苹果园 https://passport2.21ic.com/?36088 [收藏] [复制] [RSS] 嵌入式的综合开发
日志
C语言宏定义详解
已有 780 次阅读2010-3-19 03:36 |个人分类:WinCE园子|系统分类:ARM| C语言宏定义
语言宏定义详解
[ 2009-5-26 7:32:00 | By: kreal ]
1,防止一个头文件被重复包含
ifndef
 COMDEF_H
#define COMDEF_H
头文件内容
endif
2,
重新定义一些类型,防止由于各种平台和编译器的不同,而产生的类型字节数差异,方便移植。
typedef  unsigned char      boolean
;     /* Boolean value type. */
typedef  unsigned long int
  uint32;      /* Unsigned 32 bit value */
typedef
  unsigned short     uint16;      /* Unsigned 16 bit value */
typedef
  unsigned char      uint8;       /* Unsigned 8  bit value */
typedef  signed long int
    int32;       /* Signed 32 bit value */
typedef
  signed short       int16;       /* Signed 16 bit value */
typedef
  signed char        int8;        /* Signed 8  bit value */
下面的不建议使用
typedef  unsigned char     byte;         /* Unsigned 8  bit
 value type. */
typedef  unsigned short    word;         /* Unsinged
 16 bit value type. */
typedef  unsigned long     dword
;        /* Unsigned 32 bit value type. */
typedef  unsigned
 char     uint1;        /* Unsigned 8  bit value type. */
typedef  unsigned
 short    uint2;        /* Unsigned 16 bit value type. */
typedef  unsigned
 long     uint4;        /* Unsigned 32 bit value type. */
typedef  signed
 char       int1;         /* Signed 8  bit value type. */
typedef  signed
 short      int2;         /* Signed 16 bit value type. */
typedef  long int
          int4;         /* Signed 32 bit value type. */
typedef
  signed long       sint31;       /* Signed 32 bit value */
typedef
  signed short      sint15;       /* Signed 16 bit value */
typedef
  signed char       sint7;        /* Signed 8  bit value */
3,
得到指定地址上的一个字节或字
#define  MEM_B( x )  ( *( (byte *) (x) ) )
#define  MEM_W( x )  ( *( (word *) (x) ) )
4,求最大值和最小值
   #define  MAX( x, y ) ( ((x) > (y)) ? (x) : (y) )
   #define  MIN( x, y ) ( ((x) < (y)) ? (x) : (y) )
5,得到一个field在结构体(
struct)
中的偏移量
#define FPOS( type, field ) \
/*lint -e545 */ ( (
dword
) &(( type *) 0)-> field ) /*lint +e545 */
6,
得到一个结构体中field所占用的字节数
#define FSIZ( type, field )
sizeof
( ((type *) 0)->field )
7,
按照LSB格式把两个字节转化为一个Word
#define  FLIPW( ray ) ( (((word) (ray)[0]) * 256) + (ray)[1] )
8,按照LSB格式把一个Word转化为两个字节
#define  FLOPW( ray,
val
  (ray)[0] = ((
val
) / 256); \
  (ray)[1] = ((
val
) & 0xFF)
9,
得到一个变量的地址(word宽度)
#define  B_PTR(
var )  ( (byte *) (void *) &(var
#define  W_PTR(
var )  ( (word *) (void *) &(var
10,
得到一个字的高位和低位字节
#define  WORD_LO(xxx)  ((byte) ((word)(xxx) & 255))
#define  WORD_HI(xxx)  ((byte) ((word)(xxx) >> 8))
11,返回一个比X大的最接近的8的倍数
#define RND8( x )       ((((x) + 7) / 8 ) * 8 )
12,将一个字母转换为大写
#define  UPCASE( c ) ( ((c) >= ''a'' && (c) <= ''z'') ? ((c) - 0x20) : (c) )
13,判断字符是不是10
进值的
数字
#define  DECCHK( c ) ((c) >= ''0'' && (c) <= ''9'')
14,判断字符是不是16
进值的
数字
#define  HEXCHK( c ) ( ((c) >= ''0'' && (c) <= ''9'') ||\
                       ((c) >= ''A'' && (c) <= ''F'') ||\
((c) >= ''a'' && (c) <= ''f'') )
15,防止溢出的一个方法
#define  INC_SAT(
val )  (val = ((val)+1 > (val)) ? (val)+1 : (val
16,
返回数组元素的个数
#define  ARR_SIZE( a )  (
sizeof( (a) ) / sizeof
( (a[0]) ) )
17,
返回一个无符号数n尾的值MOD_BY_POWER_OF_TWO(X,n
)=X%(2^n)
#define MOD_BY_POWER_OF_TWO(
valmod_by
dword)(val) & (dword)((mod_by
)-1) )
18,
对于IO空间映射在存储空间的结构,输入输出处理
  #define
inp
(port)         (*((volatile byte *) (port)))
  #define
inpw
(port)        (*((volatile word *) (port)))
  #define
inpdw(port)       (*((volatile dword
 *)(port)))
  #define
outp(port, val)   (*((volatile byte *) (port)) = ((byte) (val
  #define
outpw(port, val)  (*((volatile word *) (port)) = ((word) (val
  #define
outpdw(port, val) (*((volatile dword *) (port)) = ((dword) (val
 19,使用一些宏
跟踪调试
A N S I
标准说明了五个预定义的宏名。它们是:
_ L I N E _
_ F I L E _
_ D A T E _
_ T I M E _
_ S T D C _
如果编译不是标准的,则可能仅支持以上宏名中的几个,或根本不支持。记住编译程序
也许还提供其它预定义的宏名。
_ L I N E _
_ F I L E _宏指令在有关# l
i n e的部分中已讨论,这里讨论其余的宏名。
_ D AT E _
宏指令含有形式为月//年的串,表示源文件被翻译到代码时的日期。
源代码翻译到目标代码的时间作为串包含在_ T I M E _中。
串形式为时:分:秒。
如果实现是标准的,则宏_ S T D C _含有十进制常量1。如果它含有任何其它数,则实现是
非标准的。
可以定义宏,例如
当定义了_DEBUG,输出数据信息和所在文件所在行
ifdef _DEBUG
#define DEBUGMSG(
msg,dateprintf(msg);printf(%d%d%d,date,_LINE_,_FILE
_)
#else
      #define DEBUGMSG(
msg,date
endif
20,
宏定义防止使用是错误
用小括号包含。
例如:#define ADD(
a,ba+b
do{}while(0)语句包含多语句防止错误
例如:#
difne DO(a,ba+b;\
                   a++;
应用时:if(.)
          DO(
a,b); //产生错误
        else
解决方法: #
difne DO(a,b) do{a+b;\
                   a++;}while(0)
宏中"#""##"的用法
一、一般用法
我们使用#把宏参数变为一个字符串,##把两个宏参数贴合在一起
用法
#i nclude<
cstdio>
#i nclude<
climits
using namespace std;
#define STR(s)     #s
#define CONS(
a,b)  int(a##e##b
int
 main()
printf(STR(vck));           // 输出字符串"vck
printf("%d\n", CONS(2,3));  // 2e3
输出:2000
    return 0;
二、当宏参数是另一个宏的时候
需要注意的是凡宏定义里有用''#''''##''的地方宏参数是不会再展开
1,
''#''''##''的情况
#define TOW      (2)
#define MUL(
a,b) (a*b)
printf
("%d*%d=%d\n", TOW, TOW, MUL(TOW,TOW));
这行的宏会被展开
为:
printf("%d*%d=%d\n", (2), (2), ((2)*(2)));
MUL
里的参数TOW被展开
(2).
2,
当有''#''''##''的时候
#define A          (2)
#define STR(s)     #s
#define CONS(
a,b)  int(a##e##b)
printf("int max: %s\n",  STR(INT_MAX));    // INT_MAX #i nclude<climits
这行会被展开
为:
printf("int max: %s\n", "INT_MAX");
printf
("%s\n", CONS(A, A));               // compile error
这一行则是:
printf("%s\n", int(AeA));
INT_MAX
A都不会再被展开然而解决这个问题的方法很简单加多一层中间转换宏.
加这层宏的用意是把所有宏的参数在这层里全部展开那么在转换宏里的那一个宏(_STR)就能得到正确的宏参数
#define A           (2)
#define _STR(s)     #s
#define STR(s)      _STR(s)          //
转换宏
#define _CONS(
a,b)  int(a##e##b)
#define CONS(
a,b)   _CONS(a,b)       //
转换宏
printf("int max: %s\n", STR(INT_MAX));          // INT_MAX,int型的最大值,为一个变量 #i nclude<climits>
输出为int
 max: 0x7fffffff
STR(INT_MAX) -->  _STR(0x7fffffff)
然后再转换成字符串;
printf("%d\n", CONS(A, A));
输出为:200
CONS(A, A)  -->  _CONS((2), (2))  -->
int((2)e(2))
三、''#''''##''的一些应用特例
、合并匿名变量名
#define  ___ANONYMOUS1(type,
var, line)  type  var##line
#define  __ANONYMOUS0(type, line)  ___ANONYMOUS1(type, _anonymous, line)
#define  ANONYMOUS(type)  __ANONYMOUS0(type, __LINE__)
例:ANONYMOUS(static int);  : static int _anonymous70;  70
表示该行行号;
第一层:ANONYMOUS(static
int);  -->  __ANONYMOUS0(static int, __LINE__);
第二层:                        -->  ___ANONYMOUS1(static int
, _anonymous, 70);
第三层:                        -->  static int
  _anonymous70;
即每次只能解开当前层的宏,所以__LINE__在第二层才能被解开;
、填充结构
#define  FILL(a)   {a, #a}
enum IDD{OPEN, CLOSE};
typedef struct
 MSG{
  IDD id;
  const char *
msg
}MSG;
MSG _
msg
[] = {FILL(OPEN), FILL(CLOSE)};
相当于:
MSG _
msg[] = {{OPEN, "OPEN"},
              {CLOSE, "CLOSE"}};
、记录文件名
#define  _GET_FILE_NAME(f)   #f
#define  GET_FILE_NAME(f)    _GET_FILE_NAME(f)
static char  FILE_NAME[] = GET_FILE_NAME(__FILE__);
、得到一个数值类型所对应的字符串缓冲大小
#define  _TYPE_BUF_SIZE(type)
sizeof #type
#define  TYPE_BUF_SIZE(type)   _TYPE_BUF_SIZE(type)
char
buf
[TYPE_BUF_SIZE(INT_MAX)];
     -->  char
buf
[_TYPE_BUF_SIZE(0x7fffffff)];
     -->  char
buf[sizeof
 "0x7fffffff"];
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
