天命风流的个人空间 https://passport2.21ic.com/?971716 [收藏] [复制] [RSS]
日志
0欧电阻作用
热度 3已有 1075 次阅读2013-4-17 13:55 |系统分类:兴趣爱好| 0R电阻
"Times New Roman";mso-bidi-font-family:"Times New Roman";mso-font-kerning:1.0pt;
mso-ansi-language:EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">在论坛中看到有人问,
mso-fareast-font-family:宋体;mso-font-kerning:1.0pt;mso-ansi-language:EN-US;
mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">0
"Times New Roman";mso-font-kerning:1.0pt;mso-ansi-language:EN-US;mso-fareast-language:
ZH-CN;mso-bidi-language:AR-SA">欧电阻作用,依据个人经验,在此总结一下。
1,
mso-bidi-font-family:"Times New Roman";mso-font-kerning:1.0pt;mso-ansi-language:
EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">在电路中没有任何功能,只是在
mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">PCB
ZH-CN;mso-bidi-language:AR-SA">上为了调试方便或兼容设计等原因;
2,
EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">可以做跳线用,如果某段线路不用,直接不贴该电阻即可(不影响外观);
3,
EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">在匹配电路参数不确定的时候,以
ZH-CN;mso-bidi-language:AR-SA">欧姆代替,实际调试的时候,确定参数,再以具体数值的元件代替;
4,
EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">想测某部分电路的耗电流的时候,可以去掉
mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">0ohm
ZH-CN;mso-bidi-language:AR-SA">电阻,接上电流表,这样方便测耗电流;
5,
EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">在布线时
mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">,
ZH-CN;mso-bidi-language:AR-SA">如果实在布不过去了
ZH-CN;mso-bidi-language:AR-SA">也可以加一个
宋体;mso-font-kerning:1.0pt;mso-ansi-language:EN-US;mso-fareast-language:ZH-CN;
mso-ansi-language:EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">欧的电阻;
6,
EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">在高频信号下,充当电感或电容。(与外部电路特性有关)电感用,主要是解决
mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">EMC
ZH-CN;mso-bidi-language:AR-SA">问题。如地与地,电源和
mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">IC Pin
ZH-CN;mso-bidi-language:AR-SA">间
7,
EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">单点接地(指保护接地、工作接地、直流接地在设备上相互分开
ZH-CN;mso-bidi-language:AR-SA">各自成为独立系统。);
8,
EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">熔丝作用;
EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">什么单点接地:
EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">  只要是地,最终都要接到一起,然后入大地。如果不接在一起就是
mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">"
ZH-CN;mso-bidi-language:AR-SA">浮地
mso-ansi-language:EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">,存在压差,容易积累电荷,造成静电。地是参考
ZH-CN;mso-bidi-language:AR-SA">电位,所有电压都是参考地得出的,地的标准要一致,故各种地应短接在一起。人们认为大地能够吸收所有电荷,始终维持稳定,是最终的地参考点。虽然有些板子没有接大地,但发电厂是接大地的,板子上的电源最终还是会返回发电厂入地。如果把模拟地和数字地大面积直接相连,会导致互相干扰。不短接又不妥,理由如上有四种方法解决此问题:
EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">、用磁珠连接;
EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">、用电容连接;
EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">、用电感连接;
ZH-CN;mso-bidi-language:AR-SA">欧姆电阻连接。
EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">  磁珠的等效电路相当于带阻限波器,只对某个频点的噪声有显著抑制作用,使用时需要预先估计噪点频率,以便选用适当型号。对于频率不确定或无法预知的情况,磁珠不合。
EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">  电容隔直通交,造成浮地。
EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">  电感体积大,杂散参数多,不稳定。
ZH-CN;mso-bidi-language:AR-SA">欧电阻相当于很窄的电流通路,能够有效地限制环路电流,使噪声得到抑制。电阻在所有频带上都有衰减作用
mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">(0
ZH-CN;mso-bidi-language:AR-SA">欧电阻也有阻抗
mso-bidi-language:AR-SA">)
mso-ansi-language:EN-US;mso-fareast-language:ZH-CN;mso-bidi-language:AR-SA">,这点比磁珠强。
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
