[综合信息]
PID的算法实现其他 挺简单的
388|0
zhuotuzi|  楼主 | 2025-1-24 17:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
pi, pid, TE, ST, TI
* PID Controller Implementation in C
* Created by Joshua Saxby (aka @saxbophone) on 1 Jan, 2016
* My own attempt at implementing the PID algorithm in some (hopefully) clean, understandable C.
* See LICENSE for licensing details.
// protection against multiple includes
#ifndef SAXBOPHONE_PID_H
#define SAXBOPHONE_PID_H
#ifdef __cplusplus
extern "C"{
#endif
    typedef struct pid_calibration {
         * struct PID_Calibration
         * Struct storing calibrated PID constants for a PID Controller
         * These are used for tuning the algorithm and the values they take are
         * dependent upon the application - (in other words, YMMV...)
        double kp; // Proportional gain
        double ki; // Integral gain
        double kd; // Derivative gain
    } PID_Calibration;
    typedef struct pid_state {
         * struct PID_State
         * Struct storing the current state of a PID Controller.
         * This is used as the input value to the PID algorithm function, which also
         * returns a PID_State struct reflecting the adjustments suggested by the algorithm.
         * NOTE: The output field in this struct is set by the PID algorithm function, and
         * is ignored in the actual calculations.
        double actual; // The actual reading as measured
        double target; // The desired reading
        double time_delta; // Time since last sample/calculation - should be set when updating state
        // The previously calculated error between actual and target (zero initially)
        double previous_error;
        double integral; // Sum of integral error over time
        double output; // the modified output value calculated by the algorithm, to compensate for error
    } PID_State;
     * PID Controller Algorithm implementation
     * Given a PID calibration for the P, I and D values and a PID_State for the current
     * state of the PID controller, calculate the new state for the PID Controller and set
     * the output state to compensate for any error as defined by the algorithm
    PID_State pid_iterate(PID_Calibration calibration, PID_State state);
#ifdef __cplusplus
} // extern "C"
#endif
// end of header
#endif
#include "pid.h"
PID_State pid_iterate(PID_Calibration calibration, PID_State state) {
    // calculate difference between desired and actual values (the error)
    double error = state.target - state.actual;
    // calculate and update integral
    state.integral += (error * state.time_delta);
    // calculate derivative
    double derivative = (error - state.previous_error) / state.time_delta;
    // calculate output value according to algorithm
    state.output = (
        (calibration.kp * error) + (calibration.ki * state.integral) + (calibration.kd * derivative)
    // update state.previous_error to the error value calculated on this iteration
    state.previous_error = error;
    // return the state struct reflecting the calculations
    return state;
