[AT32F421]
TMR1用DMA搬运数据给CH1 CH2,失效
563|2
gregrgr|  楼主 | 2025-4-2 19:44 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
问题
TMR1用DMA搬运数据给CH1 CH2,通道1数据正常,通道2无任何反应。
void wk_tmr1_init(void)
  /* add user code begin tmr1_init 0 */
  /* add user code end tmr1_init 0 */
  gpio_init_type gpio_init_struct;
  tmr_output_config_type tmr_output_struct;
  tmr_brkdt_config_type tmr_brkdt_struct;
  gpio_default_para_init(&gpio_init_struct);
  /* add user code begin tmr1_init 1 */
  /* add user code end tmr1_init 1 */
  /* configure the tmr1 CH2 pin */
  gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE9, GPIO_MUX_2);
  gpio_init_struct.gpio_pins = GPIO_PINS_9;
  gpio_init_struct.gpio_mode = GPIO_MODE_MUX;
  gpio_init_struct.gpio_out_type = GPIO_OUTPUT_PUSH_PULL;
  gpio_init_struct.gpio_pull = GPIO_PULL_NONE;
  gpio_init_struct.gpio_drive_strength = GPIO_DRIVE_STRENGTH_MODERATE;
  gpio_init(GPIOA, &gpio_init_struct);
  /* configure counter settings */
  tmr_cnt_dir_set(TMR1, TMR_COUNT_UP);
  tmr_clock_source_div_set(TMR1, TMR_CLOCK_DIV1);
  tmr_repetition_counter_set(TMR1, 0);
  tmr_period_buffer_enable(TMR1, TRUE);
  tmr_base_init(TMR1, 143, 0);
  /* configure primary mode settings */
  tmr_sub_sync_mode_set(TMR1, FALSE);
  tmr_primary_mode_select(TMR1, TMR_PRIMARY_SEL_RESET);
  /* configure overflow event */
  tmr_overflow_request_source_set(TMR1, TRUE);
  /* configure channel 2 output settings */
  tmr_output_struct.oc_mode = TMR_OUTPUT_CONTROL_PWM_MODE_B;
  tmr_output_struct.oc_output_state = TRUE;
  tmr_output_struct.occ_output_state = FALSE;
  tmr_output_struct.oc_polarity = TMR_OUTPUT_ACTIVE_LOW;
  tmr_output_struct.occ_polarity = TMR_OUTPUT_ACTIVE_HIGH;
  tmr_output_struct.oc_idle_state = TRUE;
  tmr_output_struct.occ_idle_state = FALSE;
  tmr_output_channel_config(TMR1, TMR_SELECT_CHANNEL_2, &tmr_output_struct);
  tmr_channel_value_set(TMR1, TMR_SELECT_CHANNEL_2, 30);
  tmr_output_channel_buffer_enable(TMR1, TMR_SELECT_CHANNEL_2, TRUE);
  tmr_output_channel_immediately_set(TMR1, TMR_SELECT_CHANNEL_2, FALSE);
  /* configure break and dead-time settings */
  tmr_brkdt_struct.brk_enable = FALSE;
  tmr_brkdt_struct.auto_output_enable = FALSE;
  tmr_brkdt_struct.brk_polarity = TMR_BRK_INPUT_ACTIVE_LOW;
  tmr_brkdt_struct.fcsoen_state = FALSE;
  tmr_brkdt_struct.fcsodis_state = FALSE;
  tmr_brkdt_struct.wp_level = TMR_WP_OFF;
  tmr_brkdt_struct.deadtime = 0;
  tmr_brkdt_config(TMR1, &tmr_brkdt_struct);
  tmr_output_enable(TMR1, TRUE);
  tmr_counter_enable(TMR1, TRUE);
  /* add user code begin tmr1_init 2 */
  /* add user code end tmr1_init 2 */
gregrgr|  楼主 | 2025-4-3 11:46 | 只看该作者
已解决 板子上的触发器莫名其妙坏了
muyichuan2012| | 2025-4-3 09:06 | 只看该作者
你这代码不完整啊   DMA怎么配置的
