[PCB]
QCN9074 vs QCN9024
172|0
As wireless communication technology evolves, WiFi 6 (802.11ax) has become the mainstream standard for next-generation high-performance wireless access. Qualcomm, a leader in wireless chipsets, offers a broad lineup of WiFi 6 solutions, among which QCN9074 and QCN9024 are two widely adopted main wireless chips used in high-performance routers, enterprise-grade access points (APs), and industrial networking devices.
This article presents a comprehensive comparison of these two chips from multiple perspectives, including core specifications, application scenarios, feature sets, platform compatibility, and use cases.
1. Core Specifications Comparison[td]
ParameterQCN9074QCN9024
Standard SupportIEEE 802.11a/b/g/n/ac/ax (WiFi 6)IEEE 802.11a/b/g/n/ac/ax (WiFi 6)
Frequency Bands2.4GHz, 5GHz (6GHz capable but disabled)2.4GHz, 5GHz
Spatial Streams4x4 MU-MIMO4x4 MU-MIMO
Modulation1024-QAM1024-QAM
Channel BandwidthUp to 160MHzUp to 160MHz
PHY RateUp to 4.8GbpsUp to 4.8Gbps
InterfacePCIe 3.0PCIe 3.0
BeamformingYesYes
OFDMA / MU-MIMOUplink & DownlinkUplink & Downlink
Target ApplicationsHigh-end enterprise, outdoor APs, industrial devicesCommercial-grade, home or mid-tier enterprise APs
OpenWRT SupportStrong and well-maintainedPartially supported depending on vendor
Multi-band CoordinationStrong, ideal for dense deploymentsModerate, suitable for typical deployments
2. Architecture and Design DifferencesQCN9074
  • Designed as Qualcomm’s flagship WiFi 6 radio chip, aimed at high-performance networking.
  • Supports advanced 4x4@5G MIMO configurations, ideal for enterprise APs, outdoor mesh systems, and industrial gateways.
  • Commonly paired with IPQ807x/IPQ957x series SoCs, or deployed on x86 platforms via PCIe cards.
  • Some variants are hardware-ready for 6GHz (though not enabled), allowing future upgrades.
QCN9024
  • A mainstream WiFi 6 solution for mid-tier markets, offering a cost-performance balance.
  • Well-suited for home mesh systems, commercial APs, and SOHO routers.
  • Features a simpler thermal and mechanical design with lower power consumption.
  • Typically used with IPQ601x/IPQ5018/IPQ807x SoCs in integrated or modular systems.
3. Feature Comparison[td]
FeatureQCN9074QCN9024
Beamforming
TWT (Target Wake Time)
BSS Coloring
Uplink OFDMA
Downlink MU-MIMO
DFS Band Support✅ (for outdoor usage)
Spectrum Analysis✅ (important for industrial use)Limited support
Performance TuningHigh flexibility, ideal for complex networksModerate, best for structured deployments
4. Application Scenarios[td]
ScenarioRecommended Chip
Outdoor mesh APs (high power, long range)QCN9074
Industrial-grade wireless devices (e.g., mining, ports)QCN9074
Indoor enterprise ceiling APsQCN9024
Home mesh nodes, SMB routersQCN9024
WiFi 6 PCIe NICsBoth supported, QCN9074 preferred
Deep integration with OpenWRT/OpenWiFiQCN9074 (more active community support)
5. Driver and Platform Compatibility
  • Linux Driver Support:
    • QCN9074 is well supported by the ath11k driver, with compatibility across OpenWRT, QSDK, and OpenWiFi (some branches).
    • QCN9024 has reasonable support, though some commercial devices require custom driver implementation.
  • System Platform Integration:
    • QCN9074 is mature on IPQ8072A/IPQ9574/x86-based platforms.
    • QCN9024 is widely used with IPQ6010, IPQ5018, and IPQ8072 SoCs.
6. Cost and Supply Considerations[td]
AspectQCN9074QCN9024
Chip Cost (per unit)Medium-HighMedium-Low
Module Cost (e.g., DR9074 vs DR9024)~15–20% higherLower, suitable for mass production
Package SizeLargerMore compact
Thermal ManagementHigh requirementModerate
7. Summary and Recommendations[td]
DimensionRecommended Chip
High performance, high client density environmentsQCN9074
Cost-sensitive, stable WiFi 6 experienceQCN9024
Preparing for future WiFi 7 upgradesQCN9074
SMB or home network deploymentQCN9024
Tight integration with open-source platformsQCN9074
Appendix: Example Modules and Use Cases[td]
Module ModelChipsetFrequency BandsMIMOUse Case
DR9074QCN90742.4/5GHz4x4Outdoor AP / Industrial router
DR9024QCN90242.4/5GHz4x4Indoor AP / Home router
CNV9024QCN90242.4/5GHz2x2Embedded wireless modules
If you need further details on reference schematics, antenna selection, or system-level thermal/power modeling, feel free to ask.
