#申请开发板# #申请原创# 很荣幸收到极海赠送的APM32E030开发板,今天来测试一下跑分性能。首先从github上下载coremark源代码库
coremark
我只需要其中这几个文件,把它们放在一个文件夹里
然后添加到KEIL工程里面
开始修改
1.首先修改启动文件的堆栈空间,设大一些
2.修改portme文件
//#define NSECS_PER_SEC CLOCKS_PER_SEC
//#define CORETIMETYPE clock_t
//#define GETMYTIME(_t) (*_t = clock())
#include "hal_systick.h"
#define NSECS_PER_SEC TICKS_PER_SECOND
#define CORETIMETYPE uint32_t
#define GETMYTIME(_t) (*_t = hal_systick_get())
#define MYTIMEDIFF(fin, ini) ((fin) - (ini))
#define TIMER_RES_DIVIDER 1
#define SAMPLE_TIME_IMPLEMENTATION 1
#define EE_TICKS_PER_SEC (NSECS_PER_SEC / TIMER_RES_DIVIDER)
/** Define Host specific (POSIX), or target specific global time variables. */
static CORETIMETYPE start_time_val, stop_time_val;
#ifndef COMPILER_VERSION
#ifdef __GNUC__
#define COMPILER_VERSION "GCC"__VERSION__
#else
#define COMPILER_VERSION "Please put compiler version here (e.g. gcc 4.1)"
#endif
#endif
#ifndef COMPILER_FLAGS
#define COMPILER_FLAGS "-Omax" /* "Please put compiler flags here (e.g. -o3)" */
#endif
#ifndef MEM_LOCATION
#define MEM_LOCATION "STACK"
#endif
#define ITERATIONS 10000 // 这个值需要保证能够运行至少10秒,可以先写一个值,运行不足10秒会报错,再回来修改
#if MAIN_HAS_NOARGC
MAIN_RETURN_TYPE
coremark_main(void)
int argc = 0;
char *argv[1];
#else
MAIN_RETURN_TYPE
coremark_main(int argc, char *argv[])
主函数添加核心功能函数
* @file main.c
* @brief Main program body
* @version V1.0.4
* @date 2025-02-15
* @attention
* Copyright (C) 2021-2025 Geehy Semiconductor
* You may not use this file except in compliance with the
* GEEHY COPYRIGHT NOTICE (GEEHY SOFTWARE PACKAGE LICENSE).
* The program is only for reference, which is distributed in the hope
* that it will be useful and instructional for customers to develop
* their software. Unless required by applicable law or agreed to in
* writing, the program is distributed on an "AS IS" BASIS, WITHOUT
* ANY WARRANTY OR CONDITIONS OF ANY KIND, either express or implied.
* See the GEEHY SOFTWARE PACKAGE LICENSE for the governing permissions
* and limitations under the License.
/* Includes ***************************************************************/
#include "main.h"
#include "Board.h"
#include <stdio.h>
/* Private includes *******************************************************/
#include "coremark.h"
/* Private macro **********************************************************/
/* printf using USART1 */
#define DEBUG_USART USART1
/* Private typedef ********************************************************/
/* Private variables ******************************************************/
static __IO u32 TimingDelay;
/* Private function prototypes ********************************************/
void SysTick_Init(void);
void SysTick_Delay_ms(__IO u32 nTime);
void TimingDelay_Decrement(void);
/* External variables *****************************************************/
void coremark_main(void);
/* External functions *****************************************************/
* @param None
* @retval None
int main(void)
USART_Config_T usartConfigStruct;
usartConfigStruct.baudRate = 115200;
usartConfigStruct.hardwareFlow = USART_HARDWARE_FLOW_NONE;
usartConfigStruct.mode = USART_MODE_TX;
usartConfigStruct.parity = USART_PARITY_NONE;
usartConfigStruct.stopBits = USART_STOP_BIT_1;
usartConfigStruct.wordLength = USART_WORD_LEN_8B;
BOARD_COMInit(COM1, &usartConfigStruct);
BOARD_LEDInit(LED2);
BOARD_LEDInit(LED3);
printf("\r\nDelay Time = 1000ms\r\n");
/* SysTick Initialization */
SysTick_Init();
printf("极海APM32F402 EVAL评估板 coremark跑分:\r\n");
coremark_main();
while (1)
BOARD_LEDToggle(LED2);
BOARD_LEDToggle(LED3);
/* Precise Delay 1ms */
SysTick_Delay_ms(1000);
* @brief Start SysTick
* @param None
* @retval None
SystemCoreClock = RCM_ReadSYSCLKFreq();
/* SystemFrequency / 1000 = 1ms */
if (SysTick_Config(SystemCoreClock / 1000))
/* Capture error */
while (1);
* @brief Precise Delay
* @param nTime in milliseconds
* @retval None
TimingDelay = nTime;
while(TimingDelay != 0);
* @brief Decrements the TimingDelay
* @param None
* @retval None
if(TimingDelay != 0)
TimingDelay--;
#if defined (__CC_ARM) || defined (__ICCARM__) || (defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050))
* @brief Redirect C Library function printf to serial port.
* After Redirection, you can use printf function.
* @param ch: The characters that need to be send.
* @param *f: pointer to a FILE that can recording all information
* needed to control a stream
* @retval The characters that need to be send.
* @note
int fputc(int ch, FILE* f)
/* send a byte of data to the serial port */
USART_TxData(DEBUG_USART, (uint8_t)ch);
/* wait for the data to be send */
while (USART_ReadStatusFlag(DEBUG_USART, USART_FLAG_TXBE) == RESET);
return (ch);
#elif defined (__GNUC__)
* @note
int __io_putchar(int ch)
USART_TxData(DEBUG_USART, ch);
return ch;
* @param file: Meaningless in this function.
* @param *ptr: Buffer pointer for data to be sent.
* @param len: Length of data to be sent.
* @note
int _write(int file, char* ptr, int len)
UNUSED(file);
int i;
for (i = 0; i < len; i++)
__io_putchar(*ptr++);
return len;
#else
#warning Not supported compiler type
#endif
编译后烧录代码
打开串口助手,115200波特率
等待10S左右时间会出现跑分结果
可以看到,APM32E030 EVAL评估板 coremark跑分:
153.699548 分,在开最大优化等级 -Omax条件下
这个分数在Cortex M0中很强了
