jimmyhua的笔记 https://passport2.21ic.com/?74262 [收藏] [复制] [RSS]
日志
带清零 计数使能和置数的十进制加减计数器
已有 1513 次阅读2007-2-13 14:23 |个人分类:单片机|系统分类:EDA/PLD
library ieee;
use ieee.std_logic_1164.all;
entity counter10_updown is
port(clr,ena,clk,updown,load: in std_logic;
     d: buffer integer range 0 to 9;
     q: buffer integer range 0 to 9;
     count:out std_logic);
end entity counter10_updown;
architecture rtl of counter10_updown is
begin
process(clk,clr)
begin
if clr='1' then q<=0;
else
    if clk='1' and clk'event then
    if load='1' then q<=d;
    elsif ena='1'then
    if updown='1' then
      if q=9 then q<=0;
       else
        q<=q+1;
       end if;
      else
         if q=0 then q<=9;
         else
           q<=q-1;
       end if;
       end if;
       end if;
       end if;
end if;
if updown='1' then
 if q=9 then count<='1';
else count<='0';
end if;
else
if q=0 then
count<='1';
else count<='0';
end if;
end if;
end process;
end architecture rtl;
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
