发新帖本帖赏金 50.00元(功能说明)我要提问
返回列表
[AT32F405]
【AT-START-F405测评】+驱动温湿度传感器GXHT-30
4713|1
GXHT-30温湿度传感器是一个国产的温湿度传感器,使用I2C方式通讯。
典型应用电路:
由测量结果数据计算相对湿度转换公式(%RH):
我这里实际使用的是GXHT-30的模块,提供VDD、GND、SDA、SCL接口。
开发板提供的GPIO中,我使用GPIO口模拟方式,连接GXHT-30温湿度传感器,其中PC9作为SCL使用,PC7作为SDA使用。
主程序在初始化完各关联设备后,每间隔1秒钟,温湿度启动传感器一次,并读取结果显示到TFT显示屏上。
int main(void) {
    float         temperature;        // temperature [°C]
    float        humidity;                // relative humidity [%RH]
    char val[32]={'\0'};
    etError   error;        // error code
    system_clock_config();
    at32_board_init();
    uart_print_init(115200);
    printf("Start main ...\r\n");
    // 初始化TFT显示屏
    Lcd_Init();
    // 测试
    Lcd_Clear(BLACK);
    Gui_DrawFont_GBK16(8,10,WHITE, BLACK, (unsigned char *)"Artery & 21IC");
    Gui_DrawFont_GBK16(30,36,WHITE, BLACK, (unsigned char *)"AT32F405");
    // 初始化水位传感器、抽水马达控制口
    at32_led_on(LED2);
    mymac_Init();
    Gui_DrawFont_GBK16(0, 60,WHITE, BLACK, (unsigned char *)"初始化:");
    Gui_DrawFont_GBK16(10, 76,WHITE, BLACK, (unsigned char *)"水位控制接口");
    at32_led_off(LED2);
    at32_led_on(LED3);
    // 初始化温湿度传感器GXHT-30
    Gui_DrawFont_GBK16(10, 92,WHITE, BLACK, (unsigned char *)"传感器接口");
    gxht30_Init(GXHT30_ADDRESS);
    at32_led_off(LED3);
    Gui_DrawFont_GBK16(0, 110, WHITE, BLACK, (unsigned char *)"温度");
    Gui_DrawFont_GBK16(32,110, WHITE, BLACK, (unsigned char *)"=");
    Gui_DrawFont_GBK16(0, 126,WHITE, BLACK, (unsigned char *)"湿度");
    Gui_DrawFont_GBK16(32,126,WHITE, BLACK, (unsigned char *)"=");
    while(1) {
//        Gui_DrawFont_GBK16(58,84,  WHITE, BLACK, (unsigned char *)"       ");
//        Gui_DrawFont_GBK16(58,100, WHITE, BLACK, (unsigned char *)"       ");
        //at32_led_toggle(LED2);
        //delay_ms(200);
        //at32_led_toggle(LED3);
        //delay_ms(200);
        //at32_led_toggle(LED4);
        //delay_ms(200);
//        error = gxht30_GetTempAndHumi(&temperature, &humidity, REPEATAB_HIGH, MODE_CLKSTRETCH, 50);
//        sprintf(val, "Result=0x%02x", error);
//        Gui_DrawFont_GBK16(0,142,WHITE, BLACK, (unsigned char *)val);
        SHT30_read_result(GXHT30_ADDRESS, &temperature, &humidity);
        sprintf(val, "%5.1f", temperature);
        Gui_DrawFont_GBK16(48,110,WHITE, BLACK, (unsigned char *)val);
        sprintf(val, "%5.1f", humidity);
        Gui_DrawFont_GBK16(48,126, WHITE, BLACK, (unsigned char *)val);
        delay_ms(1000);
目前的处理结果不对,应该卡在了传感器的读写时序上,正在检查中。
打赏榜单
ArteryMCU 打赏了 50.00 元 2024-06-07
理由:[F405开发板评测活动]内容优质
suncat0504|  楼主 | 2024-5-5 21:58 | 只看该作者
数据不正常,竟然是因为初始化GPIO口的代码没有被调用,大意了。
发新帖 本帖赏金 50.00元(功能说明)我要提问
认证:大连伊飞特信息技术有限公司软件工程师
简介:本人于1993年毕业于大连理工大学。毕业后从事单片机开发工作5年,之后转入软件开发工作至今。
151
