[MM32硬件]
【灵动微电子MM32F0121测评】8、移植RTOS到MM32F0121系列MCU
863|1
本文目的:移植RTOS到MM32F0121系列MCU
首先要准备一个MM32F0121基本模板,可以以GPIO_LED_Toggle为基础。
在LibSamples_MM32F0120_V1.13.4中建立了middlewares\freertos目录,复制一份freeRTOS库文件此目录
将freeRTOS下各路径下7个文件添加到工程中
添加include paths
..\..\..\..\..\middlewares\freertos\source\include
..\..\..\..\..\middlewares\freertos\source\portable\rvds\ARM_CM0
在freeRTOS中找到FreeRTOSConfig.h、portmacro.h,复制到工程根目录下
FreeRTOSConfig.h中修改
#define configUSE_PREEMPTION                        1
#define configUSE_IDLE_HOOK                                0
#define configUSE_TICK_HOOK                                0
#define configCPU_CLOCK_HZ                                ( 72000000 )
#define configTICK_RATE_HZ                                ( ( TickType_t ) 1000 )
#define configMAX_PRIORITIES                        ( 5 )
#define configMINIMAL_STACK_SIZE                ( ( unsigned short ) 128 )
#define configTOTAL_HEAP_SIZE                        ( ( size_t ) ( 3*1024 ) )
#define configMAX_TASK_NAME_LEN                        ( 5 )
#define configUSE_TRACE_FACILITY                1
#define configUSE_16_BIT_TICKS                        0
#define configIDLE_SHOULD_YIELD                        1
#define configUSE_MUTEXES                                1
#define configQUEUE_REGISTRY_SIZE                8
#define configCHECK_FOR_STACK_OVERFLOW        0
#define configUSE_RECURSIVE_MUTEXES                1
#define configUSE_MALLOC_FAILED_HOOK        0
#define configUSE_APPLICATION_TASK_TAG        0
#define configUSE_COUNTING_SEMAPHORES        1
#define configGENERATE_RUN_TIME_STATS        0
/* Co-routine definitions. */
#define configUSE_CO_ROUTINES                         0
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
/* Software timer definitions. */
#define configUSE_TIMERS                                0
#define configTIMER_TASK_PRIORITY                ( 2 )
#define configTIMER_QUEUE_LENGTH                5
#define configTIMER_TASK_STACK_DEPTH        ( 80 )
/* Set the following definitions to 1 to include the API function, or zero
to exclude the API function. */
#define INCLUDE_vTaskPrioritySet                1
#define INCLUDE_uxTaskPriorityGet                1
#define INCLUDE_vTaskDelete                                1
#define INCLUDE_vTaskCleanUpResources        1
#define INCLUDE_vTaskSuspend                        1
#define INCLUDE_vTaskDelayUntil                        1
#define INCLUDE_vTaskDelay                                1
/* Normal assert() semantics without relying on the provision of an assert.h
header file. */
#define configASSERT( x ) if( ( x ) == 0 ) { taskDISABLE_INTERRUPTS(); for( ;; ); }
/* Definitions that map the FreeRTOS port interrupt handlers to their CMSIS
standard names - or at least those used in the unmodified vector table. */
//#define vPortSVCHandler SVC_Handler
#define xPortPendSVHandler PendSV_Handler
#define xPortSysTickHandler SysTick_Handler
#endif /* FREERTOS_CONFIG_H */
注意其中:
#define configCPU_CLOCK_HZ                                ( 72000000 )  //主频72MHZ
#define configMINIMAL_STACK_SIZE                ( ( unsigned short ) 128 )  //stack根据情况设置,LED task可以设小点,printf需要设大一点
#define xPortPendSVHandler PendSV_Handler  //
#define xPortSysTickHandler SysTick_Handler  //这两个中断需要被freeRTOS接管
mm32f0120_it.c中将这两个中断处理函数注释掉,避免编译冲突
void PendSV_Handler(void)
void SysTick_Handler(void)
    if (0 != PLATFORM_DelayTick)
        PLATFORM_DelayTick--;
main()修改,执行freeRTOS_Sample()
int main(void)
    PLATFORM_Init();
                freeRTOS_Sample();
    while (1)
PLATFORM_Init中注释掉PLATFORM_InitDelay()
void PLATFORM_Init(void)
   // PLATFORM_InitDelay();
    PLATFORM_InitConsole(115200);
    PLATFORM_InitLED();
    PLATFORM_PrintInfo();
新建freeRTOS_demo.c存放以下内容:
freeRTOS_Sample()
建立3个Task
#define PRINT_TASK_STACK_SIZE  (256)  // 256 words = 1024 bytes
#define LED_TASK_STACK_SIZE    (configMINIMAL_STACK_SIZE)  // 128 words = 512 bytes
void freeRTOS_Sample(void)
        printf("【灵动微电子MM32F0121测评】8、移植RTOS到MM32F0121系列MCU\r\n");
        SysTick_Init();
        xTaskCreate( vLED1Task, "LED1", LED_TASK_STACK_SIZE, NULL,  tskIDLE_PRIORITY + 6 , NULL );
        xTaskCreate( vLED2Task, "LED2", LED_TASK_STACK_SIZE, NULL,  tskIDLE_PRIORITY + 7 , NULL );
        xTaskCreate( printTask, "print", PRINT_TASK_STACK_SIZE, NULL,  tskIDLE_PRIORITY + 8 , NULL );
        vTaskStartScheduler();
        while(1); // 正常情况下不会执行到这里
SysTick_Init()
static void SysTick_Init(void)
        if (SysTick_Config(SystemCoreClock / configTICK_RATE_HZ)) {
    printf("SysTick config failed\r\n");
                while (1);  // 初始化失败
三个TASK
void vLED1Task( void *pvParameters )
    for( ;; )
                PLATFORM_LED_Toggle(LED1);
                //printf("1 Free Heap: %d\n", xPortGetFreeHeapSize());
    vTaskDelay(pdMS_TO_TICKS(100));
void vLED2Task( void *pvParameters )
        for( ;; )
                PLATFORM_LED_Toggle(LED2);
                //printf("2 Free Heap: %d\n", xPortGetFreeHeapSize());
                vTaskDelay(pdMS_TO_TICKS(500));
void printTask( void *pvParameters )
  for( ;; )
                printf("Hello 21ic, Hello MM32F0121\r\n");
    vTaskDelay(pdMS_TO_TICKS(2000));
运行情况:
AdaMaYun| | 2025-7-31 17:58 | 只看该作者
移植RTOS很不错的
