How to control the GPIO P0.18 to output High and low with nrf52832?
384|0
Raygong1207|  楼主 | 2024-12-17 10:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
background:
1: my board  is the same with the nRF52832-CIAA Reference Layout 1_0 from nordic docs.
2: the source code is from sample code: blinky_led
3: only change the led0 to led1
#define LED0_NODE DT_ALIAS(led0)
to
#define LED0_NODE DT_ALIAS(led1)
My question is that:
1: seems that the output reg is right (at least the reg value can be change with my control), but  the measured voltage is always 3.3V with multimeter.
2: whether below reg value can show all info about gpio P0.18 ?
the reg value is below when control high.
CNF[18] = 0X00000003
OUT = 0X00040060  // Here changed, bit 18 to 1
IN = 0X002001C0
DIR = 0X00040060
LATVCH = 0X0
DETECTMODE = 0X0
the reg value is below when control LOW.
OUT = 0X00000060   // Here changed,bit 18 to 0
IN = 0X002001C0
DIR = 0X00040060
LATVCH = 0X0
DETECTMODE = 0X0
