[AVR单片机]
HT1621显示
3861|4
代码
#include <iom128v.h>
#include <macros.h>
#define uchar unsigned char
#define uint unsigned int
#define DA_1  PORTD |= BIT(6)//RS置1
#define DA_0  PORTD &= ~BIT(6)//RS置0
#define WR_1  PORTD |= BIT(2)//RS置1
#define WR_0  PORTD &= ~BIT(2)//RS置0
#define CS_1  PORTD |= BIT(4)//RS置1
#define CS_0  PORTD &= ~BIT(4)//RS置0
#define Smg_a 0x80
#define Smg_b 0x40
#define Smg_c 0x20
#define Smg_d 0x01
#define Smg_e 0x02
#define Smg_f 0x08
#define Smg_g 0x04
#define Smg_dp 0x10
#define Bmp0Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
#define Bmp1Map Smg_b | Smg_c
#define Bmp2Map Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
#define Bmp3Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
#define Bmp4Map Smg_b | Smg_c | Smg_f | Smg_g
#define Bmp5Map Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp6Map Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp8Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp9Map Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp7Map Smg_a | Smg_b | Smg_c
#define BmpAMap Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
#define BmpBMap Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpCMap Smg_a | Smg_d | Smg_e | Smg_f
#define BmpDMap Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
#define BmpEMap Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpFMap Smg_a | Smg_e | Smg_f | Smg_g
const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
unsigned char DpyNum[6] = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //?????
unsigned int i;
void COMMAND_HT1621(unsigned char comm)
//unsigned char i;
CS_0;
WR_0;
for(i=0;i<3;i++)//???
if((0x04<<i)&0x04)
                                                   DA_1; //100
else
                                    DA_0;
WR_0;
WR_1;
for(i=0;i<9;i++)//?????
    if((comm<<i)&0x80) DA_1; //100
    else DA_0;
    WR_0;
    WR_1;
CS_1;
void HT1621_Display(void)
//unsigned char i;
CS_0;//??CS
WR_0;
for(i=0;i<3;i++) //???
    if((0x05<<i)&0x04) DA_1;
    else DA_0;
    WR_0;
    WR_1;
for(i=0;i<6;i++) //???
    if((20<<i)&0x20) DA_1;//20?? SEG??
    else DA_0;
    WR_0;
    WR_1;
for(i=0;i<8;i++) //???
    if((DpyNum[5]<<i)&0x80)
                                                   DA_1;
    else DA_0;
    WR_0;
    WR_1;
if((DpyNum[4]<<i)&0x80)DA_1;
else DA_0;
WR_0;
WR_1;
if((DpyNum[3]<<i)&0x80) DA_1;
else DA_0;
WR_0;
WR_1;
if((DpyNum[2]<<i)&0x80)DA_1;
else DA_0;
WR_0;
WR_1;
if((DpyNum[1]<<i)&0x80)DA_1;
else DA_0;
WR_0;
WR_1;
if((DpyNum[0]<<i)&0x80) DA_1;
else DA_0;
WR_0;
WR_1;
CS_1;//??CS
void LCD_Init(void)
COMMAND_HT1621(0x01);//SYS EN
COMMAND_HT1621(0x03);//LCD ON
COMMAND_HT1621(0x29);//4 COM牋1/3 BIAS
HT1621_Display(); //clear screen
void main(void)
DDRD=0xff;
LCD_Init();
DpyNum[0] = Smg_a|Smg_d|Smg_g;//"?"
DpyNum[1] = SegCode[2];
DpyNum[2] = SegCode[4];
DpyNum[3] = SegCode[6];
DpyNum[4] = SegCode[8];
DpyNum[5] = SegCode[0];
HT1621_Display();
while(1)
效果图
xionghaoyun| | 2024-5-21 17:44 | 只看该作者
兄弟 中间注释是? 文字编码格式不对
13603089129| | 2024-5-23 16:06 | 只看该作者
专注替代HT162X系列段码屏驱动显示芯片
Cjy_JDxy| | 2024-9-20 17:26 | 只看该作者
xionghaoyun 发表于 2024-5-21 17:44
兄弟 中间注释是? 文字编码格式不对
应该是
昨天| | 2024-9-23 09:43 | 只看该作者
这个搞 的很规范哦??。
