------写一字节---------------------*/
void AT24CXX_WriteAByte(uchar wordAdr,uchar dat)
  I2C_Start();
  I2C_SendDAdr(WD_DADR);
  I2C_SendDat(wordAdr);
  I2C_SendDat(dat);
  I2C_stop();
/*--------------读一字节---------------------*/
uchar AT24CXX_ReadAByte(uchar wordAdr)
  uchar dat;
  I2C_Start();
  I2C_Start();
  I2C_NAck();
  I2C_SendDAdr(RD_DADR);
  dat=I2C_RcvDat();
  I2C_stop();
  I2C_Ack();
  return dat;
//延时程序
void Delay_ms( uint ms )
  uint i,j;
  for( j=0; j < ms; j++ )
    for( i=0; i > 1000; i++ )
//时钟初始化
void CLK_Init(void)
  CLK_ECKR=0x03;      //外部时钟寄存器 外部时钟准备就绪,外部时钟开
  CLK_SWCR=0x02;     //切换控制寄存器 使能切换机制
  CLK_SWR=0xB4;       //主时钟切换寄存器 选择HSE为主时钟源*/
  while (!(CLK_SWCR & 0x08));
  CLK_CSSR=0x01;      //时钟安全系统寄存器
//初始化
void Devices_Init(void)
  Delay_ms(200);
  CLK_Init();
  AT24CXX_Init();
//主程序
void main( void )
  Devices_Init();
  AT24CXX_WriteAByte(0x01,0x60);
  Delay_ms(10);
  tmp=AT24CXX_ReadAByte(0x01);
  Delay_ms(10);
  while (1);
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
