[研电赛技术支持]
GD32F470 TimerBase
316|0
Zhiniaocun|  楼主 | 2025-4-12 07:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//timer.c
#include "timer.h"
void timer_base_init(uint32_t x100ns)
  timer_parameter_struct timer_initpara;
  /* enable the peripherals clock */
  rcu_periph_clock_enable(USER_TIMER1_CLK);                //120M
  /* deinit a TIMER */
  timer_deinit(USER_TIMER1);
  /* initialize TIMER init parameter struct */
  timer_struct_para_init(&timer_initpara);
  /* TIMER2 configuration */
  timer_initpara.prescaler         = 12 - 1;
  timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
  timer_initpara.counterdirection  = TIMER_COUNTER_UP;
  timer_initpara.period            = x100ns - 1;
  timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
  timer_init(USER_TIMER1, &timer_initpara);
  /* clear channel 0 interrupt bit */
  timer_interrupt_flag_clear(USER_TIMER1, TIMER_INT_FLAG_UP);
  /* enable the TIMER interrupt */
  timer_interrupt_enable(USER_TIMER1, TIMER_INT_UP);
  /* enable a TIMER */
  timer_enable(USER_TIMER1);
  nvic_irq_enable(USER_TIMER1_IRQ, 0, 0);
void USER_TIMER1_IRQHandler(void)
  if(SET == timer_interrupt_flag_get(USER_TIMER1, TIMER_INT_UP)) {
    /* clear update interrupt bit */
    timer_interrupt_flag_clear(USER_TIMER1, TIMER_INT_UP);
      tp1_tog();
//timer.h
#ifndef __TIMER_H_
#define __TIMER_H_
#include "includes.h"
#define USER_TIMER1               TIMER1
#define USER_TIMER1_CLK           RCU_TIMER1
#define USER_TIMER1_IRQ           TIMER1_IRQn
#define USER_TIMER1_IRQHandler    TIMER1_IRQHandler
#define        T1US                10
#define        T1MS                (T1US*1000)
#define        T10MS                (T1MS*10)
void timer_base_init(uint32_t x100ns);
#endif
原文链接:https://blog.csdn.net/lljss1980/article/details/143107425
