ISP_UART0.rar
(105.24 KB)
/* SPDX-License-Identifier: Apache-2.0 */
/* Copyright(c) 2023 Nuvoton Technology Corp. All rights reserved. */
// File Function: ML51 UART0 ISP demo code
#include "MG51_SDCC.H"
#include "isp_uart0.h"
//#define isp_with_wdt
unsigned int __xdata start_address,u16_addr;
void Serial_ISR(void) __interrupt (4)
PUSH_SFRS;
if (RI == 1)
uart_rcvbuf[bufhead++] = SBUF;
clr_SCON_RI; // Clear RI (Receive Interrupt).
if (TI == 1)
clr_SCON_TI; // Clear TI (Transmit Interrupt).
if (bufhead == 1)
g_timer1Over = 0;
g_timer1Counter = 90; //for check uart timeout using
if (bufhead == 64)
bUartDataReady = TRUE;
g_timer1Counter = 0;
g_timer1Over = 0;
bufhead = 0;
POP_SFRS;
void Timer0_ISR(void) __interrupt (1)
PUSH_SFRS;
if (g_timer0Counter)
g_timer0Counter--;
if (!g_timer0Counter)
g_timer0Over = 1;
if (g_timer1Counter)
g_timer1Counter--;
if (!g_timer1Counter)
g_timer1Over = 1;
POP_SFRS;
* Main function
void main (void)
set_CHPCON_IAPEN;
MODIFY_HIRC_24();
#ifdef isp_with_wdt
TA=0x55;TA=0xAA;WDCON=0x07;
#endif
//uart initial for ISP programmer GUI, always use 115200 baudrate
UART0_ini_115200_24MHz();
TM0_ini();
g_timer0Over=0;
g_timer0Counter=Timer0Out_Counter;
g_programflag=0;
while(1)
if(bUartDataReady == TRUE)
EA=0; //DISABLE ALL INTERRUPT
if(g_programflag==1)
for(count=8;count<64;count++)
// g_timer0Counter=Timer0Out_Counter;
IAPCN = BYTE_PROGRAM_AP; //program byte
IAPAL = flash_address&0xff;
IAPAH = (flash_address>>8)&0xff;
IAPFD=uart_rcvbuf[count];
#ifdef isp_with_wdt
set_IAPTRG_IAPGO_WDCLR;
#else
set_IAPTRG_IAPGO;
#endif
IAPCN = BYTE_READ_AP; //program byte verify
if(IAPFD!=uart_rcvbuf[count])
while(1);
if (CHPCON==0x43) //if error flag set, program error stop ISP
while(1);
g_totalchecksum=g_totalchecksum+uart_rcvbuf[count];
flash_address++;
if(flash_address==AP_size)
g_programflag=0;
g_timer0Over =1;
goto END_2;
END_2:
Package_checksum();
uart_txbuf[8]=g_totalchecksum&0xff;
uart_txbuf[9]=(g_totalchecksum>>8)&0xff;
Send_64byte_To_UART0();
switch(uart_rcvbuf[0])
case CMD_CONNECT:
case CMD_SYNC_PACKNO:
Package_checksum();
g_timer0Counter=0; //clear timer 0 for no reset
g_timer0Over=0;
break;
case CMD_GET_FWVER:
Package_checksum();
uart_txbuf[8]=FW_VERSION;
break;
case CMD_RUN_APROM:
goto _APROM;
break;
//please for ISP programmer GUI, ID always use following rule to transmit.
case CMD_GET_DEVICEID:
READ_ID();
Package_checksum();
uart_txbuf[8]=DID_lowB;
uart_txbuf[9]=DID_highB;
uart_txbuf[10]=PID_lowB;
uart_txbuf[11]=PID_highB;
break;
case CMD_ERASE_ALL:
set_IAPUEN_APUEN;
IAPFD = 0xFF; //Erase must set IAPFD = 0xFF
IAPCN = PAGE_ERASE_AP;
for(flash_address=0x0000;flash_address<APROM_SIZE/PAGE_SIZE;flash_address++)
IAPAL = LOBYTE(flash_address*PAGE_SIZE);
IAPAH = HIBYTE(flash_address*PAGE_SIZE);
#ifdef isp_with_wdt
#else
set_IAPTRG_IAPGO;
#endif
Package_checksum();
break;
case CMD_READ_CONFIG:
READ_CONFIG();
Package_checksum();
uart_txbuf[8]=CONF0;
uart_txbuf[9]=CONF1;
uart_txbuf[10]=CONF2;
uart_txbuf[11]=0xff;
uart_txbuf[12]=CONF4;
uart_txbuf[13]=0xff;
uart_txbuf[14]=0xff;
uart_txbuf[15]=0xff;
break;
case CMD_UPDATE_CONFIG:
recv_CONF0 = uart_rcvbuf[8];
recv_CONF1 = uart_rcvbuf[9];
recv_CONF2 = uart_rcvbuf[10];
recv_CONF4 = uart_rcvbuf[12];
set_IAPUEN_CFUEN; /*Erase CONFIG */
IAPCN = PAGE_ERASE_CONFIG;
IAPAL = 0x00;
IAPAH = 0x00;
IAPFD = 0xFF;
#ifdef isp_with_wdt
#else
set_IAPTRG_IAPGO;
#endif
IAPCN = BYTE_PROGRAM_CONFIG; /*Program CONFIG*/
IAPFD = recv_CONF0;
#ifdef isp_with_wdt
#else
set_IAPTRG_IAPGO;
#endif
IAPFD = recv_CONF1;
IAPAL = 0x01;
#ifdef isp_with_wdt
#else
set_IAPTRG_IAPGO;
#endif
IAPAL = 0x02;
IAPFD = recv_CONF2;
#ifdef isp_with_wdt
#else
set_IAPTRG_IAPGO;
#endif
IAPAL = 0x04;
IAPFD = recv_CONF4;
#ifdef isp_with_wdt
#else
set_IAPTRG_IAPGO;
#endif
clr_IAPUEN_CFUEN;
READ_CONFIG(); /*Read new CONFIG*/
Package_checksum();
break;
case CMD_UPDATE_APROM:
set_IAPUEN_APUEN;
start_address = 0;
start_address = uart_rcvbuf[8];
start_address |= ((uart_rcvbuf[9]<<8)&0xFF00);
AP_size = 0;
AP_size = uart_rcvbuf[12];
AP_size |= ((uart_rcvbuf[13]<<8)&0xFF00);
u16_addr = start_address + AP_size;
flash_address = (start_address&0xFF00);
while(flash_address< u16_addr)
IAPAL = LOBYTE(flash_address);
IAPAH = HIBYTE(flash_address);
#ifdef isp_with_wdt
#else
set_IAPTRG_IAPGO;
#endif
flash_address += PAGE_SIZE;
g_totalchecksum = 0;
flash_address = start_address;
g_programflag = 1;
for(count=16;count<64;count++)
IAPFD = uart_rcvbuf[count];
#ifdef isp_with_wdt
#else
set_IAPTRG_IAPGO;
#endif
set_IAPTRG_IAPGO;
while(1);
while(1);
flash_address++;
g_programflag=0;
goto END_1;
END_1:
Package_checksum();
break;
bUartDataReady = FALSE;
bufhead = 0;
EA=1;
/*For connect timer out */
if(g_timer0Over==1)
CALL_NOP;
goto _APROM;
/*for uart time out or buffer error */
if(g_timer1Over==1)
if((bufhead<64)&&(bufhead>0)||(bufhead>64))
bufhead=0;
_APROM:
EA=0;
MODIFY_HIRC_16();
clr_CHPCON_IAPEN;
TA = 0xAA; TA = 0x55; CHPCON = 0x80; //software reset enable boot from APROM
/* Trap the CPU */
while(1);
