[少儿编程]
深度学习圣经:Deep learning
1187|2
keer_zu|  楼主 | 2024-5-17 09:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
keer_zu|  楼主 | 2024-5-17 10:05 | 只看该作者
If we had separate parameters  for each value of the time index, we could not generalize to sequence lengths not  seen during training, nor share statistical strength across different sequence lengths  and across different positions in time.
keer_zu 2024-5-17 13:22 回复TA
The idea of parameter sharing manifests in the application of the same convolution kernel at each time step.
