[N32WBxxx]
N32WB452CEQ6单片机I2C异常
1005|12
ylq1433223|  楼主 | 2025-4-24 08:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在多次使用I2C和从机通信中,发现经常会有单片机I2C开始条件执行过后,状态寄存器为0的异常情况,经抓过波形发现单片机确实没有发出开始条件,各位大佬,帮忙看看代码是不会有什么问题uint8_t  i2c_master_recv(u8* pBuffer, uint8_t ReadAddr, uint16_t NumByteToRead)
                if(NumByteToRead > 1)
                        /** Disable Acknowledgement */
                        I2C_ConfigAck(I2C2, ENABLE);
                I2CTimeout = I2CT_LONG_TIMEOUT;
    while (I2C_GetFlag(I2C2, I2C_FLAG_BUSY))
                        if((I2CTimeout --) == 0)
        I2C_TIMEOUT_UserCallback(MASTER_BUSY);
                                return 0;
    /** Send START condition */
    // send start
//                I2C_Enable(I2C2,DISABLE);
//                I2C_Enable(I2C2,ENABLE);
    I2C_GenerateStart(I2C2, ENABLE);
    /** Test on EV5 and clear it */
    while (!I2C_CheckEvent(I2C2, I2C_EVT_MASTER_MODE_FLAG))
        I2C_TIMEOUT_UserCallback(MASTER_MODE);
                                return 0;
                /** Send write address for write */
    I2C_SendAddr7bit(I2C2, 0x40, I2C_DIRECTION_SEND);
    /** Test on EV6 and clear it */
    while (!I2C_CheckEvent(I2C2, I2C_EVT_MASTER_TXMODE_FLAG))
        I2C_TIMEOUT_UserCallback(MASTER_TXMODE);
                                return 0;
                I2C_Enable(I2C2, ENABLE);
                I2C_SendData(I2C2, ReadAddr);
//    /** Test on EV8 and clear it */
    while (!I2C_CheckEvent(I2C2, I2C_EVT_MASTER_DATA_SENDED))
        I2C_TIMEOUT_UserCallback(MASTER_SENDING);
                                return 0;
                /** Send STRAT condition a second time */
//    /** Test on EV5 and clear it */
                                return 0;
//                /** Send EEPROM address for read */
    I2C_SendAddr7bit(I2C2, 0x41, I2C_DIRECTION_RECV);
    /* Test on EV6 and clear it */
                while (!I2C_GetFlag(I2C2, I2C_FLAG_ADDRF))
            I2C_TIMEOUT_UserCallback(MASTER_BYTEF);
                                                return 0;
                if(NumByteToRead == 1)
                        I2C_ConfigAck(I2C2, DISABLE);
                        (void)(I2C2->STS1); /// clear ADDR
                        (void)(I2C2->STS2);
                        I2C_GenerateStop(I2C2, ENABLE);
                else
                        (void)(I2C2->STS1);
                        (void)(I2C2->STS2);
                        while(NumByteToRead)
                                /** Wait until RXNE flag is set */
                                while (!I2C_GetFlag(I2C2, I2C_FLAG_RXDATNE))
                                                return 0;
                                /** Read data from DAT */
                                /** Read a byte from the EEPROM */
                                *pBuffer++ = I2C_RecvData(I2C2);
                                NumByteToRead--;
                        //I2C_GenerateStop(I2C2, ENABLE);
                return 1;
ylq1433223|  楼主 | 2025-4-24 08:55 | 只看该作者
主要是经常在通讯开始的第一个开始条件上,它没发出来,剩下的也不会执行
昊430| | 2025-4-24 21:59 | 只看该作者
就是没有发出吧
ylq1433223|  楼主 | 2025-4-27 08:57 | 只看该作者
昊430 发表于 2025-4-24 21:59
就是没有发出吧
是的,单片机到这确实没发,多次执行发送启动条件也是没有发出,只能暂时通过重新初始化I2C解决这个问题
qeeuly| | 2025-4-29 09:49 | 只看该作者
仿真查看寄存器值
技术工程师| | 2025-4-29 11:27 | 只看该作者
建议还是用模拟I2C,硬件I2C大大小小都有些问题
probedog| | 2025-5-27 10:58 | 只看该作者
I2C总线的硬件连接是否正确,包括SCL和SDA线的上拉电阻。
classroom| | 2025-5-27 10:59 | 只看该作者
检查I2C时钟配置是否正确。
flycamelaaa| | 2025-5-27 11:00 | 只看该作者
I2C_EVT_MASTER_TXMODE_FLAG是用于指示I2C控制器已进入发送模式的事件标志。确保从机地址和方向设置正确。
powerantone| | 2025-5-27 11:00 | 只看该作者
确保I2C_EVT_MASTER_MODE_FLAG是正确的事件标志,用于指示I2C控制器已进入主模式。
suncat0504| | 2025-5-28 18:54 | 只看该作者
建议先用I2C例程测试。没问题再改造为自己的处理。
suncat0504| | 2025-5-28 18:56 | 只看该作者
要想让硬件的I2C外设正常工作,需要很多设置。看看设置处理是否被执行了。
suncat0504| | 2025-5-28 18:58 | 只看该作者
必要的话,在程序的每个分支中加入log输出,通过log,看看程序是否是按照你设想的逻辑顺序执行的。
