[其它]
在Arduino下ESP32C3通过ULN2003模块驱动28BYJ-48步进电机
12051|1
电机接线图
电机参数如下所示
模块原理图
驱动时序
简单粗暴的来一下
uint32_t delay_time =1;
#define IN1 19
#define IN2 18
#define IN3 12
#define IN4 1
void setup() {
  // put your setup code here, to run once:
  pinMode(IN1, OUTPUT);
  pinMode(IN2, OUTPUT);
  pinMode(IN3, OUTPUT);
  pinMode(IN4, OUTPUT);
void loop() {
  // put your main code here, to run repeatedly:
  digitalWrite(IN1, LOW );
  digitalWrite(IN2, HIGH);
  digitalWrite(IN3, HIGH);
  digitalWrite(IN4, HIGH);
  delay(delay_time);
  digitalWrite(IN2, LOW );
  delay(delay_time);
  digitalWrite(IN1, HIGH);
  delay(delay_time);
  digitalWrite(IN3, LOW );
  delay(delay_time);
  delay(delay_time);
  digitalWrite(IN4, LOW );
  delay(delay_time);
  delay(delay_time);
  delay(delay_time);
经过测试效果很好
闻则123| | 2023-12-13 16:04 | 只看该作者
看看,学习下
1997
